Error when creating annotation scale
Browning_Zed
Browning_Zed
Good afternoon, forum members.
I am trying to create a scale using the following function:
 (defun CreateScale  ( nme dun lun / dictname )
	(setq dictname (cdr (assoc -1 (dictsearch (namedobjdict) "ACAD_SCALELIST"))))
	(dictadd dictname
		(entmakex
			(list
				'(0 . "SCALE")
				(cons 330 dictname)
				'(100 . "AcDbScale")
				'(70 . 0)
				(cons 300 nme)
				(cons 140 dun)
				(cons 141 lun)
				'(290 . 0)
Run the function:
(CreateScale "1:20" 50 1)
And this returns an error: too few arguments. What could be the reason?
hak_vz
Why no simple as this. This will create new annotation scale if its not already present
(defun CreateScale  (scalestr / scalelist *error*)
 (defun *error* () (setvar 'cmdecho 1) princ)
	(setq scalelist
		(vl-remove nil
			   (mapcar
				 (function
				   (lambda (x)
					 (if (eq (car x) 350)
					   (cdr (assoc 300 (entget (cdr x))))
	(setvar 'cmdecho 0)
	(cond
		((not (member scalestr scalelist))
			(command "-scalelistedit" "Add" scalestr scalestr "e")
		(T (princ (strcat "\n Scale " scalestr " already exist!")))
	(setvar 'cmdecho 1)
	(princ)
Usage :  (CreateScale "1:60")
Miljenko Hatlak
Browning_Zed
Thanks, it works, but I would like to be able to specify drawing units and paper units myself when creating a scale. That is, in the function, I need three arguments: scale name, drawing units, paper units.
hak_vz
String is formulated "paper_units : drawing units" and this is also name of the scale
Miljenko Hatlak
Browning_Zed
Yes, but I need the name to be different from units, options like this:
name: "1:20" | drawing units: 50 | paper units: 1
hak_vz
Ok then as simple as this
(defun CreateScale  (name paperunits drawingunits /  *error*)
	(setvar 'cmdecho 0)
	(command "-scalelistedit" "Add" name (strcat paperunits ":" drawingunits) "e")
	(setvar 'cmdecho 1)
	(princ)
Usage:
(CreateScale "whatever" paper_units drawing_units)
(CreateScale "whatever" "50" "1")
Miljenko Hatlak
Browning_Zed
Thanks a lot for your help, hak_vz.
