fatal error on opening autocad if bundle installed under %ProgramFiles% folder
gang
gang
We created our AutoCAD 2018 add-on.
If we put our bundle under "C:\ProgramData\Autodesk\ApplicationPlugins\" folder, our add-on can be loaded in AutoCAD but the security warning - unknown publisher will show up.
If we put our bundle under "C:\Program Files\Autodesk\ApplicationPlugins\" folder, the fatal error shows up saying unhandled access violation reading 0x0658 Exception at ecec6447h.
Interesting thing is if we put our bundle under %ProgramData% folder first and load AutoCAD with our Add-on loaded. Then quit AutoCAD, copy our bundle under %ProgramFiles% folder and reload AutoCAD again. The fatal error is gone.
Since installing bundle under %ProgramData% folder needs users change setting to add the path to the trustedpath, we would like to install it under %ProgramFiles% folder, but the fatal error shows up.
Any suggestions on this issue?
Thanks in advance.
Best,
Gang
Alfred.NESWADBA
As the error does not appear when you run the startup in another way I would look into your applications initialize part, if files are written or registry settings are tried without enough permissions?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
gang
- alfred -
Thank you, Alfred.
If that's the case, do you know how we should change permission so that this won't be an issue?
Thanks again.
Best,
Gang
Alfred.NESWADBA
Without seeing what you are doing in the initialize part?
Sorry, not possible. How should I correct a code that I have not written and don't see ...?
- alfred -
Alfred NESWADBA
Mark.Lancaster
@gang
Adding to @Alfred.NESWADBA information.
This is not an Autodesk installation and licensing issue.  This is based on an add-on you wrote..   In the end it would not be supported here and you should be using the AutoCAD Customization forum for this.   I will have the moderator relocate your posting there.
https://forums.autodesk.com/t5/visual-basic-customization/bd-p/33
Mark Lancaster
gang
I didn't see my post is relocated to that forum. I will repost it there.
