Extract block information from mutlileader
christian_paulsen98V29
Message 1 of 38
So right now i have a lisp that takes all of my keynotes in my drawing, and inserts their information into my title block.
The only issue is that the keynote block and the Mleader have to be separate objects in order for this to work. Instead of making a multileader style with the block connected to the leader. This creates issues where sometimes people are moving the block without the leader, or moving the leader without the block. Or when you want to move them it now requires two steps instead of 1. So I'm trying to fix that issue by creating a Mleader style with the block connected, then extracting the information from there.
This chunk of code I'm posting is part of a much much larger lisp routine that connects with all kinds of other dlls and stuff. However I'm pretty sure this line right here is the root of the problem. Originally it only looked for block references but then i added the "or" condition to also look for Mleaders. The only issue is that im pretty sure its looking for the attributes of the Mleader, and not the attributes of the block connected to the Mleader.
(if (and (or (= (vlax-get-property G-OBJ "ObjectName") "AcDbBlockReference")
(= (vlax-get-property G-OBJ "ObjectName") "AcDbLeader"))
I know this is a tough one but any help would be greatly appreciated. I've got very limited knowledge and have been working on this for days.
;;;  Subfunction: CPKS-GET-SYMBOLS                                    ;
;;;  Description: This function returns a sorted list of all keynote   ;
;;;               symbols in all spaces of current drawing including   ;
;;;               xrefs and binded blocks.                             ;
(defun CPKS-GET-SYMBOLS (/           G-SS        G-SYM       G-TAG       G-STRLEN
                          G-STRVAL    G-OBJ       G-ATTR      G-I         G-LST-SYM
                          G-ARR-ATTR  G-OBJ-BLKS  G-XREFDB    G-XREFDB-MS G-NAME
                          G-LST-BADFAB            G-BADFAB    G-PART      G-SYM-PART
  ;; Process Symbols in current space ;
  (if (setq G-SS
             (ssget
               "x"
               (list
                 '(0 . "INSERT")
                 '(2
                   "*PNT,*MAT,*ALUM,*STEEL,*ELEC,*FAB,*HDWE,*FABTEXT,*CP_KNMAT,*CP_KNPNT,*CP_KNHDW,*CP_KNELC,*CP_KNALM,*CP_KNSTL,*CP_KNFAB,*CP_KNFAB2,*CP_KNFAB3,*CP_KNPAR,*CP_KNPAR2,*CP_KNPAR3,*CP_KNREV,*CP_FTAG,*CP_FABTAG,*CP_FABTAG-S,*CP_FABTAG-XS,*CP_FABTAG-L,*CP_FABTAG-XL,*CP_PARTAG,*CP_PARTAG-S,*CP_PARTAG-XS,*CP_PARTAG-L,*CP_PARTAG-XL"
    (while (> (sslength G-SS) 0)
      (setq G-OBJ (vlax-ename->vla-object (ssname G-SS 0)))
               (= (vlax-get-property G-OBJ "HasAttributes") :vlax-true)
               (setq
                 G-ARR-ATTR (vlax-safearray->list (vlax-variant-value (vla-getattributes G-OBJ)))
        (progn
          (foreach G-ATTR G-ARR-ATTR
            (setq G-TAG    (strcase (vlax-get-property G-ATTR "TagString"))
                  G-STRLEN (strlen (vlax-get-property G-ATTR "TextString"))
                  G-STRVAL (vlax-get-property G-ATTR "TextString")
                  G-SYM    NIL
            (cond
              ((member G-TAG (list "FAB" "FABNUM")) (setq G-SYM (strcase G-STRVAL)))
              ((= G-TAG "FABNO")
                     G-SYM-PART G-SYM
              ((= G-TAG "PART") (setq G-PART (strcase G-STRVAL)))
              ((member G-TAG (list "F" "KNF"))
               (setq G-SYM      (strcat "F-"
                                        (cond ((= G-STRLEN 3) (substr G-STRVAL 1))
                                              ((= G-STRLEN 2) (strcat "0" (substr G-STRVAL 1)))
                                              ((= G-STRLEN 1) (strcat "00" (substr G-STRVAL 1)))
                                              (t (substr G-STRVAL (- G-STRLEN 2)))
                     G-SYM-PART G-SYM
               (if (and (not (member G-STRLEN '(5 3))) (not (member G-STRVAL G-LST-BADFAB)))
                 (setq G-LST-BADFAB (append G-LST-BADFAB (list G-STRVAL)))
              ((member
                 G-TAG
                 (list "M" "P" "H" "E" "A" "S" "R" "PNT" "MAT" "ALUM" "STEEL" "ELEC" "HDWE")
               (setq G-SYM (strcat (substr G-TAG 1 1) G-STRVAL))
              ((member G-TAG (list "KNP" "KNM" "KNH" "KNE" "KNA" "KNS"))
               (setq G-SYM (strcat (substr G-TAG 3 1) G-STRVAL))
            (if (and G-SYM (not (member G-SYM G-LST-SYM)))
              (setq G-LST-SYM (append (list G-SYM) G-LST-SYM))
          (if (and G-PART G-SYM-PART (not (assoc G-SYM-PART G_LST-PARTS)))
            (setq G_LST-PARTS (append G_LST-PARTS (list (cons G-SYM-PART G-PART))))
          (setq G-SYM-PART NIL
                G-PART NIL
      (ssdel (ssname G-SS 0) G-SS)
Replies (37)
Message 21 of 38
DIDNT REALIZE THIS POST WAS PUT ON A SECOND PAGE, SO I ACCIDENTALLY POSTED IT TWICE. THERES NO DELETE BUTTON SO I APOLOGIZE.
This is correct.
Like i said this code is part of a much larger set of code. I thought i extracted the part that is pulling all of the block references. Ill post the larger code but just beware it is a lot. And this isnt even the whole thing. Theres other lisp files connected to this one that also influence how it work
code removed because of accidental duplicate post.
Message 22 of 38
This is correct. Like i said this small snippet of code is part of a much larger file. I thought i extracted the part of the code that counts all of the block usages but there must be another part that is counting from the xrefs. Ill post the larger code. Just beware it is a lot of code. And this isnt even all of it, there are other lisp files that this code interacts with that have an influence on it as well.
;;;  Function: CP-KS                             Copyright © CP 2002 ;
;;;  Written by ANON                                             ;
;;;  Description:  This function handles all Key Schedules tasks.      ;
(defun CP-KS (G-MODE         /              G-SS           G_LST-SS       G_LST-SYM
               G_LST-SUM      G_LST-SEM      G_LST-FABCNT   G_FILE-ID      G_PATH
               G-TB-DATA      G-TB-NM        G-TB-IPT       G-TB-SCALE     G-TB-VER
               G-TB-PTS       G_CDWG         G_CSER         G_CSHT         G_SPEC-MAT
               G_SPEC-PNT     G_SPEC-HDW     G_SPEC-ELC     G_SPEC-ALM     G_SPEC-STL
               G_SPEC-REV     G_CLI-NAME     G_CLI-CODE     G_PRG-NAME     G_PRG-CODE
               G_PRJ-NUM      G_ELM-NAME     G_ELM-CODE     G_INDX         G_DICT
               G_ATTR-MISS    G_ELM-QTY      G_LST-PARTS    G_SURVEYSC     G_SURVEYIPT
               G_TB-SCF       G-TB-KS-MAXHT  G_IPT-L        G-TB-KS-MAXHT-REAL
               G-TB-IPT-REAL  G_SQUEEZE-FACTOR              G_MISSING-INFO
  ;; Call the GETKEYNOTEFILES added to pull files from Vault. Calls command in AutoCADConnect.dll
  (command "GETKEYNOTEFILES")
  (CPF-ERR-ON)
  (CPF-VSAVE (list "clayer" "osmode" "cmdecho" "attreq" "attdia" "textstyle"))
  (setvar "cmdecho" 0)
  (setvar "osmode" 0)
  (setvar "attreq" 1)
  (setvar "attdia" 0)
  (prompt "\n   *** Processing Kenoting Schedules... \n")
  (if (and (= (getvar "dwgtitled") 1)
           (setq G_LST-SS (CPKS-GET-SHEETS))
           (setq G_PATH (CPF-PROJECT-PATH))
           (setq G_FILE-ID (CPF-FILE-ID NIL))
    (progn
      ;; collect information ;
      ;; Expanded scan to include additional versions of keynote blocks (DF 03-24-20)
      (if (setq G-SS (ssget "_x"
                            (list
                              '(0 . "INSERT")
                              '(-4 . "<or")
                              '(2 . "pntmast*,pnttitl*")
                              '(2 . "matmast*,mattitl*")
                              '(2 . "hdwmast*,hdwtitl*")
                              '(2 . "elecmast*,electitl*")
                              '(2 . "mtlmast*,mtltitl*")
                              '(2 . "fabmast*,fabtitl*")
                              '(2 . "revmast*,revtitl*")
                              '(2 . "CP_kspnt-t*,CP_kspnt-m*,CP_kspnt-mx*")
                              '(2 . "CP_ksmat-t*,CP_ksmat-m*,CP_ksmat-mx*")
                              '(2 . "CP_kshdw-t*,CP_kshdw-m*,CP_kshdw-mx*")
                              '(2 . "CP_kselc-t*,CP_kselc-m*,CP_kselc-mx*")
                              '(2 . "CP_ksmet-t*,CP_ksmet-m*,CP_ksmet-mx*")
                              '(2 . "CP_ksfab-t*,CP_ksfab-m*,CP_ksfab-mx*")
                              '(2 . "CP_ksftl-t*,CP_ksftl-m*,CP_ksmiss*")
                              '(2 . "CP_ksrev-t*,CP_ksrev-m*,CP_ksrev-mx*")
                              '(2 . "CP_ksrev-t2*")
                              '(2 . "CP_ksrt*")
                              '(-4 . "or>")
        (progn
          (if (member (car G_FILE-ID) '("FAB" "DTL"))
            (CPKS-SURVEY)
          (vl-cmdf ".erase" G-SS "")
          (vl-cmdf
            "-purge"
            "_b"
            "pntmast*,pnttitl*,matmast*,mattitl*,hdwmast*,hdwtitl*,elecmast*,electitl*,mtlmast*,mtltitl*,fabmast*,fabtitl*,revmast*,revtitl*,CP_kspnt-t*,CP_kspnt-m*,CP_kspnt-mx*,CP_ksmat-t*,CP_ksmat-m*,CP_ksmat-mx*,CP_kshdw-t*,CP_kshdw-m*,CP_kshdw-mx*,CP_kselc-t*,CP_kselc-m*,CP_kselc-mx*,CP_ksmet-t*,CP_ksmet-m*,CP_ksmet-mx*,CP_ksfab-t*,CP_ksfab-m*,CP_ksfab-mx*,CP_ksftl-t*,CP_ksftl-m*,CP_ksmiss*,CP_ksrev-t*,CP_ksrev-m*,CP_ksrev-mx*,CP_ksrev-t2*,CP_ksrt*"
            "_n"
          (if
            (not (ssget "x"
                        (list '(0 . "INSERT") (cons 410 (getvar "ctab")) '(2 . "CP_kslock-ec*"))
             (progn (setq G-SS (ssget "_x"
                                            '(-4 . "<or")
                                            '(2 . "CP_ksstn-t*,CP_ksstn-m*,CP_ksstn-b*")
                                            '(-4 . "or>")
                    (vl-cmdf "-purge" "_b" "CP_ksstn-t*,CP_ksstn-m*,CP_ksstn-b*" "_n")
      (if (member (setq G_CDWG (nth 0 G_FILE-ID)) '("SHT" "DTL" "FAB"))
        (progn (if (nth 2 G_FILE-ID)
                 (setq G_CSER (vl-string-left-trim "0" (nth 2 G_FILE-ID)))
               (if (nth 3 G_FILE-ID)
                 (setq G_CSHT (vl-string-left-trim "0" (nth 3 G_FILE-ID)))
               (setq G_DICT (CPF-DICT "CP" NIL))
               (if (not (setq G_CLI-NAME (cdr (assoc "DB_CLIENT_NAME" G_DICT))))
                 (if (not (setq G_CLI-NAME (nth 0 G_PATH)))
                   (setq G_CLI-NAME "Unknown")
               (if (not (setq G_CLI-CODE (cdr (assoc "DB_CLIENT_CODE" G_DICT))))
                 (setq G_CLI-CODE "")
                 (setq G_CLI-CODE (strcat G_CLI-CODE " - "))
               (if (not (setq G_PRG-NAME (cdr (assoc "DB_PROGRAM_NAME" G_DICT))))
                 (if (not (setq G_PRG-NAME (nth 1 G_PATH)))
