Explode Command & SSGET
steelcitymetal
steelcitymetal
If I use:
(command "erase" (ssget) "")
all objects I select are erased.
However, if I change it to:
(command "explode" (ssget) "")
only the LAST object that was selected is exploded.
What is going on here?  Why is it not exploding all items selected?
Edit: The object type I am testing this on are closed polylines.
Obviously I plan on adding more to this, but here is the "full" code which is not exploding all selected objects (only the last object selected):
(defun c:xc()
Ranjit_Singh
There are different command versions that can be invoked. Before calling explode set the command version to 2
(initcommandversion 2)
steelcitymetal
That works, thanks.
To set it back, do I just use (initcommandversion) ?
Ranjit_Singh
initcommandversion applies only to the command that follows. It should go back to current version right after the command ends. You shouldn't have to do anything.
