Explode Command & SSGET
steelcitymetal
steelcitymetal
If I use:
(command "erase" (ssget) "")
all objects I select are erased.
However, if I change it to:
(command "explode" (ssget) "")
only the LAST object that was selected is exploded.
What is going on here?  Why is it not exploding all items selected?
Edit: The object type I am testing this on are closed polylines.
Obviously I plan on adding more to this, but here is the "full" code which is not exploding all selected objects (only the last object selected):
(defun c:xc()
Ranjit_Singh
There are different command versions that can be invoked. Before calling explode set the command version to 2
(initcommandversion 2)
steelcitymetal
That works, thanks.
To set it back, do I just use (initcommandversion) ?
Ranjit_Singh
initcommandversion applies only to the command that follows. It should go back to current version right after the command ends. You shouldn't have to do anything.
已半已满
Community Visitor
Community Visitor
thanks a lot , this is exactly what i am looking for.
