Assigning automatically lines to different layers
rdellorcoVW4WC
rdellorcoVW4WC
I am aware this is an old question and I know there is a lisp called layer director (http://www.lee-mac.com/layerdirector.html) or flay (https://apps.autodesk.com/ACD/fr/Detail/Index?id=7021100717958412164&appLang=en&os=Win32_64) that are super tools. But I'm'wondering if is it possible to assign a different layer to different polylines, maybe having a command for every line: for exemple pl1 will draw a polyline on layer 1 and pl2 a polyline on layer 2.
Does this exist or is it possible? I don't know how to write LISP.
Thank you for your help.
Kent1Cooper
I could easily whip something up, but I suggest you start learning to write AutoLisp routines, since this would be a very basic and easy introduction.  Each command definition with (defun) would involve either a (command) or a (setvar) function to set the correct Layer, and a (command) function to start the PLINE command, and could then just terminate and leave you in that command.
Start with that kind of operation, and then if you want to get more sophisticated, you can look at adjusting it to do things like ensure the Layer exists, save the current Layer first and reset that when you're done, draw on the current Layer and change what you've drawn to the desired one, or other approaches.
Kent Cooper, AIA
cadffm
use the TOOLPALETTE feature (and if you run such a tool you linked too parallel, check about possible problems between / untested).
Sebastian
rdellorcoVW4WC
That's nice.'It can be a workaround before I learn Autolisp.
By the way can you assign a key shortcut to the command of the palette?
Sea-Haven
An extra to the suggestion by Kent before adding a pline, check what was last PLINEX layer created, this way you can close dwg and go to lunch, then open and continue on.
Just a comment not sure how many layers your going to be left with, how many plines involved ?