                   (setq G_PRG-NAME "Unknown")
               (if (not (setq G_PRG-CODE (cdr (assoc "DB_PROGRAM_CODE" G_DICT))))
                 (setq G_PRG-CODE "")
                 (setq G_PRG-CODE (strcat G_PRG-CODE " - "))
               (if (not (setq G_PRJ-NUM (cdr (assoc "DB_PROJECT_NO" G_DICT))))
                 (setq G_PRJ-NUM (cdr (assoc "DB_PROJECT_CODE" G_DICT)))
               (if (not (setq G_ELM-NAME (cdr (assoc "DB_ELEMENT_NAME" G_DICT))))
                 (setq G_ELM-NAME "****")
               (setq G_ELM-CODE (cdr (assoc "DB_ELEMENT_CODE" G_DICT)))
               (setq G_ELM-QTY (cdr (assoc "DB_QTY" G_DICT)))
        (setq G_CDWG NIL)
      (setq G_INDX    10
            G_LST-SEM (CPKS-GET-SEM)
            G_LST-SYM (CPKS-GET-SYMBOLS)
            G_LST-SUM (CPKS-GET-SUMMARY)
      ;; create summary file ("Project_number.sum"), if applicable;
      (CPKS-DO-SUMMARY)
      ;; insert keynotes revisions and stenciling shedules;
      (CPKS-DO-INSERTS)
      (if G_MISSING-INFO
        (progn (if (setq G-SS (ssget "_x"
                                     (list
                                       '(0 . "INSERT")
                                       '(-4 . "<or")
                                       '(2 . "CP_ksrt*")
                                       '(-4 . "or>")
               (CPKS-DO-INSERTS)
    (cond ((= (getvar "dwgtitled") 0)
           (setq G-LST-MSG (append G-LST-MSG
                                   (list "   **** CANNOT USE \"KS\" IN UNNAMED DRAWING! ****")
          ((not G_LST-SS)
           (setq
                               (list "   **** UNABLE TO FIND ANY SHEETS IN CURRENT FOLDER! ****")
          ((not G_FILE-ID)
                                   (list "   ***** UNABLE TO DETERMINE THE TYPE OF DRAWING! ****")
          ((not G_PATH)
                                   (list "   **** UNABLE TO FIND SPECIFICATION LIST FILES! ****")
          (t
           (setq G-LST-MSG
                  (append G-LST-MSG (list "   **** UNKNOWN ERROR - UNABLE TO CONTINUE! ****"))
  (CPF-ERR-OFF)
  (CPF-VBACK NIL)
  (foreach G-I G-LST-MSG (prompt "\n") (CPF-BLINK G-I 6))
  (princ "\n   *** Keynoting Schedules Completed.\n")
  (princ)
;;;  Subfunction: CPKS-GET-SHEETS                                     ;
;;;  Description: This function returns a sorted list of all sheet     ;
;;;               series (G-MODE = T) or a sorted list of all sheets   ;
;;;               in current directory in asscending order.            ;
;;;               I.e.                                                 ;
;;;               ("1" "2" "3" ...) - all sheet series                 ;
;;;               ("1A" "1B" "1C" "2A" "2B" "3A" ...) - all sheets     ;
(defun CPKS-GET-SHEETS (/ G-LST-SER G-LST-SHT G-ID G-SHT G-DWG)
  (foreach G-DWG (vl-directory-files (getvar "dwgprefix") "*.dwg" 1)
    (cond
      ((member (car (setq G-ID (CPF-FILE-ID G-DWG))) '("SHT"))
       (if (and (not (member (setq G-SHT (vl-string-left-trim "0" (caddr G-ID))) G-LST-SER))
                (/= G-SHT "")
         (setq G-LST-SER (append (list G-SHT) G-LST-SER))
       (if (and (not (member (setq G-SHT (vl-string-left-trim "0" (cadddr G-ID))) G-LST-SHT))
                (/= G-SHT "")
                (< 47 (ascii (substr G-SHT 1 1)) 58)
         (setq G-LST-SHT (append (list G-SHT) G-LST-SHT))
  (setq G-LST-SER (vl-sort G-LST-SER (function (lambda (I1 I2) (< (atoi I1) (atoi I2)))))
        G-LST-SHT (vl-sort G-LST-SHT
                           (function (lambda (I1 I2) (< (CPKS-SHT2NUM I1) (CPKS-SHT2NUM I2))))
  (append (list (list "SERIES" G-LST-SER)) (list (list "SHEETS" G-LST-SHT)))
;;;  Subfunction: CPKS-SHT2NUM                                        ;
;;;  Description: This function breaks down sheet number into single   ;
;;;               characters, converts these to ascii code and bind    ;
;;;               them together to create unique integer for sorting   ;
;;;               purpose. I.e. "10B" -> 494866                        ;
(defun CPKS-SHT2NUM (G-NUM / G-STR G-SUF G-PREF G-PREF-LG)
  (foreach G-I (vl-string->list G-NUM)
    (cond ((< 47 G-I 58)
           (if G-PREF
             (setq G-PREF (strcat G-PREF (chr G-I)))
             (setq G-PREF (chr G-I))
          (t
           (setq G-I (- G-I 64))
           (if G-SUF
             (setq G-SUF (+ G-SUF G-I))
             (setq G-SUF G-I)
  (setq G-PREF-LG (strlen G-PREF))
  (while (< (strlen G-PREF) (+ 2 G-PREF-LG)) (setq G-PREF (strcat G-PREF "0")))
  (setq G-STR (+ (atoi G-PREF)
                 (if G-SUF
                   G-SUF
                   0
  G-STR
  (if (setq G-SS
             (ssget
               "x"
               (list
		 '(-4 . "<or")
		 '(-4 . "<and")
		 '(0 . "INSERT")
                 '(2
		 '(-4 . "and>")
		 '(0 . "MULTILEADER")
		 '(-4 . "or>")
      (if (or
		(and (= (vlax-get-property G-OBJ "ObjectName") "AcDbBlockReference")
		     (setq G-ARR-ATTR (vlax-safearray->list (vlax-variant-value (vla-getattributes G-OBJ))))
		(and (= "AcDbMLeader" (vla-get-objectname G-OBJ))
		     (/= "" (setq ml_block_name (vla-get-contentblockName G-OBJ)))
		     (null (setq G-ARR-ATTR nil))
		     (vlax-map-collection (vla-item (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))) ml_block_name)
		       	'(lambda (object) (if (= (vla-get-objectname object) "AcDbAttributeDefinition") (setq G-ARR-ATTR (append G-ARR-ATTR (list object)))))
        (progn
	    (if (= (vlax-get-property G-OBJ "ObjectName") "AcDbBlockReference")
	                  G-SYM    NIL
	                  G-STRLEN (strlen (vla-getblockattributevalue G-OBJ (vla-get-objectid G-ATTR)))
	                  G-STRVAL (vla-getblockattributevalue G-OBJ (vla-get-objectid G-ATTR))
	                  G-SYM    NIL
            (cond
              ((= G-TAG "FABNO")
                     G-SYM-PART G-SYM
                     G-SYM-PART G-SYM
              ((member
                 G-TAG
                G-PART NIL
  ;; Process Symbols in Xrefs ;
  (setq G-OBJ-BLKS (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))))
  (vlax-for G-I G-OBJ-BLKS
    (if (and (= (vlax-get-property G-I "IsXRef") :vlax-true)
             (> (vlax-get-property G-I "Count") 1)
             (setq G-XREFDB (vlax-get-property G-I "XRefDatabase"))
             (setq G-XREFDB-MS (vlax-get-property G-XREFDB "ModelSpace"))
      (progn
        (vlax-for G-OBJ G-XREFDB-MS
          (if
            (and
              (setq G-NAME (vlax-get-property G-OBJ "Name"))
              (or
                (member (strcase (substr G-NAME
                                         (+ 2
                                            (cond ((vl-string-position (ascii "|") G-NAME 1 t))
                                                  (t -1)
                        '("PNT"            "MAT"            "ALUM"           "STEEL"
                          "ELEC"           "FAB"            "HDWE"           "FABTEXT"
                          "CP_KNMAT"      "CP_KNPNT"      "CP_KNHDW"      "CP_KNELC"
                          "CP_KNALM"      "CP_KNSTL"      "CP_KNFAB"      "CP_KNFAB2"
                          "CP_KNFAB3"     "CP_KNPAR"      "CP_KNPAR2"     "CP_KNPAR3"
                          "CP_FTAG"       "CP_FABTAG"     "CP_FABTAG-S"   "CP_FABTAG-XS"
                          "CP_FABTAG-L"   "CP_FABTAG-XL"  "CP_PARTAG"     "CP_PARTAG-S"
                          "CP_PARTAG-XS"  "CP_PARTAG-L"   "CP_PARTAG-XL"
                (wcmatch
                  (strcase (vlax-get-property G-OBJ "Name"))
                  "*PNT,*MAT,*ALUM,*STEEL,*ELEC,*FAB,*HDWE,*FABTEXT,*CP_KNMAT,*CP_KNPNT,*CP_KNHDW,*CP_KNELC,*CP_KNALM,*CP_KNSTL,*CP_KNFAB2,*CP_KNFAB3,*CP_KNPAR2,*CP_KNPAR3,*CP_KNPAR,*CP_KNFAB,*CP_FTAG,*CP_FABTAG,*CP_FABTAG-S,*CP_FABTAG-XS,*CP_FABTAG-L,*CP_FABTAG-XL,*CP_PARTAG,*CP_PARTAG-S,*CP_PARTAG-XS,*CP_PARTAG-L,*CP_PARTAG-XL"
              (setq G-ARR-ATTR
             (progn
                       G-SYM    NIL
                 (cond
                   ((= G-TAG "FABNO")
                          G-SYM-PART G-SYM
                    (setq G-SYM
                           (strcat
                             "F-"
                             (cond
                               (t
                                (substr (vlax-get-property G-ATTR "TextString") (- G-STRLEN 2))
                          G-SYM-PART G-SYM
                    (if
                   ((member
                      G-TAG
                      (list "M" "P" "H" "E" "A" "S" "PNT" "MAT" "ALUM" "STEEL" "ELEC" "HDWE")
                     G-PART NIL
  ;; Process Symbols in Binded (as Inserts) Xrefs;
  (if (and (setq
             G-SS (ssget "x" (list '(0 . "INSERT") '(2 . "DTL*,FAB*") (cons '410 (getvar "CTAB"))))
      (if
        (and
            (logand (cdr (assoc 70 (tblsearch "block" (cdr (assoc 2 (entget (ssname G-SS 0)))))))
                    4
            4
          (setq G-NAME (cdr (assoc 2 (entget (ssname G-SS 0)))))
          (setq G-OBJ-BLK (vla-item G-OBJ-BLKS G-NAME))
          (setq G-CNT  (vlax-get-property G-OBJ-BLK "Count")
                G-ITEM 0
         (while (< G-ITEM G-CNT)
           (setq G-OBJ  (vla-item G-OBJ-BLK G-ITEM)
                 G-ITEM (1+ G-ITEM)
           (if
             (and
               (setq G-ARR-ATTR
               (wcmatch
              (progn
                        G-SYM    NIL
                  (cond
                    ((= G-TAG "FABNO")
                           G-SYM-PART G-SYM
                     (setq G-SYM
                            (strcat
                              "F-"
                              (cond
                                (t
                           G-SYM-PART G-SYM
                     (if
                    ((member
                       G-TAG
                      G-PART NIL
        (setq G_LST-PARTS (append (list (cons G-SYM-PART G-PART)) G_LST-PARTS))
            G-PART NIL
  (if G-LST-BADFAB
    (foreach G-BADFAB G-LST-BADFAB
      (prompt "\n")
      (CPF-BLINK (strcat "**** Fabrication Tag " G-BADFAB " has incorrect number! ****") 24)
  (if G-OBJ-BLKS
    (vlax-release-object G-OBJ-BLKS)
  (if G-XREFDB
    (vlax-release-object G-XREFDB)
  (if G-XREFDB-MS
    (vlax-release-object G-XREFDB-MS)
  (setq X G_LST-PARTS)
  G-LST-SYM
;;;  Subfunction: CPKS-GET-SUMMARY                                    ;
;;;  Description: This function returns all a list containing all      ;
;;;               information from summary file (.sum) if present.     ;
(defun CPKS-GET-SUMMARY (/ G-LST-SUM G-FILE G-LST G-FILE-ID G-LST-READ)
  (if (and G_CDWG
           G_CSER
           G_CSHT
           G_PRJ-NUM
           G_PRG-NAME
           (caddr G_PATH)
           (setq G-FILE (findfile (strcat (caddr G_PATH) "\\" G_PRJ-NUM ".sum")))
