Extract insertion point of existing Mtext
The fourth line-  Need to use the Mtext that is in my selection set, ss1, rather than prompt the user. This program is a snippet of one that will delete an existing Mtext and insert a new Mtext using a notepad file(already have that figured out). I think the selection set needs to be converted to a list that VLA can understand. I've tried modifying some examples with no luck. The circle is just for me to verify that the program is extracting the insertion point.
(defun c:ptTest (/ ss1 mtext mobj base)
(setq ss1 (ssget "_C" '(86 342) '(-11 303) '((0 . "mtext"))))
(vl-load-com)
(setq mtext (car (entsel "\Select mtext:")))
(setq mobj (vlax-ename->vla-object mtext))
(setq base (vlax-safearray->list (vlax-variant-value (vlax-get-property mobj 'insertionpoint))))
(command "circle" base "2")
CodeDing
@Anonymous ,
Assuming your selection set will only consist of 1 MTEXT object, then this should work:
(defun c:ptTest ( / ss1 mtext base osm)
(if (setq ss1 (ssget "_C" '(86 342) '(-11 303) '((0 . "mtext"))))
  (progn
    (setq mtext (ssname ss1 0))
    (setq base (cdr (assoc 10 (entget mtext))))
    (setq osm (getvar 'OSMODE)) (setvar 'OSMODE (logior 16384 osm))
    (setvar 'OSMODE osm)
  );progn
  (prompt "\nNo MTEXT found...")
);if
(princ)
);defun
If it ever will contain more than 1 then you would need to loop through the selection set...
Best,
~DD
Kent1Cooper
The simple answer is to replace this:
with this:
(setq mtext (ssname ss1 0)); get the first entity name out of the selection set
and you should be able to keep the rest.  @CodeDing suggested a simpler way to get the insertion point, but in their Circle-drawing part, I would not bother saving and changing and resetting the OSMODE setting, but rather would simply add a "none" Osnap call before giving it the base point for the Circle's center:
(command "circle" "_none" base 2)
[and the 2 can be just a number -- it doesn't need quotation marks to make it a text string].
Kent Cooper, AIA
Perfect!
Thanks for the help.
Hey Ken. That works too. Thanks for the additional info.
