Error while making block if block name already exists
Hi everybody,
I have made a lisp for creating blocks with certain parameters. If the block name already exists the function gets canceled. Can I somehow provide a option to stop or continue redefining the block
(defun c:blkmake ()
  (command "undo" "be")
  (princ "\nSelect the objects |||| Cannot redefine blocks")
  (setq obj (ssget))
  (initget 1 " YES NO ")
  (setq	keywordclr
	 (getkword "\nChange Block color to BYBLOCK? [ YES / NO ]: <YES>")
  (if (eq keywordclr "YES")
    (change_byblock)
  (setq	keyword
	 (getkword "\nBlock has Center line? [ YES / NO ]: <YES>")
  (if (eq keyword "YES")
    (change_color)
  (princ "\nSpecify insertion base point: ")
  (setq pnt (getpoint))
  (princ "\nEnter block name: ")
  (setq name (getstring t))
  (command "_.-block" name pnt obj "")
  (command "insert" name pnt "1" "1" "0" "")
  (setq	ukeyword
	 (getkword "\nScale BLock Uniformly? [ YES / NO ]: <YES>")
  (if (eq ukeyword "YES")
    (scale_uniformly)
  (command "undo" "end")
(defun change_byblock ()
  (command "CHPROP" obj "" "LAYER" "0" "")
  (command "CHPROP" obj "" "COLOR" "BYBLOCK" "")
  (command "CHPROP" obj "" "LTYPE" "BYBLOCK" "")
  (command "CHPROP" obj "" "LWEIGHT" "BYBLOCK" "")
(defun change_color ()
  (princ "\nEnter color code")
  (setq ccolor (getint))
  (setq cobj (ssget))
  (command "CHPROP" cobj "" "COLOR" ccolor "")
  (command "CHPROP" cobj "" "LTYPE" "CENTER" "")
(defun scale_uniformly ()
  (command "-bedit" name "scale_uniformly")
Kent1Cooper
(if (tblsearch "block" name)
  (progn
    (initget "Yes No")
    (setq redef (getkword "\nBlock name exists -- redefine? [Yes/No]: "))
    (if (= redef "Yes")
      (command "_.block" …include Yes answer to redefinition
    ); if
  ); progn
); if
(command "_.insert" ….
Kent Cooper, AIA
Thank you
It works but, the following command doesn't execute & how do i make the code if block name doesnot exists
Kent1Cooper
@Anonymous wrote:
.... if block name doesnot exists ....
I didn't quite think it all the way through.  Try this:
  (progn ; then
    (initget "Yes No")
    (if (= redef "Yes")
    ); if
  ); progn
  (command "_.block" ; else …without that answer
); if
Kent Cooper, AIA
Thank you that worked perfectly!!!