           (setq G-FILE-ID (open G-FILE "r"))
    (progn
      (while (setq G-I (read-line G-FILE-ID)) (setq G-LST-READ (append G-LST-READ (list G-I))))
      (close G-FILE-ID)
      (setq G-LST-SUM (list (cons "CLIENT" (list (car G-LST-READ))))
            G-LST-SUM (append G-LST-SUM (list (cons "PROGRAM" (list (cadr G-LST-READ)))))
            G-LST-SUM (append G-LST-SUM (list (cons "PROJECT" (list (caddr G-LST-READ)))))
      (repeat 3 (setq G-LST-READ (cdr G-LST-READ)))
      (while G-LST-READ
        (setq G-LST-STR (CPF-STR2LST (car G-LST-READ) "|" NIL))
        (cond ((member "ELEMENT NAME>" G-LST-STR)
               (setq
                 G-LST-SUM (append
                             G-LST-SUM
                             (list (cons "ELEMENT NAME" (list (CPF-LST2LST G-LST-STR G_INDX))))
              ((member "UNITS>" G-LST-STR)
               (setq
                                   (list (cons "UNITS" (list (CPF-LST2LST G-LST-STR G_INDX))))
              ((member "SHEET SERIES" G-LST-STR)
                     G-LST-SUM  (append
                                  G-LST-SUM
                                  (list (cons "SHEET SERIES" (list (CPF-LST2LST G-LST-STR G_INDX))))
              ((member "SHEETS" G-LST-STR)
                                        (list (cons "SHEETS" (list (CPF-LST2LST G-LST-STR G_INDX))))
              ((= (car G-LST-STR) "Fabrication")
               (setq
                 G-LST-SUM (append (list (list (nth 1 G-LST-STR) (CPF-LST2LST G-LST-STR G_INDX)))
                                   G-LST-SUM
              ((member (car G-LST-STR)
                       '("Paint" "Material" "Hardware" "Electrical" "Aluminum" "Steel")
               (setq G-LST-SUM
                      (append (list (list (strcat (substr (car G-LST-STR) 1 1) (cadr G-LST-STR))
                              G-LST-SUM
  G-LST-SUM
;;;  Subfunction: CPKS-GET-FABCNT                                     ;
;;;  Description: This function returns a list of fab counts from      ;
;;;               *.fab file. It works with the new standard (pipe     ;
;;;               delimited fab spec. file with counts stored in it)   ;
;;;               as well as with legacy files (counts stored in multi-;
;;;               ple *.cnt files located in "Fabcounts" subfolder.    ;
(defun CPKS-GET-FABCNT (/            G-CNT-DIR    G-LST-CNTS   G-LST-SER    G-CNT-SER
                         G-FILE-NM    G-FILE-ID    G-SER        G-I          G-FAB
                         G-CNT        G-ENTRY      G-FAB-ENTRY  G-OLD-ASSO   G-NEW-ASSO
                         G-LST-FABCNT G-SER
  (if G_SPEC-FAB
    (if G*SPEC-PIPE
      ;; retrieve fab counts stored in .fab file (new standard) ;
      (progn (foreach G-I G_SPEC-FAB
               (setq G-FAB (car G-I))
               (if (/= (setq G-CNT (nth 2 G-I)) "")
                 (progn (setq G-LST-CNT NIL)
                        (foreach G-SER (CPF-STR2LST G-CNT "," NIL)
                          (setq G-LST-CNT (append G-LST-CNT (list (CPF-STR2LST G-SER "-" NIL))))
                        (setq G-ENTRY (append (list G-FAB) G-LST-CNT))
                 (setq G-ENTRY (list G-FAB))
               (setq G-LST-FABCNT (append G-LST-FABCNT (list G-ENTRY)))
             (setq G*SPEC-PIPE NIL)
      ;; retrieve fab counts stored in separete .cnt files (old standard) ;
      (if (caddr G_PATH)
        (progn
          (setq G-CNT-DIR  (strcat (caddr G_PATH) "\\Fabcounts")
                G-LST-CNTS (vl-directory-files G-CNT-DIR "*.cnt" 1)
          (mapcar (function (lambda (X)
                              (if (= (strlen X) 1)
                                (setq G-LST-SER (append G-LST-SER (list (strcat "0" X))))
                                (setq G-LST-SER (append G-LST-SER (list X)))
                  (cadr (assoc "SERIES" G_LST-SS))
          (while G-LST-CNTS
            (setq G-CNT-SER (substr (car G-LST-CNTS)
                                    1
                                    (vl-string-position (ascii ".") (car G-LST-CNTS))
            (if (member G-CNT-SER G-LST-SER)
              (progn
                (if (setq G-FILE-NM (strcat (caddr G_PATH) "\\Fabcounts\\" (car G-LST-CNTS)))
                  (progn (setq G-FILE-ID (open G-FILE-NM "r")
                               G-SER     (vl-string-left-trim "0" G-CNT-SER)
                           (if (/= (strcase (vl-string-trim " " G-I)) "NONE")
                             (progn (setq G-FAB (vl-string-trim
                                                  (substr G-I 1 (vl-string-position (ascii " ") G-I))
                                          G-CNT (vl-string-trim
                                                  (substr G-I (+ 2 (vl-string-position (ascii " ") G-I)))
                                    (setq G-ENTRY (list G-SER G-CNT))
                                    (if (not (assoc G-FAB G-LST-FABCNT))
                                      (setq G-FAB-ENTRY  (append (list G-FAB) (list G-ENTRY))
                                            G-LST-FABCNT (append (list G-FAB-ENTRY) G-LST-FABCNT)
                                      (setq G-OLD-ASSO   (assoc G-FAB G-LST-FABCNT)
                                            G-NEW-ASSO   (append G-OLD-ASSO (list G-ENTRY))
                                            G-LST-FABCNT (subst G-NEW-ASSO
        G-LST-FABCNT
                         (close G-FILE-ID)
            (setq G-LST-CNTS (cdr G-LST-CNTS))
  G-LST-FABCNT
;;;  Subfunction: CPKS-LST2STR                                        ;
;;;  Description: This function returns conversion of a list of strings;
;;;               into delimited string.                               ;
;;;               I.e. ("1" "2" "3") -> "1|2|3"                        ;
(defun CPKS-LST2STR (G-LST G-DELIM / G-STR G-I)
  (if (and G-LST G-DELIM (setq G-STR (car G-LST)))
    (foreach G-I (cdr G-LST) (setq G-STR (strcat G-STR G-DELIM G-I)))
  (if G-STR
    G-STR
;;;  Subfunction: CPKS-XPIPES                                         ;
;;;  Description: This function generates string of pipe characters.   ;
;;;               Number of pipes is defined by G-NUM argument.        ;
(defun CPKS-XPIPES (G-NUM / G-STR)
  (setq G-STR "|")
  (repeat (1- G-NUM) (setq G-STR (strcat G-STR "|")))
  G-STR
;;;  Subfunction: CPKS-SYM-VALIDATE                                   ;
;;;  Description: This function returns T if provided symbol (G-STR)   ;
;;;               is a legitimate CP keynote symbol, NIL otherwise.   ;
(defun CPKS-SYM-VALIDATE (G-STR)
  (if (and (member (strcase (substr G-STR 1 1)) '("P" "M" "H" "E" "A" "S"))
           (< 47 (ascii (substr G-STR 2 1)) 58)
           (< 47 (ascii (substr G-STR 3 1)) 58)
           (< (strlen (substr G-STR 2)) 5)
    (setq G-STR t)
    (if (and (= (strcase (substr G-STR 1 2)) "F-")
             (< 47 (ascii (substr G-STR 4 1)) 58)
             (< 47 (ascii (substr G-STR 5 1)) 58)
             (= (strlen G-STR) 5)
      (setq G-STR t)
      (setq G-STR NIL)
;;;  Subfunction: CPKS-DO-SUMMARY                                     ;
;;;  Description: This function creates PROJECT_NUMBER.SUM summary file;
(defun CPKS-DO-SUMMARY (/            G-LST-SER    G-LST-SHT    G-COL-MASTER G-COL-SER
                         G-COL-SHT    G-LST-CELM   G-LST-CUNIT  G-LST-CSER   G-LST-CSHT
                         G_LST-SUMMARY             G-LST        G-I          G-POS
                         G-VAL        G-CODE       G-NUM        G-UNITS      G-LST-UNIT
                         G-LST-FAB-SYM             G-LST-FAB-SUM             G-FAB
                         G-LST-CNT    G-SER        G-LST-SER    G-ASSO       G-CNT
                         G-TOTAL      G-LST-SYM    G-LST-SYM-SUM             G-NAME
                         G-COL-NULL   G-COL-INDX   G-SYM        G-SHT        G-MARK
                         G-DATA       G-LST-X      G-ITEM-STR   G-STR        G-S
                         G-TOTAL-STR
  (if (and G_CDWG G_CSER G_CSHT G_PRJ-NUM G_PRG-NAME)
    (progn
      (setq G-LST-SER     (cadr (assoc "SERIES" G_LST-SS))
            G-LST-SHT     (cadr (assoc "SHEETS" G_LST-SS))
            G-COL-MASTER  9
            G-COL-SER     (length G-LST-SER)
            G-COL-SHT     (length G-LST-SHT)
            G-LST-CELM    (cadr (assoc "ELEMENT NAME" G_LST-SUM))
            G-LST-CUNIT   (cadr (assoc "UNITS" G_LST-SUM))
            G-LST-CSER    (cadr (assoc "SHEET SERIES" G_LST-SUM))
            G-LST-CSHT    (cadr (assoc "SHEETS" G_LST-SUM))
            G_LST-SUMMARY NIL
            G-LST         NIL
      (cond (G_LST-SEM
             (cond ((setq G-LST-SEM (cadr (assoc G_PRJ-NUM G_LST-SEM)))
                    (foreach G-S G-LST-SEM
                      (if (not (member G-S G-LST-SER))
                        (setq G-LST-SEM (vl-remove G-S G-LST-SEM))
                    (if (not (member G_CSER G-LST-SEM))
                      (setq G-LST-SEM (vl-sort (append G-LST-SEM (list G_CSER)) '<))
                    (setq G_LST-SEM
                           (subst (list G_PRJ-NUM G-LST-SEM) (assoc G_PRJ-NUM G_LST-SEM) G_LST-SEM)
                   (t
                    (setq G-LST-SEM (list G_CSER)
                          G_LST-SEM (append G_LST-SEM (list (list G_PRJ-NUM G-LST-SEM)))
            (t
      (setq G-LST-SEM (vl-sort G-LST-SEM (function (lambda (I1 I2) (< (atoi I1) (atoi I2))))))
      (foreach G-S G_LST-SEM
        (setq G-LST2WRITE (append G-LST2WRITE
                                  (list (strcat (car G-S) "|" (CPKS-LST2STR (cadr G-S) ",")))
      (if G-LST2WRITE
        (progn (setq G-FILE-ID (open (strcat (caddr G_PATH) "\\" (cadr G_PATH) ".sem") "w"))
               (foreach G-S G-LST2WRITE (write-line G-S G-FILE-ID))
               (close G-FILE-ID)
      (setq G-LST-SER G-LST-SEM
            G-LST2WRITE NIL
      (foreach G-S G-LST-SHT
        (if (= (strlen G-S) 1)
          (setq G-SSER G-S)
          (progn (setq G-SSER "")
                                     (cond ((< 47 X 58)
                                            (if (not G-SSSTOP)
                                              (setq G-SSER (strcat (chr X) G-SSER))
                                           (t (setq G-SSSTOP t))
                         (vl-string->list G-S)
        (setq G-SSSTOP NIL)
        (if (not (member G-SSER G-LST-SER))
          (setq G-LST-SHT (vl-remove G-S G-LST-SHT))
      ;; create Header entries ;
      (setq G_LST-SUMMARY
             (append (list (list (strcat "Client:     "
                                         G_CLI-CODE
                                         G_CLI-NAME
                                         (CPKS-XPIPES (+ (1- G-COL-MASTER) G-COL-SER))
                     (list (list (strcat "Program:    "
