Extend code with extra plot functionality
Marcelhoogteijling
Marcelhoogteijling
(vl-load-com)
(setq adoc (vla-get-activedocument (vlax-get-acad-object)))
(vlax-for layout (vla-get-layouts adoc)
  (if (/= (vla-get-name layout) "Model")
    (progn
    (vla-put-ShowPlotStyles layout :vlax-true)
    (vla-put-StyleSheet layout "lucht.ctb")
(princ)
This script works perfect.
But, I like to extend the functionality of the script with:
- In the modelDisplay plotstyles has to be off.
- In the modelPlot style table has to be none.
Is there somebody who can adjust the code for me?
Kind regards Marcel
Here is the original post, because it's a solved post I opend this one.
Original post
pbejse
(vl-load-com)
  (setq data
	 (if (eq (vla-get-name layout) "Model")
	  '(0 "") '(-1 "lucht.ctb")
    (mapcar '(lambda (a b)
	       (vlax-put layout a b))  (list 'ShowPlotStyles 'StyleSheet) data)
(princ)
HTH
Sea-Haven
using original code
(vlax-for lay (vla-get-layouts (vla-get-activedocument (vlax-get-acad-object)))
(if (= (vla-get-name lay) "Model")
  (progn
  (vla-put-ShowPlotStyles lay :vlax-false)
  (vla-put-StyleSheet lay "")
  (progn
  (vla-put-ShowPlotStyles lay :vlax-true)
  (vla-put-StyleSheet lay "Luch.ctb")
Marcelhoogteijling
Message 2 works perfect, thanks a lot
Kind regards Marcel
Marcelhoogteijling
Message 3 doesn't work but the one before, Message 2, works fine.
So I'm happy.
Kind regards Marcel
