Extract from text string to attribute values.
Message 1 of 24
I am trying to search a single text string and extract values to "paste" into attribute values in a block.
Text string example: "PoleNumber=3-146592$Owner=APCO$Attachment1=57'-4"
Is it possible to search out PoleNumber=, retrieve the 3-146592 and populate an attribute value for PoleNumber based on each search criteria? As in, then search for Owner= and populate attribute Owner with APCO?
I feel like this is possible but have no idea how to begin to achieve this. Any help would be greatly appreciated.
Replies (23)
Message 2 of 24
dlanorh
Are all the values in the same text string, and is this Text or MText?
Do the text values all go into the same block?
Is it always the same named block?
Is the block already inserted into the drawing or does the lisp need to do this?
Do you require the Text/Mtext deleting once the values are transfered?
It would be easier if you posted a drawing containing the block and the text string for testing purposes. AutoCAD 2010 for me which would also be accessable for others.
I am not one of the robots you're looking for
Message 3 of 24
Moshe-A
@Anonymous  hi,
check (get-kword-value) function...can you handle attributes setting on your own?
moshe
(defun c:test (/ get-kword-value ; local function
	         data_text)
 (defun get-kword-value (text kword / p0 p1 p2)
  (if (and
	(setq p0 (vl-string-search (strcase (strcat "$" kword)) (strcase text)))
        (setq p1 (vl-string-position (ascii "=") (substr text (1+ p0))))
   (if (not (setq p2 (vl-string-position (ascii "$") (substr text (+ 1 p1 p0)))))
    (substr text (+ 2 p0 p1))
    (substr text (+ 2 p0 p1) (- (+ p0 p1 p2) (+ p0 p1) 1))
   ); if
  ); if
 ); get-kword-value
 (setq data_text "$PoleNumber=3-146592$Owner=APCO$Attachment1=57'-4")
 (foreach kword '("PoleNumber" "Owner" "Attachment1")
  (terpri)
  (princ (get-kword-value data_text kword))
 (princ)
); c:test
Message 4 of 24
The values are in one continuous string of text, not Mtext. All values will be transferred into the same block and will be named the same. I had assumed to insert the block and position it near the text and select the origin (text), then select the block for the lisp to fill in the attributes. The text will remain after extraction and need no deletion. I currently don't have the block built, just more in the stages of "is this possible" at the moment.
Message 5 of 24
Moshe-A
@Anonymous ,
Attach the complete solution. i defined a block blktag + 3 attributes:
PoleNumber, Owner, Attachment1
this means the format of the text(s) you select must have these key words otherwise it won't work
enjoy
moshe
	         savAttDia savAttReq ss ename1 elist data_text value)
  (if (and
   ); if
  ); if
 ); get-kword-value
 (setvar "cmdecho" 0)
 (command "._undo" "_begin")
 (if (setq ss (ssget '((0 . "text"))))
  (progn
   (setq savAttDia (getvar "attdia"))
   (setvar "attdia" 0)
   (setq savAttReq (getvar "attreq"))
   (setvar "attreq" 0)
   (foreach ename0 (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))
    (setq elist (entget ename0))
    (setq data_text (cdr (assoc '1 elist)))
    (command-s "._insert" "blktag")
    (setq ename1 (entlast))
     (if (/= (setq value (get-kword-value data_text kword)) "")
      (setpropertyvalue ename1 kword value)
    ); foreach
   ); foreach
   (setvar "attreq" savAttReq)
   (setvar "attdia" savAttDia)
  ); progn
 ); if
 (command "._undo" "_end")
 (princ)
); c:test
Message 6 of 24
I get ; error: ADS request error once I click on the text string.
Message 7 of 24
Moshe-A
@Anonymous ,
work prefect for me, note that the text value must start with "$PoleNumber=...."
can you post a sample dwg?
Message 8 of 24
dlanorh
It is eminently possible, and would probably be easiest to select the text, then insert the block with the attributes filled. I would suggest setting the attributes to preset value wise.
Message 9 of 24
Here is the drawing I'm testing in.
Message 10 of 24
Moshe-A
@Anonymous ,
On message #5 i also attached blktag.dwg did you use it? guess not!
the lisp was design to use this block (only because you did not provide something else before) so you can not expect it will work with POLE_ID_BLOCK?!
when prompt for select object(s) you should select only the text than the program will let you insert your block and assign the attributes.
i'm sending a fix to support POLE_ID_BLOCK as default block name but if you like another name, just set USERS1 (sysvar) with another default block name.
enjoy
moshe
	         bname savAttDia savAttReq ss ename1 elist data_text value)
  (if (and
   ); if
  ); if
 ); get-kword-value
 ; initialize
 (if (eq (getvar "users1") "")
  (setq bname (setvar "users1" "pole_id_block"))
  (setq bname (getvar "users1"))
  (progn
   (setvar "attdia" 0)
   (setvar "attreq" 0)
    (command-s "._insert" bname)
    ); foreach
   ); foreach
  ); progn
 ); if
 (princ)
); c:test
Message 11 of 24
I must have overlooked where you had attached that file. I see it now. I did however replace in the lisp the POLE_ID_BLOCK instead of where you had blktag listed. Granted there could've been somewhere else that I missed something when I replaced it. And when I tested it I did only select the text first and it would give me the error before it got to the point of inserting the block.
Let me check this one out and get back with you.
Message 12 of 24
Moshe-A
@Anonymous ,
of course there is a possibility that you insert POLE_ID_BLOCK in advance and let lisp to select text + blockref
from where this text is coming? (you do not add it manually?)
does the key words (PoleNumber,Owner,Attachment1) fixed? only what comes after equality sign varies?
moshe
Message 13 of 24
The text is being imported from a GPS Unit. Shots are taken with these "attributes" filled out and the only way to bring them in to Autocad is a continuous text string per shot. So each shot will contain a string of text that has to same fields, i.e. PoleNumber, Owner, Attachment1 as well as multiple other entries. The input after "=" is the information entered from the field. So basically trying to take the raw data and make it more presentable in Autocad.
Message 14 of 24
Moshe-A
@Anonymous ,
OK, please close this thread and mark this as your solution.
Moshe
Message 15 of 24
Moshe-A
@Anonymous ,
mark this as your solution please
Message 16 of 24
I can't mark this as solution when it's not my solution. I still receive "; error: ADS request error" as I have every time I've tried any of these routines, regardless of what I do.
Message 17 of 24
Now I'm getting "Point or option keyword required. ; error: Function cancelled"
Message 18 of 24
Moshe-A
@Anonymous ,
post a sample dwg so i can see it.
Message 19 of 24
It's the same DWG that I attached previously in Message 9.
Message 20 of 24
dlanorh
Try the attached. Type T2A on the commandline once loaded.
If it errors it may be your setup. Unfortunately I cannot test it on your drawing as I require AutoCAD 2010.