                                         G_PRG-CODE
                                         G_PRG-NAME
                     (list (list (strcat "Project No: "
                                         G_PRJ-NUM
      ;; create ELEMENT NAME entry ;
      (foreach G-I G-LST-SER
        (if (equal G-I G_CSER)
          (setq G-LST (append G-LST (list G_ELM-NAME)))
          (if (and G-LST-CELM G-LST-CSER (setq G-POS (vl-position G-I G-LST-CSER)))
            (setq G-LST (append G-LST (list (nth G-POS G-LST-CELM))))
            (setq G-LST (append G-LST (list "****")))
      (setq G_LST-SUMMARY (append G_LST-SUMMARY
                                  (list (list (strcat (CPKS-XPIPES (1- G-COL-MASTER))
                                                      "ELEMENT NAME>|"
                                                      (CPKS-LST2STR G-LST "|")
            G-LST         NIL
      ;; create UNITS entry ;
      (if (and G_ELM-CODE (/= G_ELM-CODE ""))
        (progn (setq G-UNITS NIL)
               (foreach G-I (CPF-STR2LST G_ELM-CODE ";" NIL)
                 (if (and (setq G-CODE (CPF-STR2LST G-I "|" NIL))
                          (setq G-NUM (atoi (last G-CODE)))
                          (> G-NUM 0)
                          (= (length G-CODE) 4)
                   (if (not G-UNITS)
                     (setq G-UNITS G-NUM)
                     (setq G-UNITS (+ G-UNITS G-NUM))
               (if G-UNITS
                 (setq G-UNITS (itoa G-UNITS))
                 (setq G-UNITS "1")
        (if (and G_ELM-QTY (/= G_ELM-QTY ""))
          (setq G-UNITS G_ELM-QTY)
          (setq G-UNITS "1")
      (setq G-LST NIL)
          (setq G-LST (append G-LST (list G-UNITS)))
          (if (and G-LST-CUNIT G-LST-CSER (setq G-POS (vl-position G-I G-LST-CSER)))
            (setq G-LST (append G-LST (list (nth G-POS G-LST-CUNIT))))
            (setq G-LST (append G-LST (list "1")))
                                                      "UNITS>|"
            G-LST-UNIT    G-LST
            G-LST         NIL
      ;; create FABRICATIONS LIST: HEADER entry ;
      (setq G_LST-SUMMARY
             (append
               G_LST-SUMMARY
               (list (list (strcat "FABRICATIONS LIST:"
                                   (CPKS-XPIPES G-COL-MASTER)
                                   "SHEET SERIES|"
                                   (CPKS-XPIPES (- G-COL-SER 2))
               (list
                 (list
                   (strcat
                     "ITEM|SYMBOL|TOTAL QTY|PART #||DWG NO.|VENDOR|DUE DATE|Description|"
                     (CPKS-LST2STR G-LST-SER "|")
            G-LST NIL
      ;; create Fabrication entries ;
                          (if (= (substr X 1 1) "F")
                            (setq G-LST-FAB-SYM
                                   (vl-sort
                                     (append G-LST-FAB-SYM (list X))
                                     (function
                                       (lambda (I1 I2) (< (atoi (substr I1 3)) (atoi (substr I2 3))))
              G_LST-SYM
                          (if (and (= (substr (car X) 1 1) "F") (CPKS-SYM-VALIDATE (car X)))
                            (setq G-LST-FAB-SUM (append (list X) G-LST-FAB-SUM))
              G_LST-SUM
      (if G-LST-FAB-SYM
                            (if (not (assoc X G-LST-FAB-SUM))
                              (setq G-LST-FAB-SUM
                                     (vl-sort
                                       (append G-LST-FAB-SUM (list (list X)))
                                       (function
                                         (lambda (I1 I2)
                                           (< (atoi (substr (car I1) 3)) (atoi (substr (car I2) 3)))
                G-LST-FAB-SYM
      (if (and G-LST-FAB-SUM
               (setq G_SPEC-FAB (CPF-SPEC-FILE "FAB" NIL))
               (setq G_LST-FABCNT (CPKS-GET-FABCNT))
        (foreach G-I G-LST-FAB-SUM
          (if (and (setq G-FAB (car G-I)) (setq G-CNT (cdr (assoc G-FAB G_LST-FABCNT))))
            (progn
              (foreach G-SER G-LST-SER
                (if (setq G-ASSO (assoc G-SER G-CNT))
                  (setq G-LST-CNT (append G-LST-CNT (cdr G-ASSO)))
                  (setq G-LST-CNT (append G-LST-CNT (list "")))
              (if (member NIL (mapcar (function (lambda (X) (= X ""))) G-LST-CNT))
                (progn
                  (setq G-CNT 0
                        G-TOTAL 0
                  (mapcar
                    (function
                      (lambda (X)
                        (if (> (atoi X) 0)
                          (setq G-TOTAL (+ G-TOTAL (* (atoi (nth G-CNT G-LST-UNIT)) (atoi X))))
                        (setq G-CNT (1+ G-CNT))
                    G-LST-CNT
                  (setq G-TOTAL-STR (itoa G-TOTAL))
                (if (= (caar G-CNT) "EXIST.")
                  (setq G-TOTAL-STR "EXIST.")
                  (setq G-TOTAL-STR "")
              (setq
                                      (list (list (strcat "Fabrication|"
                                                          G-FAB
                                                          G-TOTAL-STR
                                                          (nth 1 (assoc G-FAB G_SPEC-FAB))
                                                          (vl-string-subst "FAB" "F" G-FAB)
                                                          (nth 3 (assoc G-FAB G_SPEC-FAB))
                                                          (last (assoc G-FAB G_SPEC-FAB))
                                                          (CPKS-LST2STR G-LST-CNT "|")
        (if (and G-LST-FAB-SUM (not G_SPEC-FAB))
          (progn
            (if G_PRG-NAME
              (CPF-BLINK (strcat "   **** Missing" (strcase G_PRG-NAME) ".FAB Spec. File! ****")
                          6
              (CPF-BLINK (strcat "   **** Missing *.FAB Spec. File! ****") 6)
            (if G_LST-SUM
              (setq G_LST-SUMMARY NIL)
      ;; create MATERIALS LIST: HEADER entry ;
      (if G_LST-SUMMARY
        (progn
          (setq G_LST-SUMMARY
                 (append
                   G_LST-SUMMARY
                   (list (list " "))
                   (list (list (strcat "MATERIALS LIST:"
                                       "SHEETS|"
                                       (CPKS-XPIPES (- G-COL-SHT 2))
                   (list
                     (list
                       (strcat "ITEM|SYMBOL|QTY|UNITS|SIZE|CP#|MFR.|MFR#|Description|"
                               (CPKS-LST2STR G-LST-SHT "|")
                G-LST NIL
          ;; create Paint, Material, Hardware, Electrical, Aluminum and Steel entries ;
          (foreach G-I (list "PNT" "MAT" "HDW" "ELC" "ALM" "STL")
            (setq G-LST-SYM NIL
                  G-LST-SYM-SUM NIL
                  G-SPEC-FILE NIL
            (if G_LST-SUMMARY
              (progn
                                    (if (= (substr X 1 1) (substr G-I 1 1))
                                      (setq G-LST-SYM
                                             (vl-sort
                                               (append G-LST-SYM (list X))
                                                           (< (atoi (substr I1 2)) (atoi (substr I2 2)))
                        G_LST-SYM
                                    (if (and (= (substr (car X) 1 1) (substr G-I 1 1))
                                      (setq G-LST-SYM-SUM (append (list X) G-LST-SYM-SUM))
                        G_LST-SUM
                (if G-LST-SYM
                  (mapcar
                                (if (not (assoc X G-LST-SYM-SUM))
                                  (setq
                                    G-LST-SYM-SUM (vl-sort (append G-LST-SYM-SUM (list (list X)))
        (< (atoi (substr (car I1) 2))
        (atoi (substr (car I2) 2))
                    G-LST-SYM
                (if (and G-LST-SYM-SUM (setq G-SPEC-FILE (CPF-SPEC-FILE G-I NIL)))
                  (progn
                    (cond ((= G-I "PNT")
                           (setq G-NAME     "Paint"
                                 G-COL-NULL "||||"
                                 G-COL-INDX (list 3 2 1)
                                 G_SPEC-PNT G-SPEC-FILE
                          ((= G-I "MAT")
                           (setq G-NAME     "Material"
                                 G-COL-NULL "|||||"
                                 G-COL-INDX (list 2 3)
                                 G_SPEC-MAT G-SPEC-FILE
                          ((= G-I "HDW")
                           (setq G-NAME     "Hardware"
                                 G-COL-NULL "||||"
                                 G-COL-INDX (list 1 2 2)
                                 G_SPEC-HDW G-SPEC-FILE
                          ((= G-I "ELC")
                           (setq G-NAME     "Electrical"
                                 G-COL-NULL "||||"
                                 G-COL-INDX (list 1 2 3)
                                 G_SPEC-ELC G-SPEC-FILE
                          ((= G-I "ALM")
                           (setq G-NAME     "Aluminum"
                                 G-COL-NULL "||||||"
                                 G-COL-INDX (list 10)
                                 G_SPEC-ALM G-SPEC-FILE
                          ((= G-I "STL")
                           (setq G-NAME     "Steel"
                                 G-COL-NULL "||||||"
                                 G_SPEC-STL G-SPEC-FILE
                    (foreach G-ITEM G-LST-SYM-SUM
                      (setq G-LST-X NIL
                            G-SYM   (car G-ITEM)
                            G-MARK  (substr G-SYM 2)
                            G-ASSO  (cadr G-ITEM)
                            G-DATA  NIL
                      (if (setq G-DATA (assoc G-SYM G-SPEC-FILE))
                        (progn (foreach G-SHT G-LST-SHT
                                 (if (equal G_CSHT G-SHT)
                                   (if (member G-SYM G-LST-SYM)
                                     (setq G-LST-X (append G-LST-X (list "X")))
                                     (setq G-LST-X (append G-LST-X (list "")))
                                   (if (and G-ASSO
                                            (setq G-POS (vl-position G-SHT G-LST-CSHT))
                                            (setq G-VAL (nth G-POS G-ASSO))
                                     (setq G-LST-X (append G-LST-X (list G-VAL)))
                               (if (member t (mapcar (function (lambda (X) (/= "" X))) G-LST-X))
                                 (progn (setq G-ITEM-STR (strcat G-NAME "|" G-MARK G-COL-NULL))
                                        (foreach G-CNT G-COL-INDX
                                          (if (not (setq G-STR (nth G-CNT G-DATA)))
