Error message
Error message
sam_safinia
Message 1 of 10
Error message
sam_safinia
What is thi error message for?
"Cannot invoke (command) from *error* without prior call to (*push-error-using-command*).
Converting (command) calls to (command-s) is recommended."
Replies (9)
Message 2 of 10
Ajilal.Vijayan
Can you give more details(AutoCAD version, Product) regarding when this error message shown ?
If you are running any lisp routine have you tried replacing the command to command-s as suggested in the error message ?
More about this error
Message 3 of 10
sam_safinia
You are right. It appears after running lisp. I got this in ver. 2015 & 16.
Message 4 of 10
Ajilal.Vijayan
Try after replacing command to command-s, or post the code here to check.
Message 5 of 10
Kent1Cooper
@Ajilal.Vijayan wrote:
Try after replacing command to command-s....
... but perhaps only (command) functions inside the *error* handler [typically used for Undo End but also possibly things like UCS resetting, etc.].  Read about (command-s) in Help, where the differences between it and (command) are described, as well as certain restrictions -- you can't simply replace all (command) functions with (command-s) functions.
Kent Cooper, AIA
Message 6 of 10
carlos_m_gil_p
Replace
command by command-s
vl-cmdf by command-s
So I fix myself.
I hope it helps you.
A greeting.
AutoCAD 2026.1.1
Visual Studio Code 1.105.1
AutoCAD AutoLISP Extension 1.6.3
Windows 10 - 22H2 (64 bits)
Message 7 of 10
sam_safinia
Actually replacing command-s didn't help. I am just curious regarding
version of CAD hat this lisp is written for which is quite old.It might be
version 12 or 13.
After running the routine the DCL appears and everything looks OK but when
start to invoke the lisp I get this error:
"ERR_CTRL version 1.4 loaded.
>From point:
To point:
The lisp is reading a config file and error control routine. I found this
code in error control lisp:
; Start an undo group so *error* can undo everthing that occured before
it was called.
; In R12 the command was Group, in R13 it was changed to Begin.
(if (< (atoi (getvar "ACADVER")) 13)
(command "_.UNDO" "_G")
(command "_.UNDO" "_BE")
) ;if
Message 8 of 10
Kent1Cooper
@s_plant wrote:
... when start to invoke the lisp I get this error:
>From point:
To point:
Cannot invoke (command) from *error* ....
There appears to be more wrong than just the (command)-in-*error* problem, if you're getting that message upon giving a point....  But in any case:
There should be something in your error handler that is similar to those Undo-related commands but with the End option, and that is where you should change function names from (command ...) to (command-s ...).  HOWEVER, if you are also running any computers with AutoCAD older than [I think] 2015, they won't recognize (command-s) as a function.  If you have AutoLisp routines with *error* handlers that need to run on both older and newer versions of AutoCAD, you may need to switch to (vla) methods of starting and ending the Undo wrapping, avoiding either (command) or (command-s).  Write back if that's what you need to do, or Search for
(vla-startundomark
to find examples of code that does it that way.
Kent Cooper, AIA
Message 9 of 10
sam_safinia
Thanks guys but still cannot run my lisp. I try on my end again and again...
Message 10 of 10
hmsilva
Hi s_plant,
would be easier to help, if you show us your code...
Henrique
