false ceiling routine
dani-perez
dani-perez
Hello all,
I have this issue. I need to draw false ceiling of many rooms. Some of them are square-shape and others are irregular-shape. Is it possible this routine? I draw a pline (boundary of room including edges, pillars, etc) and it is filled with a square net of 60x60 (or other dimensions, 30x45, 20x30 etc) but I need a tolerance from the limits of pline. I mean, at least 30cm free from the pline in all directions (30 cm free, or 20 cm free or, between 20 or 30 for example. I need complete net of course of 60x60 or the dimension specified.
Thanks in advance
Kent1Cooper
Your example drawing does not show anything about what you intend for the "tolerance from the limits."  I can imagine what that might mean for a rectangle, but I'm not sure what you mean by it in a boundary with eges running at different angles.  Can you just OFFSET the perimeter, and Hatch the Offset result?
Your drawing uses two User-defined Hatch patterns at perpendicular angles.  Are you aware that for a square grid, you can do it with just one, if you set it to be Double-direction in the Properties palette or the Properties pull-down in the ribbon's Hatch editor [or simply when drawing it in the first place]?  For your non-square tile sizes, you can do two patterns like that, or it's not difficult to define Hatch patterns that have the proportions you want in a single pattern definition [I have some for (US Imperial) 24x48 tile size, with either single- or double-line grids].
Kent Cooper, AIA
Sea-Haven
If you just want to show a 60x60 pattern just use NET hatch with a scale. It is possible to move the hatch origin so have a corner start point.
