Few lisps to improve workflow
Lukasvop1
Message 1 of 49
Lukasvop1
Hi guys, can you check this. I need create this few easy lisps separatly. Can you help?
1. LDN - Laydel, Name
2. MPT - Multiple Point
3. ZO - Zoom object
4. LP - Line perpendicular
5. LTA - Line tangent
6. C3T - tan, tan, tan
@komondormrex
Replies (48)
Message 2 of 49
paullimapa
So what you are showing on the pictures with each of the command prompts (except the last one where you didn’t) is exactly the same sequence in a lisp file. I’ll give you one example and then you should be able to do the others. Here’s the one for Zoom Object :
(defun c:zo () ; this defines a function you can type at command prompt as zo
(command "_.zoom" "_o") ; surround response to each command prompt with quotes
) ; defun zo
Paul Li
IT Specialist
@The Office
Message 3 of 49
Lukasvop1
Yes, I tried this, but it doesn't work right..
Message 4 of 49
paullimapa
Elaborate on what doesn’t work right
Paul Li
IT Specialist
@The Office
Message 5 of 49
hak_vz
For multiple point  by using menus DRAW>POINT>MULTIPLE POINT or
if you want lisp than something like
(defun c:mpt(/ pnt)
  (while (setq pnt (getpoint "\nSpecify a point: "))(command "_.point" pnt))
  (princ)
(defun c:zo( / ss)
	(cond
		((setq ss (last(ssgetfirst)))
			(command "_.zoom" "_O" ss "")
		(T
			(princ "\nSelect object(s) to zoom to > ")
			(command "_.zoom" "_O" (ssget) "")
	(princ)
Miljenko Hatlak
Message 6 of 49
Sea-Haven
Sq pt see attached
"Circle 3" is in built option to circle.
Message 7 of 49
Lukasvop1
Thank you
Message 8 of 49
Lukasvop1
No, there are options for "3 point circle" and "2 tangents and radius"
I asking for 3 tangents circle.
Message 9 of 49
Lukasvop1
Here I try explain :
Message 10 of 49
ВeekeeCZ
It is, it's just a menu macro in ribbon
The lisp line looks like this.
(command "_.circle" "_3p" "_tan" pause "_tan" pause "_tan" pause)
You really need to learn these basic customizations.
Message 11 of 49
Lukasvop1
Thank you, I don't know it work's like this, (I mean add "_" before command and pause after it).
Can you tell me why this doesn't work?
(defun c:LDN()
(command "-laydel" "_n")
(princ)
Message 12 of 49
Kent1Cooper
Your image is too hard to read, so I'm not positive about what you want in number 4, but maybe it's the (pf) [= perpendicular from] function defined >here<.
Kent Cooper, AIA
Message 13 of 49
Lukasvop1
Yes, perpendicular line.
I post video in Message 11.
I need last two lisps from list:
Message 14 of 49
ВeekeeCZ
(defun c:LDN()
(initcommandversion)
(princ)
Try it with (initcommandversion)
Message 15 of 49
Lukasvop1
Nothing changes, not working..
Message 16 of 49
hak_vz
@Lukasvop1  Here you have C3T.
If you like it press "accept solution button". Is this so hard to do?
(defun c:c3t (/ *error* LM:intersections a1 a2 a3 e1 e2 e3 p1 p2 p3 a b c s r cp)
	(defun *error* ( msg )
		(if (not (member msg '("Function cancelled" "quit / exit abort")))
			(princ (strcat "\nError: " msg))
		(setvar 'cmdecho 1)
		(princ)
	(defun LM:intersections ( ob1 ob2 mod / lst rtn )
		(if (and (vlax-method-applicable-p ob1 'intersectwith)
				 (vlax-method-applicable-p ob2 'intersectwith)
				 (setq lst (vlax-invoke ob1 'intersectwith ob2 mod))
			(repeat (/ (length lst) 3)
				(setq rtn (cons (list (car lst) (cadr lst) (caddr lst)) rtn)
					  lst (cdddr lst)
		(reverse rtn)
	(setvar 'cmdecho 0)
	(setq
		a1 (car(entsel "\nSelect first tangent line >"))
		a2 (car(entsel "\nSelect second tangent line >"))
		a3 (car (entsel "\nSelect third tangent line >"))
	(cond
		((and a1 a2 a3)
			(mapcar 'set '(e1 e2 e3) (mapcar 'vlax-ename->vla-object (list a1 a2 a3)))
			(setq
				p1 (car(LM:intersections e1 e2 acextendnone))
				p2 (car(LM:intersections e2 e3 acextendnone))
				p3 (car(LM:intersections e3 e1 acextendnone))
				a (distance p1 p2)
				b (distance p2 p3)
				c (distance p3 p1)
				s (* 0.5 (+ a b c))
				r (sqrt (/ (* (- s a)(- s b)(- s c)) s))
			(command "_.xline" "B" p1 p2 p3 "")
			(setq a1 (entlast))
			(setq e1 (vlax-ename->vla-object (entlast)))
			(command "_.xline" "B" p2 p1 p3 "")
			(setq a2 (entlast))
			(setq e2 (vlax-ename->vla-object (entlast)))
			(setq cp (car(LM:intersections e1 e2 acextendnone)))
			(command "_.circle" cp r)
			(command "_.erase" a1 a2 "")
	(setvar 'cmdecho 1)
	(princ)
Miljenko Hatlak
Message 17 of 49
Lukasvop1
Thank you, absolutely not a problem.
Message 18 of 49
Lukasvop1
Can you also check lisps :
They're explained in video.
Message 19 of 49
ВeekeeCZ
I think you scared the hell out of him so he marked your reply just to please your eyes. There's no way this would work.
Message 20 of 49
Lukasvop1
Nope, I just appreciate his work and effort.
I know how's feel when you work for someone try do it best you know and he doesn't care..