                                            (setq G-STR "")
                                          (setq G-ITEM-STR (strcat G-ITEM-STR G-STR "|"))
        (last G-DATA)
        (CPKS-LST2STR G-LST-X "|")
                                              G_LST-SUMMARY (append G_LST-SUMMARY (list (list G-ITEM-STR)))
                  (if (and G-LST-SYM-SUM (not G-SPEC-FILE))
                    (progn (if G_PRG-NAME
                                                 G-I
                                                 " Spec. File! ****"
                                         6
                             (CPF-BLINK (strcat "   **** Missing *." G-I " Spec. File! ****") 6)
                           (if G_LST-SUM
      (if (and G_LST-SUMMARY
               G_PRJ-NUM
               (caddr G_PATH)
               (setq G-FILE-ID (open (strcat (caddr G_PATH) "\\" G_PRJ-NUM ".sum") "w"))
        (progn (foreach G-I G_LST-SUMMARY (write-line (car G-I) G-FILE-ID)) (close G-FILE-ID))
        (cond
          ((not G_LST-SUMMARY)
           (CPF-BLINK "**** Summary file not created - No Contents!              ****" 6)
          ((not G_PRJ-NUM)
           (CPF-BLINK "**** Summary file not created - Unknown Project Number!   ****" 6)
          ((not (caddr G_PATH))
           (CPF-BLINK "**** Summary file not created - Directory mismatch!       ****" 6)
          (t (CPF-BLINK "**** Summary file not created - Unable to open for write! ****" 6))
;;;  Subfunction: CPKS-DO-SQUEEZE                                     ;
;;;  Description: Calculate y-factor for keynote block inserts.        ;
;;;(defun CPKS-DO-SQUEEZE (GA-PTY-UP GA-PTY-DN GA-SCL / G-LG-TOTAL G-LST G-FACTOR g-yes-fab g-yes-rev)
;;;  (if
;;;    (and
;;;      (setq G-SS (ssget "x" (list '(0 . "INSERT") '(2 . "CP_ksstn-t") (cons 410 (getvar "ctab")))))
;;;      (> (sslength G-SS) 0)
;;;     (setq GA-PTY-DN   (nth 1 (cdr (assoc 10 (entget (ssname G-SS 0)))))
;;;           G-RANGE-PTY (- GA-PTY-UP GA-PTY-DN)
;;;  (if G_MISSING-INFO
;;;    (setq G-LG-TOTAL (* GA-SCL 2.4))
;;;    (setq G-LG-TOTAL 0)
;;;  (foreach G-I (list "PNT" "MAT" "HDW" "ELC" "ALM" "STL" "FAB" "REV")
;;;    (setq G=LST-SYM G_LST-SYM)
;;;    (setq G-LST NIL)
;;;    (mapcar
;;;      (function (lambda (X)
;;;                  (if (equal (substr X 1 1) (substr G-I 1 1))
;;;                    (progn
;;;                    (if (equal (substr G-I 1 1) "F")
;;;                      (setq
;;;                        G-LST (vl-sort
;;;                                (append G-LST (list X))
;;;                                (function (lambda (I1 I2) (< (atoi (substr I1 3)) (atoi (substr I2 3)))))
;;;                      (setq
;;;                        G-LST (vl-sort
;;;                                (function (lambda (I1 I2) (< (atoi (substr I1 2)) (atoi (substr I2 2)))))
;;;                    (cond ((=
;;;                  (if (= (substr g-i 1 1) "F") (setq g-yes-fab t))
;;;                  (if (= (substr g-i 1 1) "R") (setq g-yes-rev t))
;;;      G_LST-SYM
;;;    (if G-LST
;;;      (progn (setq G-LG-TOTAL                         (+ G-LG-TOTAL (* GA-SCL G-KSBLK-HT-HEADER) (* (length G-LST) GA-SCL G-KSBLK-HT-TILE)
;;;                   (if G-YES-FAB
;;;                     (* GA-SCL G-KSBLK-HT-HEADER-FAB)
;;;                     0.0
;;;                   )                                  (if G-YES-REV
;;;                                                        (* GA-SCL G-KSBLK-HT-HEADER-REV)
;;;                                                        0.0
;;;             (cond ((= G-I "FAB") (setq G-LG (* GA-SCL G-KSBLK-HT-HEADER-FAB)))
;;;                   (t (setq G-LG (* GA-SCL G-KSBLK-HT-HEADER)))
;;;             (setq G-LG-TOTAL (+ G-LG-TOTAL G-LG (* (length G-LST) GA-SCL G-KSBLK-HT-TILE)))
;;;    (cond ((> G-LG-TOTAL (* 1.05 G-RANGE-PTY)) (setq G-FACTOR (* 0.92 (/ G-RANGE-PTY G-LG-TOTAL))))
;;;          (t (setq G-FACTOR 1.0))
;;;  G-FACTOR
                         G-FACTOR     G-YES-FAB    G-YES-REV    G-YES-PNT    G-YES-MAT
                         G-YES-HRD    G-YES-ELC    G-YES-MET
  ;; adjust lower y-value of KS footprint...
  (if (and (setq G-SS
                  (ssget "x" (list '(0 . "INSERT") '(2 . "CP_ksstn-t*") (cons 410 (getvar "ctab"))))
    (setq GA-PTY-DN (nth 1 (cdr (assoc 10 (entget (ssname G-SS 0))))))
  ;; calculate available KS footprint height...
  (setq G-RANGE-PTY (- GA-PTY-UP GA-PTY-DN))
  (if G_MISSING-INFO
    (setq G-LG-TOTAL 2.4)
    (setq G-LG-TOTAL 0)
                      (cond ((= (substr X 1 1) "F")
                             (setq G-LG-TOTAL (+ G-LG-TOTAL G-KSBLK-HT-TILE))
                             (if (not G-YES-FAB)
                               (setq G-YES-FAB  t
                                     G-LG-TOTAL (+ G-LG-TOTAL G-KSBLK-HT-HEADER-FAB)
                            ((= (substr X 1 1) "R")
                             (if (not G-YES-REV)
                               (setq G-YES-REV  t
                                     G-LG-TOTAL (+ G-LG-TOTAL G-KSBLK-HT-HEADER-REV)
                            ((= (substr X 1 1) "P")
                             (if (not G-YES-PNT)
                               (setq G-YES-PNT  t
                                     G-LG-TOTAL (+ G-LG-TOTAL G-KSBLK-HT-HEADER)
                            ((= (substr X 1 1) "M")
                             (if (not G-YES-MAT)
                               (setq G-YES-MAT  t
                            ((= (substr X 1 1) "H")
                             (if (not G-YES-HRD)
                               (setq G-YES-HRD  t
                            ((= (substr X 1 1) "E")
                             (if (not G-YES-ELC)
                               (setq G-YES-ELC  t
                            ((member (substr X 1 1) (list "A" "S"))
                             (if (not G-YES-MET)
                               (setq G-YES-MET  t
          G_LST-SYM
  (cond ((and G-RANGE-PTY (> (* G-LG-TOTAL GA-SCL) G-RANGE-PTY))
         (setq G-FACTOR (* 0.95 (/ G-RANGE-PTY (* G-LG-TOTAL GA-SCL))))
  G-FACTOR
;;;  Subfunction: CPKS-DO-INSERTS                                     ;
;;;  Description: This function handles insertion of keynote blocks in ;
;;;               title block.                                         ;
(defun CPKS-DO-INSERTS (/               G-SS            G-DWG-SCALE     G-INS-SCALE
                         G-TB-DATA       G-TB-NM         G-TB-IPT        G-LST-IPTS
                         G-TB-VER        G-TB-PTS        G-STEN          G-REV
                         G-IPT           G-LST           G-TITLE-ON      G-ATTR-DSC
                         G-ATTR-MFN      G-ATTR-QTY      G-SPEC-FILE     G-HT-TILE
                         G-HT-HEADER     G-BLK-HEADER    G-BLK-TILE      G-SPEC-FILE
                         G-TITLE-MET     G-ASSO          G-SYM           G-I
                         G-FAB-TOTAL     G-FEQTY         G-FUQTY         G-ENTRY
                         G-FABT          G-LST-QTY       G-LST-UNIT      G-FAB-CNT
                         G-LST-FABS      G-BLK-MASTERI   G-STEN-DONE     G-METRIC
                         G-KSBLK-HT-HEADER               G-KSBLK-HT-HEADER-FAB
                         G-KSBLK-HT-TILE G-REVBLK-HT-HEADER              G-REVBLK-HT-TITLE
			 G-TB-NEW
  (setq G-KSBLK-HT-HEADER 0.45
        G-KSBLK-HT-HEADER-FAB 0.65
        G-KSBLK-HT-HEADER-REV 1.0
        G-KSBLK-HT-TILE 0.3125
        G-REVBLK-HT-HEADER 1.0
        G-REVBLK-HT-TILE 0.3125
	G-TB-NEW nil
  (CPF-TEXTSTYLE "KEYNOTE" t)
  (vl-cmdf "._UCS" "World")
  ;Expanded selection to find V2 Titleblock (DF 03-24-20)
;;;                      (list '(0 . "INSERT")
;;;                            '(2 . "24x36,24X36,24x36_V2,24X36_V2,A1,a1,A4,a4,11X17,11x17,11X17_V2,11x17_v2,85X11,85x11,85X11_V2,85x11_v2,setup,SETUP,setup_v2,SETUP_V2")
;;;                            (cons 410 (getvar "ctab"))
  (if (setq G-SS (ssget "x"
                            '(2 . "24x36,24X36,A1,a1,A4,a4,11X17,11x17,85X11,85x11,setup,SETUP")
    (setq G-TB-NEW nil)
                            '(2 . "24x36_V2,24X36_V2,11X17_V2,11x17_v2,85X11_V2,85x11_v2,setup_v2,SETUP_V2")
      (setq G-TB-NEW t)
  (if (and G-SS (> (sslength G-SS) 0))
    (progn
      (setq G-TB-DATA   (entget (ssname G-SS 0)))
      (setq G-TB-NM     (strcase (cdr (assoc 2 G-TB-DATA))))
;;;      (if (= G-TB-NM "24X36_V2")
;;;	(setq G-TB-NM "24X36")
      (setq G-TB-IPT    (cdr (assoc 10 G-TB-DATA))
          G-DWG-SCALE (cdr (assoc 41 G-TB-DATA))
          G-TB-VER    (CPF-TBLK-VER)
          G-TB-PTS    (CPF-TBLK-POINTS)
    (if (not (setq G-DWG-SCALE (atof (cdr (assoc "DWG_SCALE" G_DICT)))))
      (setq G-DWG-SCALE 1.0)
  (setq G_TB-SCF 1.0)
  (cond ((member G-TB-NM (list "24X36" "24X36_V2" "SETUP" "SETUP_V2"))
         (setq G-INS-SCALE 1.0
               G-STEN t
               G-REV t
               G-FABT NIL
         (if (= G-TB-VER "E")
           (setq G_TB-SCF 1.0289)
         (if (= G-TB-VER "F")
	 (if (= G-TB-VER "G")
           (setq G_TB-SCF 1.0)
        ((= G-TB-NM "A1")
               G-STEN t
               G-REV t
               G-FABT NIL
        ((member G-TB-NM '("85X11" "85X11_V2" "A4"))
         (setq G-INS-SCALE 0.8)
         (cond ((member (car G_FILE-ID) '("SHT" "SET"))
                (setq G-STEN t
                      G-REV t
                      G-FABT NIL
               (t
                (setq G-STEN NIL
                      G-REV NIL
                (cond ((member (car G_FILE-ID) '("FAB")) (setq G-FABT t))
                      (t (setq G-FABT NIL))
        ((member G-TB-NM '("11X17"))
         (setq G-INS-SCALE 0.75)
                (setq G-STEN t
                      G-REV t
                      G-FABT NIL
               (t
                (setq G-STEN t
                      G-REV t
	((member G-TB-NM '("11X17_V2"))
         (setq G-INS-SCALE (/ 2.50 3.625))
                (setq G-STEN t
                      G-REV t
                      G-FABT NIL
               (t
                (setq G-STEN t
                      G-REV t
        (t
               G-STEN NIL
               G-REV NIL
  (if (setq G-LST-IPTS (cdr (assoc G-TB-NM G-TB-PTS)))
    (if (not (setq G-LST-IPTS (cdr (assoc G-TB-VER G-LST-IPTS))))
      (setq G-LST-IPTS (cdr (last (assoc G-TB-NM G-TB-PTS))))
  (if (member (substr G*ENV 2 1) (list "m" "j" "c" "M"))
    (cond ((member (substr G*ENV 2 1) '("m" "j")) (setq G-INS-SCALE (* 25.0 G-INS-SCALE)))
          ((= (substr G*ENV 2 1) "c") (setq G-INS-SCALE (* 2.5 G-INS-SCALE)))
          ((= (substr G*ENV 2 1) "M") (setq G-INS-SCALE (* 0.025 G-INS-SCALE)))
  (if G_SURVEYSC
    (setq G-INS-SCALE (/ G_SURVEYSC G-DWG-SCALE))
;;; generate insertion start point for keynoting schedules block...
