Export Table
Export Table
Message 1 of 24
Export Table
My original goal was to export a table with the push of a button. I've looked at vba and lisp methods. However, I'm struggling with identifying the table with any method. This is as close as I've made it. I want to name the exported file ( .csv ) as the current layout tab name. I don't want to see the dialog box. When using the lisp below, I have to select the table first which I can live with.
The table I export is a material list and I sometimes have as many as five tabs in one file I have to export. I would be fine with switching to each tab in order to run this procedure.
I have limited experience with lisp and no experience with AutoCAD vba but, have used it with excel. Would someone help point me in a better direction.
(defun c:tabx()
	(command "tableexport" "" "test.csv")
	(princ "\nTable Export Complete:")
	(princ)
) ;_end of defun
Steve.
Replies (23)
Message 21 of 24
aridzv
Not only extensive but also clean,run fast,give very good results and it put me in another programming language.
and I used it a lot all ready...
But I started this question from lisp and I wondered if it is possible to do it with lisp?
aridzv.
Message 22 of 24
Sea-Haven
I posted an answer that is lisp.
Message 23 of 24
aridzv
@Sea-Haven
Hi.
do you mean using your "insimage" function from "Alan Excel.lsp" inside "tab2excel.lsp" after exporting the table images?
Message 24 of 24
Sea-Haven
Yes the lisp code is for insert an image in Excel.in Alan Excel.lsp is lots of functions you need to copy them out and use in your code.