  (if G_SURVEYIPT
    (setq G-IPT G_SURVEYIPT)
    (if (or (and (not G-MODE) (member G-TB-NM '("85X11" "85X11_V2" "A4")))
            (and (not G-MODE) (member (car G_FILE-ID) '("DTL" "FAB" "MSC")) (not G-TB-NM))
      (setq G-IPT (getpoint "\nSelect upper left corner for Keynoting Schedules block: "))
  (if (and (not G-IPT) G-LST-IPTS G-TB-IPT)
    (setq G-IPT   (list (+ (* G-DWG-SCALE (caar G-LST-IPTS)) (car G-TB-IPT))
                        (+ (* G-DWG-SCALE (cadar G-LST-IPTS)) (cadr G-TB-IPT))
                        0.0
          G-IPT-L (list (+ (* G-DWG-SCALE (caadr G-LST-IPTS)) (car G-TB-IPT))
                        (+ (* G-DWG-SCALE (cadadr G-LST-IPTS)) (cadr G-TB-IPT))
                        0.0
  (if (not G-IPT)
    (setq G-IPT (list 0.0 0.0))
  (setq G-IPT-START G-IPT)
;;; process element codes...
  (if G-STEN
    (if
      (not (ssget "x" (list '(0 . "INSERT") (cons 410 (getvar "ctab")) '(2 . "CP_kslock-ec*"))))
       (CPF-EC G-MODE)
;;; end of process element codes.
  (CPF-LAYER "TITLE" "E" "MC")
  (if (member (car G_FILE-ID) '("SHT" "SET"))
    (setq G_SQUEEZE-FACTOR (CPKS-DO-SQUEEZE (nth 1 G-IPT) (nth 1 G-IPT-L) G-DWG-SCALE))
    (setq G_SQUEEZE-FACTOR 1.0)
  (if G-REV
    (CPKS-DO-REV-INSERTS)
;;; process symbols...
  (if (and G-IPT G_LST-SYM)
    (foreach G-I (list "PNT" "MAT" "HDW" "ELC" "ALM" "STL" "FAB")
      (setq G-LST NIL)
                              (setq G-LST
                                     (vl-sort (append G-LST (list X))
                                              (function
                              (setq G-LST
                                              (function
              G_LST-SYM
      (if G-LST
	;Expanded function to determine which keynote block version to be used (DF 03-24-20)
        (progn
          (setq G-TITLE-ON NIL
                G-ATTR-DSC NIL
                G-ATTR-QTY NIL
                G-ATTR-MFN NIL
                G-SPEC-FILE NIL
          (cond ((equal G-I "PNT")
		 (cond
		   ((= G-TB-NEW nil)
		    (setq G-HT-TILE     G-KSBLK-HT-TILE
                       G-HT-HEADER   G-KSBLK-HT-HEADER
                       G-WD-DSC      2.25
                       G-WD-MFN      1.0
                       G-BLK-HEADER  "CP_kspnt-m"
                       G-BLK-HEADERX "CP_kspnt-mx"
                       G-BLK-TILE    "CP_kspnt-t"
                       G-SPEC-FILE   G_SPEC-PNT
		   ((= G-TB-NEW t)
                       G-WD-DSC      2.0
                       G-WD-MFN      1.0
                       G-BLK-HEADER  "CP_kspnt-m_v2"
                       G-BLK-HEADERX "CP_kspnt-mx_v2"
                       G-BLK-TILE    "CP_kspnt-t_v2"
                ((equal G-I "MAT")
		 (cond
		   ((= G-TB-NEW nil)
                       G-WD-DSC      2.25
                       G-WD-MFN      1.0
                       G-BLK-HEADER  "CP_ksmat-m"
                       G-BLK-HEADERX "CP_ksmat-mx"
                       G-BLK-TILE    "CP_ksmat-t"
                       G-SPEC-FILE   G_SPEC-MAT
		   ((= G-TB-NEW t)
                       G-WD-DSC      2.125
                       G-WD-MFN      1.0
                       G-BLK-HEADER  "CP_ksmat-m_v2"
                       G-BLK-HEADERX "CP_ksmat-mx_v2"
                       G-BLK-TILE    "CP_ksmat-t_v2"
                ((equal G-I "HDW")
		 (cond
		   ((= G-TB-NEW nil)
                       G-WD-DSC      2.25
                       G-WD-MFN      1.0
                       G-BLK-HEADER  "CP_kshdw-m"
                       G-BLK-HEADERX "CP_kshdw-mx"
                       G-BLK-TILE    "CP_kshdw-t"
                       G-SPEC-FILE   G_SPEC-HDW
		   ((= G-TB-NEW t)
                       G-WD-DSC      2.125
                       G-WD-MFN      1.0
                       G-BLK-HEADER  "CP_kshdw-m_v2"
                       G-BLK-HEADERX "CP_kshdw-mx_v2"
                       G-BLK-TILE    "CP_kshdw-t_v2"
                ((equal G-I "ELC")
		 (cond
		   ((= G-TB-NEW nil)
                       G-WD-DSC      2.25
                       G-WD-MFN      1.0
                       G-BLK-HEADER  "CP_kselc-m"
                       G-BLK-HEADERX "CP_kselc-mx"
                       G-BLK-TILE    "CP_kselc-t"
                       G-SPEC-FILE   G_SPEC-ELC
		   ((= G-TB-NEW t)
                       G-WD-DSC      2.125
                       G-WD-MFN      1.0
                       G-BLK-HEADER  "CP_kselc-m_v2"
                       G-BLK-HEADERX "CP_kselc-mx_v2"
                       G-BLK-TILE    "CP_kselc-t_v2"
                ((equal G-I "ALM")
		 (cond
		   ((= G-TB-NEW nil)
                       G-WD-DSC      3.25
                       G-BLK-HEADER  "CP_ksmet-m"
                       G-BLK-HEADERX "CP_ksmet-mx"
                       G-BLK-TILE    "CP_ksmet-t"
                       G-SPEC-FILE   G_SPEC-ALM
                       G-TITLE-MET   t
		   ((= G-TB-NEW t)
                       G-WD-DSC      3.125
                       G-BLK-HEADER  "CP_ksmet-m_v2"
                       G-BLK-HEADERX "CP_ksmet-mx_v2"
                       G-BLK-TILE    "CP_ksmet-t_v2"
                       G-TITLE-MET   t
                ((equal G-I "STL")
		 (cond
		   ((= G-TB-NEW nil)
                       G-WD-DSC      3.25
                       G-SPEC-FILE   G_SPEC-STL
		    (if G-TITLE-MET
		      (setq G-TITLE-ON t)
		   ((= G-TB-NEW t)
                       G-WD-DSC      3.125
		    (if G-TITLE-MET
		      (setq G-TITLE-ON t)
                ((equal G-I "FAB")
		 (cond
		   ((= G-TB-NEW nil)
		    (cond (G-FABT
                              G-HT-HEADER   0.775
                              G-WD-DSC      2.875
                              G-WD-MFN      0.5
                              G-BLK-HEADER  "CP_ksftl-m"
                              G-BLK-HEADERX "CP_ksftl-m"
                              G-BLK-TILE    "CP_ksftl-t"
                              G-SPEC-FILE   G_SPEC-FAB
                              G-FAB-TOTAL   t
			   (if (equal (car G_FILE-ID) "FAB")
			     (setq G-LST (list (strcat "F-" (nth 1 G_FILE-ID))))
			     (setq G-LST NIL)
			  (t
                              G-HT-HEADER   G-KSBLK-HT-HEADER-FAB
                              G-WD-DSC      2.25
                              G-WD-MFN      0.5
                              G-BLK-HEADER  "CP_ksfab-m"
                              G-BLK-HEADERX "CP_ksfab-mx"
                              G-BLK-TILE    "CP_ksfab-t"
		   ((= G-TB-NEW t)
		    (cond (G-FABT
                              G-HT-HEADER   0.775
                              G-WD-DSC      2.75
                              G-WD-MFN      0.5
                              G-BLK-HEADER  "CP_ksftl-m_v2"
                              G-BLK-HEADERX "CP_ksftl-m_v2"
                              G-BLK-TILE    "CP_ksftl-t_v2"
                              G-FAB-TOTAL   t
			     (setq G-LST NIL)
			  (t
                              G-WD-DSC      2.125
                              G-WD-MFN      0.5
                              G-BLK-HEADER  "CP_ksfab-m_v2"
                              G-BLK-HEADERX "CP_ksfab-mx_v2"
                              G-BLK-TILE    "CP_ksfab-t_v2"
          (if (not (tblsearch "BLOCK" G-BLK-HEADER))
            (if (not (findfile (strcat G-BLK-HEADER ".dwg")))
              (progn
                (terpri)
                (CPF-BLINK (strcat "**** UNABLE TO FIND " G-BLK-HEADER ".dwg BLOCK! ****") 3)
                (setq G-BLK-HEADER NIL)
              (setq G-BLK-HEADER (strcat G-BLK-HEADER ".dwg"))
          (if (not (tblsearch "BLOCK" G-BLK-HEADERX))
            (if (not (findfile (strcat G-BLK-HEADERX ".dwg")))
              (progn
                (terpri)
                (CPF-BLINK (strcat "**** UNABLE TO FIND " G-BLK-HEADERX ".dwg BLOCK! ****") 3)
                (setq G-BLK-HEADERX NIL)
              (setq G-BLK-HEADERX (strcat G-BLK-HEADERX ".dwg"))
          (if (not (tblsearch "BLOCK" G-BLK-TILE))
            (if (not (findfile (strcat G-BLK-TILE ".dwg")))
              (progn (terpri)
                     (CPF-BLINK (strcat "**** UNABLE TO FIND " G-BLK-TILE ".dwg BLOCK! ****") 3)
                     (setq G-BLK-TILE NIL)
              (setq G-BLK-TILE (strcat G-BLK-TILE ".dwg"))
          (if (not G-SPEC-FILE)
            (setq G-SPEC-FILE (CPF-SPEC-FILE G-I (last G-LST)))
          (if (and G-BLK-HEADER G-BLK-HEADERX G-BLK-TILE G-SPEC-FILE)
            (progn
              (foreach G-SYM G-LST
                (if (setq G-ASSO (assoc G-SYM G-SPEC-FILE))
                  (progn
                    (setq G-ATTR-DSC (last G-ASSO))
                    (cond
                      ((equal G-I "PNT")
                       (setq G-ATTR-SYM (substr G-SYM 2)
                             G-ATTR-MFN (nth 3 G-ASSO)
                      ((member G-I '("MAT" "ELC"))
                             G-ATTR-MFG (nth 2 G-ASSO)
                       (if (> (strlen G-ATTR-MFG) 0)
                         (setq G-ATTR-DSC (strcat G-ATTR-MFG " " G-ATTR-DSC))
                      ((member G-I '("ALM" "STL"))
                       (setq G-ATTR-SYM (strcat (substr G-SYM 1 1) " " (substr G-SYM 2)))
                      ((equal G-I "HDW")
                             G-ATTR-MFG (nth 3 G-ASSO)
                             G-ATTR-MFN (nth 1 G-ASSO)
                      ((equal G-I "FAB")
                       (setq G-ATTR-SYM G-SYM
                             G-ATTR-QTY NIL
                             G-LST-QTY  NIL
                             G-FAB-CNT  NIL
                       (cond
                         (G-FAB-TOTAL
                          (cond ((/= (setq G-FAB-CNT (nth 2 G-ASSO)) "")
                                 (setq G-LST-UNIT (CPF-GET-SUMS G-SYM G_INDX))
                                 (foreach G-SER (CPF-STR2LST G-FAB-CNT "," NIL)
                                   (setq
                                     G-LST-QTY (vl-sort
                                                 (append G-LST-QTY
                                                             (< (atoi (car I1)) (atoi (car I2)))
                                 (foreach G-X G-LST-QTY
                                   (setq G-ENTRY NIL)
                                   (setq G-SER (car G-X))
                                   (setq G-FEQTY (cadr G-X))
                                   (setq G-FUQTY (cadr (assoc G-SER G-LST-UNIT)))
                                   (if G-FEQTY
                                     (if G-FUQTY
                                       (setq G-ENTRY (list (list G-SER
        G-FEQTY
        G-FUQTY
        (* (atoi G-FEQTY) (atoi G-FUQTY))
                                       (setq G-ENTRY (list (list G-SER G-FEQTY "" "")))
                                   (if G-ENTRY
                                     (setq G-LST-FABS (append G-LST-FABS G-ENTRY))
                                (t (CPF-BLINK (strcat "   **** MISSING QUANTITIES! ****") 3))
                         (t
                          (cond
                            ((= (setq G-FAB-CNT (nth 2 G-ASSO)) "") (setq G-ATTR-QTY NIL))
                            (t
                             (if (= (nth 2 G-ASSO) "EXIST.")
                               (setq G-ATTR-QTY "EXIST.")
                               (progn (foreach G-SER (CPF-STR2LST G-FAB-CNT "," NIL)
                                        (setq G-LST-QTY (append G-LST-QTY
                                      (foreach G-SER G-LST-QTY
                                        (if (equal G_CSER (car G-SER))
                                          (setq G-ATTR-QTY (cadr G-SER))
                          (cond
                            ((and (not G-ATTR-QTY) G_CSER)
                             (prompt "\n")
                             (setq G-ATTR-QTY ""
                                   G_ATTR-MISS t
                             (if (not G_MISSING-INFO)
                               (CPF-BLINK (strcat "   **** " G-SYM " - MISSING QUANTITY! ****")
                                           3
                            ((not G-ATTR-QTY) (setq G-ATTR-QTY ""))
                       (cond ((assoc G-SYM G_LST-PARTS)
                              (setq G-ATTR-SYM (cdr (assoc G-SYM G_LST-PARTS)))
                             (t (setq G-ATTR-SYM G-SYM))
                    (if (or (and G-ATTR-DSC
                                 (> (CPF-TXT-LENGTH G-ATTR-DSC "KEYNOTE" 0.095 0.75) G-WD-DSC)
                            (and G-ATTR-MFN
                                 (> (CPF-TXT-LENGTH G-ATTR-MFN "KEYNOTE" 0.095 0.75) G-WD-MFN)
                      (setq G-BLK-MASTERI G-BLK-HEADERX)
                      (setq G-BLK-MASTERI G-BLK-HEADER)
                  (progn
                    (cond ((member G-I '("HDW" "PNT")) (setq G-ATTR-SYM (substr G-SYM 2)))
                          ((member G-I '("MAT" "ELC")) (setq G-ATTR-SYM (substr G-SYM 2)))
                          ((equal G-I "HDW") (setq G-ATTR-SYM (substr G-SYM 2)))
                          ((equal G-I "FAB")
                          G-ATTR-DSC    ""
                          G-ATTR-MFN    ""
                          G-ATTR-QTY    ""
                          G_ATTR-MISS   t
                    (prompt "\n")
                      (CPF-BLINK (strcat "**** " G-SYM "   - NOT SPECIFIED!    ****") 3)
                (if (not G-TITLE-ON)
                  (cond (G-FAB-TOTAL
                         (vl-cmdf "._-insert"
                                  G-BLK-TILE
                                  G-IPT
                                  "x"
                                  (* G-DWG-SCALE G-INS-SCALE G_TB-SCF)
                                  (* G-DWG-SCALE G-INS-SCALE G_SQUEEZE-FACTOR)
                                  (* G-DWG-SCALE G-INS-SCALE)
                                  "0.0"
                                  G-ATTR-SYM
                                  G-ATTR-MFN
                                  G-ATTR-DSC
                         (setq G-IPT      (list (car G-IPT)
                                                (- (cadr G-IPT)
                                                   (* G-DWG-SCALE G-INS-SCALE G-HT-HEADER G_SQUEEZE-FACTOR)
                                                0.0
                               G-TITLE-ON t
                        (t
                                  G-BLK-TILE
                                  G-IPT
                                  "x"
                                  "0.0"
                                                (- (cadr G-IPT)
                                                0.0
                               G-TITLE-ON t
                (cond ((member G-I '("PNT" "MAT" "HDW" "ELC"))
                                G-BLK-MASTERI
                                G-IPT
                                "x"
                                "0.0"
                                G-ATTR-SYM
                                G-ATTR-MFN
                                G-ATTR-DSC
                                G-BLK-MASTERI
                                G-IPT
                                "x"
                                "0.0"
                                G-ATTR-SYM
                                G-ATTR-DSC
                      ((= G-I "FAB")
                       (cond (G-FAB-TOTAL
                              (foreach G-S G-LST-FABS
                                         G-BLK-MASTERI
                                         G-IPT
                                         "x"
                                         "0.0"
                                         (nth 0 G-S)
                                         (nth 1 G-S)
                                         (nth 2 G-S)
                                         (nth 3 G-S)
                                (setq G-IPT
                                       (list (car G-IPT)
                                             (- (cadr G-IPT)
                                                (* G-DWG-SCALE G-INS-SCALE G-HT-TILE G_SQUEEZE-FACTOR)
                                             0.0
                             (t
                                       G-BLK-MASTERI
                                       G-IPT
                                       "x"
                                       "0.0"
                                       G-ATTR-SYM
                                       G-ATTR-QTY
                                       G-ATTR-MFN
                                       G-ATTR-DSC
                                  (- (cadr G-IPT)
                                  0.0
              (progn (prompt "\n")
                     (CPF-BLINK (strcat "   **** MISSING ." G-I " FILE! ****") 3)
  (if (and G-IPT G_ATTR-MISS (setq G-BLK-MASTERI (findfile "CP_ksmiss.dwg")))
    (progn (if (tblsearch "BLOCK" "CP_ksmiss")
             (setq G-BLK-MASTERI "CP_ksmiss")
                    G-BLK-MASTERI
                    G-IPT
                    (* G-DWG-SCALE G-INS-SCALE (- 1 (/ (- 1 G_SQUEEZE-FACTOR) 2)))
                    "0.0"
           (setq G_MISSING-INFO t)
  (CPKS-MOVE-IF)
  (vl-cmdf "._UCS" "Prev")
;;;  Subfunction: CPKS-GET-SEM                                        ;
;;;  Description: This function returns a list of PROGRAM.SEM file     ;
;;;               containing information about which sheet series      ;
;;;               belongs to each project number.                      ;
(defun CPKS-GET-SEM (/ G-FILE-NM G-FILE-ID G-LST G-I G-LST-SEM)
  (if (and (caddr G_PATH) (cadr G_PATH))
    (cond
      ((setq G-FILE-NM (findfile (strcat (caddr G_PATH) "\\" (cadr G_PATH) ".sem")))
       (setq G-FILE-ID (open G-FILE-NM "r"))
         (setq G-LST (CPF-STR2LST G-I "|" NIL))
         (cond ((cadr G-LST)
                (setq
                  G-LST-SEM (append G-LST-SEM
                                    (list (list (car G-LST) (CPF-STR2LST (cadr G-LST) "," NIL)))
               (t (setq G-LST-SEM (append G-LST-SEM (list (list (car G-LST))))))
       (close G-FILE-ID)
  G-LST-SEM
;;;  Subfunction: CPKS-DO-REV-INSERTS                                 ;
;;;  Description: This function handles insertion of Revision schedules;
;;;               in title block.                                      ;
(defun CPKS-DO-REV-INSERTS (/ G-ATTR-DATE G-ATTR-BY)
  (setq G-LST NIL)
                      (if (equal (substr X 1 1) "R")
                        (setq G-LST (vl-sort (append G-LST (list X)) '<))
          G_LST-SYM
  (if G-LST
    (progn
            G-ATTR-DSC    NIL
            G-ATTR-DATE   NIL
            G-ATTR-BY     NIL
            G-SPEC-FILE   NIL
            G-HT-TILE     G-REVBLK-HT-TILE
            G-HT-HEADER   G-REVBLK-HT-HEADER
            G-WD-DSC      2.375
            G-WD-BY       0.5
            G-SPEC-FILE   G_SPEC-REV
	(setq G-BLK-HEADER  "CP_ksrev-m_v2"
	      G-BLK-HEADERX "CP_ksrev-mx_v2"
	      G-BLK-TILE    "CP_ksrev-t2_v2")
	(setq G-BLK-HEADER  "CP_ksrev-m"
	      G-BLK-HEADERX "CP_ksrev-mx"
	      G-BLK-TILE    "CP_ksrev-t2")
      (if (and (setq
                 G-SS (ssget "x"
        (setq G-IPT-L (cdr (assoc 10 (entget (ssname G-SS 0)))))
          (progn (terpri)
          (progn (terpri)
          (progn (terpri)
        (setq G-SPEC-FILE (CPF-SPEC-FILE "REV" NIL))
          (if (setq G-ASSO (assoc (substr G-SYM 2) G-SPEC-FILE))
            (progn
                    G-ATTR-DATE (nth 2 G-ASSO)
                    G-ATTR-BY   (nth 3 G-ASSO)
              (if
                (or
                  (and
                    G-ATTR-DSC
                    (> (caadr
                         (textbox
                           (list (cons 1 G-ATTR-DSC) '(40 . 0.095) '(41 . 0.75) '(7 . "KEYNOTE"))
                       G-WD-DSC
                  (and
                    G-ATTR-BY
                    (> (caadr
                         (textbox
                           (list (cons 1 G-ATTR-BY) '(40 . 0.095) '(41 . 0.75) '(7 . "KEYNOTE"))
                       G-WD-BY
                 (setq G-BLK-HEADER G-BLK-HEADERX)
                 (setq G-BLK-HEADER G-BLK-HEADER)
            (progn (setq G-ATTR-SYM  (substr G-SYM 2)
                         G-ATTR-DSC  ""
                         G-ATTR-BY   ""
                         G-ATTR-DATE ""
                         G_ATTR-MISS t
                   (prompt "\n")
            (progn (vl-cmdf "._-insert"
                            G-BLK-TILE
                            G-IPT-L
                            "x"
                            "0.0"
                   (setq G-IPT-L    (list (car G-IPT-L)
                                          (+ (cadr G-IPT-L) (* G-DWG-SCALE G-INS-SCALE G-HT-HEADER))
                                          0.0
                         G-TITLE-ON t
                   G-BLK-HEADER
                   G-IPT-L
                   "x"
                   "0.0"
                   G-ATTR-SYM
                   G-ATTR-DSC
                   G-ATTR-BY
                   G-ATTR-DATE
          (setq G-IPT-L
                 (list
                   (car G-IPT-L)
                   (+ (cadr G-IPT-L) (* G-DWG-SCALE G-INS-SCALE G-HT-TILE G_SQUEEZE-FACTOR))
                   0.0
          (progn (prompt "\n") (CPF-BLINK (strcat "   **** MISSING .REV FILE! ****") 3))
;;;      (if G_IPT-L
;;;        (if (< (nth 1 G-IPT-L) (nth 1 G_IPT-L))
;;;          (setq G_IPT-L G-IPT-L)
    (if (and (setq
               G-SS (ssget "x"
;;;  (if G_IPT-L
;;;    (setq G-IPT-L G_IPT-L)
  (princ)
(defun CPKS-DO-REV-SORT (G-VAL)
  (if G-VAL
    (atof (strcat (itoa (length (vl-string->list G-VAL)))
                  (itoa (- (last (vl-string->list G-VAL)) 65))
    0
;;;  Subfunction: CPKS-MOVE-IF                                        ;
;;;  Description: This function moves Stenciling and Revision Schedules;
;;;               if Parent Sheet has 85x11 title block.               ;
(defun CPKS-MOVE-IF (/ G-SS G-SS-TMP G-EN G-ED G-BN G-IP G-REV-IPT G-STE-IPT G-IPT0)
  (if (and (equal G-TB-NM "85X11")
           (equal (car G_FILE-ID) "SHT")
                             (list
                               '(0 . "INSERT")
                               '(-4 . "<or")
                               '(2 . "CP_ksste-t*,CP_ksste-m*,CP_ksste-b*")
                               '(-4 . "or>")
    (progn (setq G-CNT 0)
           (while (> (sslength G-SS) G-CNT)
             (setq G-EN  (ssname G-SS G-CNT)
                   G-ED  (entget G-EN)
                   G-BN  (cdr (assoc 2 G-ED))
                   G-IP  (cdr (assoc 10 G-ED))
                   G-CNT (1+ G-CNT)
             (cond ((member G-BN '("CP_ksrev-m" "CP_ksrev-mx"))
                    (if (> (cadr G-IP) (cadr G-REV-IPT))
                      (setq G-REV-IPT (list (car G-IP) (+ (cadr G-IP) (* 0.25 G-DWG-SCALE)) 0.0))
                   ((= G-BN "CP_ksste-t") (setq G-STE-IPT G-IP))
           (if G-REV-IPT
             (setq G-IPT0 G-REV-IPT)
             (if G-STE-IPT
               (setq G-IPT0 G-STE-IPT)
           (if (and G-IPT0 G-IPT)
             (vl-cmdf "._move" G-SS "" G-IPT0 G-IPT)
(defun CPKS-SURVEY (/ G-E G-ED G-SSLG G-SSCNT)
  (setq G-SSCNT 0
        G-SSLG  (sslength G-SS)
  (while (> G-SSLG G-SSCNT)
    (setq G-E     (ssname G-SS G-SSCNT)
          G-ED    (entget G-E)
          G-EIPT  (list (nth 1 (assoc 10 G-ED)) (nth 2 (assoc 10 G-ED)))
          G-SSCNT (1+ G-SSCNT)
    (if (not G_SURVEYSC)
      (setq G_SURVEYSC (cdr (assoc 41 G-ED)))
    (if (not G_SURVEYIPT)
      (setq G_SURVEYIPT G-EIPT)
      (if (> (cadr G-EIPT) (cadr G_SURVEYIPT))
Message 23 of 38
ec-cad
Wow, a lot of code there. I think you need to change lines 315-322.
The (vla-map-collection ... is getting 'all' the MLeaders in the entire .dwg file database, not just those that are
on the current tab.
For additional posting, please just attach the Lisp, or a fragment of it, for downloading.
ECCAD
Message 24 of 38
MrJSmith
I see. This makes more sense now. If the XREF on the paper space layout contains only the relevant information required  (i.e. it isn't being clipped/viewported) then it would be better to cycle through each layout and grab the xref on that layout and pull the keynotes/mleaders from it. Right now it seems to be cycling through all the possible xrefs and grabbing all the related info? But I can't be 100% sure because I don't see where/how all these functions are being called.
@ec-cad Lines 315-322 isn't the problem, assuming he implemented the filter change from the previous posts as it is only checking objects based on the SSGET function.
The function "CPKS-GET-SYMBOLS" was written to process ALL keynotes in ALL spaces and XREFS. If you want to modify it to do only the given tab, I'd make a new function entirely with an input for what tab to process. You'd then modify the ssget function from earlier to only take the requested tab so it only grabbed the blocks on that tab. Then you'd also need to modify the XREF function starting at 385 to include a check that the XREF it is pulling is on the requested tab.
If doing the ctab method from before, you'd replace lines 386/387 (above) with something like this....
(vlax-for la (vla-get-layouts (vla-get-activedocument (vlax-get-acad-object))) ;la is each layout in the drawing
	(if (= (getvar 'ctab) (vla-get-name la)) ;If the current tab you are on is the same name as the layout it is scanning, run the function
		(vlax-for G-I (vla-get-block la) ;only search the blocks on that specific layout
			;...everything from line 388 onwards
As for the double post, you could edit one and delete everything from it so the thread isn't so long.
Message 25 of 38
Do i still need to include these lines of code from earlier?
(setq G-SS
             (ssget (cons 410 (getvar 'ctab))
and did i insert your code properly?
Message 26 of 38
MrJSmith
@christian_paulsen98V29 Yes, you'd still need the code from earlier as it is limiting the search inside the currently open drawing to be only on the currently viewed tab. It will grab any keynotes placed in your drawing on that layout tab.
Yes, that insertion looks correct. Sadly I don't have the dwgs you are attempting this on so I can't say that it will work 100%, but it should be very close to what you are looking for (if I understand the setup correctly).
Message 27 of 38
I cannot for the life of me input the code you gave me without getting an error code. Malformed list on input which means there's an uneven amount of brackets correct? I tried everything i know how to do to find the messed up part and fix it, but couldn't do it. Any chance someone can modify the attached lisp file and send it back?
Message 28 of 38
komondormrex
any chance to see kinda sample of what to be processed with before and after state? i am going to rewrite that subroutine.
Message 29 of 38
Attached below is what a finished product looks like.
This is a single paperspace layout. On this layout there are 6 fabrications. Each of those fabrications are their own unique xref. All dimensions, mleaders, text, or other annotation are within the xrefs.
The only things that are not within the xref and are actually in the paperspace layout are the title block, the revision cloud, and all the keynotes.
The part at the top of the keynotes that says "keynoting schedule" is part of the title block. The individual keynotes below that are all separate blocks that are inserted on top of one another through this lisp routine.
Ill attach another screenshot below.
This is what an example of one of the keynoting blocks that gets inserted looks like. It puts in the symbol for the keynote, then is connected to a database where it looks up that number and pulls any information associated with that number (the part number and part name).
The keynotes that are in the xreffed fabrication files are a combinations of symbol blocks, or mleaders connected to that symbol block. Each one of those symbol blocks has an attribute where the number for that keynote is entered. Also youll notice the symbol blocks are all different shapes, each of those shapes represents something different (steel, aluminum, paint, laminate, hardware, fabrications, ect).
See symbol block examples below.
Soooooooooo. The whole point of this command is to look at all the xrefs on the CURRENT page, extract any symbol blocks that are used and the numbers associated with them, then insert the keynote block in the top right with the correct symbol and information.
I hope this makes sense.
Message 30 of 38
ec-cad
I have Acad 2021 Win10 Pro.
I saved that lisp, renamed to 'bb.lsp' (so I didn't have to type that long name).
Loaded it in Acad, no issues with 'loading' giving me an error. That's typically when you
would get the error "Malformed list on input" ...
All I got was (load "c:/disk8/bb") .. CPKE-SURVEY (which is the last Function),
so it looks good for loading.
Do you get that message when you 'run' the program ?
ECCAD
Message 31 of 38
MrJSmith
@christian_paulsen98V29 It makes sense what you are attempting to do; however, that isn't what the current LISP routine does. It was written explicitly to grab all the xrefs in the entire dwg, regardless of what layout they were on. Not sure why if the goal was to do what you described above. Makes it seem like it never worked properly? Or there was only ever one layout per drawing? As @komondormrex pointed out, it would probably be best to re-write it to handle your situation properly.
Message 32 of 38
The file that i attached was the unedited version of the code where i hadnt changed anything from the original code. It does not have any of the suggestions that you guys had mentioned.
Message 33 of 38
Yes our current workflow is that every single paperspace layout is its own dwg file. So if you have a 40 page document, its 40 separate dwgs.
I'm trying to eliminate that nonsense and make it to where we are able to have a single dwg file with multiple layouts.
The company i work for developed all this stuff way back in like the 1980s and has not bothered to update it since. Paperspace wasn't even a thing when they developed their standards. We only started using paperspace in the last couple of months. (I just started here not too long ago, and my previous company was the complete opposite and always had the most up to date tools and best practices.)
Message 34 of 38
komondormrex
hey, are you still there?
check the rewritten 'cpks-get-symbols' function.
hth.
;	gets and returns symbols from current space only
;   komondormrex, nov 2024
(defun cpks-get-symbols (/ end_pattern_list)
	(setq end_pattern_list '(
								PNT MAT ALUM STEEL ELEC FAB HDWE FABTEXT CP_KNMAT CP_KNPNT CP_KNHDW CP_KNELC CP_KNALM CP_KNSTL
								CP_KNFAB CP_KNFAB2 CP_KNFAB3 CP_KNPAR CP_KNPAR2 CP_KNPAR3 CP_KNREV CP_FTAG CP_FABTAG CP_FABTAG-S
								CP_FABTAG-XS CP_FABTAG-L CP_FABTAG-XL CP_PARTAG CP_PARTAG-S CP_PARTAG-XS CP_PARTAG-L CP_PARTAG-XL
	(defun add_to_list (member_ list_)
	 	(if (not (member (setq member_ (strcase member_)) list_))
			(append list_ (list member_))
			list_
	(defun parse_tags (tag_value_list / tag value g-part g-sym-part g-lst-sym)
		(foreach tag_value_set tag_value_list
			(foreach tag_value tag_value_set
				(setq tag (car tag_value)
					  value (cdr tag_value)
				(cond
					((member tag (list "FAB" "FABNUM"))
						(setq g-lst-sym (add_to_list value g-lst-sym))
					((member tag (list "FABNO"))
	               			  g-sym-part value
					((member tag (list "PART"))
						(setq g-part value)
	    		    ((member tag (list "F" "KNF"))
	    		   		(setq g-sym-part (strcat "F-" (cond ((= (strlen value) 3) (substr value 1))
	    		   		                               		((= (strlen value) 2) (strcat "0" (substr value 1)))
	    		   		                               		((= (strlen value) 1) (strcat "00" (substr value 1)))
	    		   		                               		(t (substr value (- (strlen value) 2)))
							  g-lst-sym (add_to_list g-sym-part g-lst-sym)
	    		       	(if (not (member (strlen value) '(5 3)))
	    		       		(setq g-lst-badfab (add_to_list value g-lst-badfab))
	    		    ((member tag (list "M" "P" "H" "E" "A" "S" "R" "PNT" "MAT" "ALUM" "STEEL" "ELEC" "HDWE"))
						(setq g-lst-sym (add_to_list (strcat (substr tag 1 1) value) g-lst-sym))
	    		  	((member tag (list "KNP" "KNM" "KNH" "KNE" "KNA" "KNS"))
						(setq g-lst-sym (add_to_list (strcat (substr tag 3 1) value) g-lst-sym))
	        (if (and g-part g-sym-part (not (assoc g-sym-part g_lst-parts)))
	            (setq g_lst-parts (append g_lst-parts (list (cons g-sym-part g-part))))
	        (setq g-sym-part nil g-part nil)
		g-lst-sym
	(defun parse_current_space (/ tag_value_list)
		(defun parse_collection (block)
			(vlax-map-collection block
				'(lambda (object)
					(cond
						((and (= "AcDbBlockReference" (vla-get-objectname object))
							  (null (vlax-property-available-p object 'path))
							  (vl-some '(lambda (pattern) (wcmatch (strcase (vla-get-effectivename object)) (strcat "*" (vl-symbol-name pattern))))
										end_pattern_list
							  (minusp (vlax-get object 'hasattributes))
							(setq tag_value_list (append tag_value_list (list (mapcar '(lambda (attribute) (cons (vla-get-tagstring attribute)
																												 (vla-get-textstring attribute)
														  						 	   (vlax-invoke object 'getattributes)
							(parse_collection (vla-item (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))) (vla-get-name object)))
						((and (= "AcDbMLeader" (vla-get-objectname object))
							  (/= "" (setq ml_block_name (vla-get-contentblockname object)))
							  (vl-some '(lambda (pattern) (wcmatch ml_block_name (strcat "*" (vl-symbol-name pattern))))
										end_pattern_list
							  (null (setq tag_value_sub_list nil))
				     		  	'(lambda (sub_object) (if (= (vla-get-objectname sub_object) "AcDbAttributeDefinition")
														(setq tag_value_sub_list (append tag_value_sub_list
																						(list (cons (vla-get-tagstring sub_object)
																										object
																										(vla-get-objectid sub_object)
							(setq tag_value_list (append tag_value_list (list tag_value_sub_list)))
						(t)
		(parse_collection (vla-get-block (vla-get-activelayout (vla-get-activedocument (vlax-get-acad-object)))))
		tag_value_list
	(setq g_lst-parts nil g-lst-badfab nil)
	(parse_tags (parse_current_space))
;	(if g-lst-badfab
;    	(foreach g-badfab g-lst-badfab
;    	  (cpf-blink (strcat "\n**** Fabrication Tag " g-badfab " has incorrect number! ****") 24)
Message 35 of 38
In the overall code does is this meant to replace all the way from
DOWN TO
Message 36 of 38
komondormrex
yep, all the function 'CPKS-GET-SYMBOLS' definition. and do not uncomment checking 'g-lst-badfab'.
Message 37 of 38
It works! So far ive ran it through a few tests and it hasnt given me any issues so far. Ill have to keep running it through some trials. I guess if i get any errors ill keep you posted.
Message 38 of 38
Hello. Thank you for all the help in the past. I'm hoping you might be able to help me again since you're the person who created the original working code.
I just realized that while in the process of making this lisp work for individual layouts instead of the whole document, we lost the functionality to read blocks from mleaders along the way. Which was the original reason for this post.
So as of right now everything is working just fine and i havent had any errors. I just need to add the ability back in so that mleaders can be read. Its just a simple mleader that has the keynote block attached to it.
