(DEFUN C:PS()
(SETQ
EW (GETREAL "\n Enter WIDTH OF PLOT:")
EL (GETREAL "\n Enter LENGTH OF PLOT:")
RW (GETREAL "\n ENTER ROAD WIDTH:")
ERS (GETREAL "\nEnter PLOT RIGHTSIDE SET BACK 1:")
ELS (GETREAL "\nEnter PLOT LEFTSIDE SET BACK 2:")
EFS (GETREAL "\nEnter PLOT FRONTSIDE SET BACK:")
EBS (GETREAL "\nEnter PLOT REARSIDE SET BACK:")
ST (GETPOINT "\nPick a point:")
ORSL (- EL (+ EFS EBS))
OFSL (- EW (+ ERS ELS))
RP1 (POLAR ST 0 EW)
RP2 (POLAR RP1 (/ PI 2) EFS) ; RIGHT SIDE SET BACK FIRST CORNER
LP2 (POLAR ST (/ PI 2) EFS) ; LEFT SIDE SET BACK FIRST CORNER
FP1 (POLAR ST 0 ELS) BP1(POLAR FP1 ( / PI 2) (- EL EBS))
TP1(POLAR ST 0 (/ EW 2)) TP2(POLAR TP1 ( / PI 2) (/ EL 2))
MP1(POLAR ST 0 (+ EW 20))
P2(POLAR ST (/ PI 2) EL) P3(POLAR P2 0 ELS)
RP1(POLAR ST (+ PI( / PI 2)) 10)
(SETQ P1 (POLAR ST 0 10))
(COMMAND "RECTANGLE" ST "D" EW EL P1) ; PLOT AREA
(SETQ OBJ1 (ENTLAST))
(COMMAND "RECTANGLE" ST "D" EW RW RP1) ; ROAD AREA
(SETQ ROBJ1 (ENTLAST))
(COMMAND "CHPROP" ROBJ1 "" "LA" "ROAD_WIDTH" "CO" 1 "")
; Change the layer and color of the first rectangle
(COMMAND "CHPROP" OBJ1 "" "LA" "PLOT_BOUNDARY" "CO" 70 "")
(COMMAND "COPY" OBJ1 "" "12,0" "12,0" "")(SETQ COBJ1(ENTLAST))
(COMMAND "CHPROP" COBJ1 "" "LA" "FMB_OR_PLR" "CO" 70 "")
(COMMAND "COPY" OBJ1 "" "16,0" "16,0" "")(SETQ COBJ2(ENTLAST))
(COMMAND "CHPROP" COBJ2 "" "LA" "AS_AT_SITE" "CO" 6 "")
(COMMAND "COPY" OBJ1 "" "18,0" "18,0" "")(SETQ COBJ3(ENTLAST))
(COMMAND "CHPROP" COBJ3 "" "LA" "SUPER_IMPOSED" "CO" 5 "")
(SETQ P1 (POLAR ST (/ PI 2) 10))
(COMMAND "RECTANGLE" RP2 "D" ERS ORSL P1) ; RIGHT SIDE SET BACK
(SETQ OBJ2 (ENTLAST))
; Change the layer and color of the second rectangle
(COMMAND "CHPROP" OBJ2 "" "LA" "BLK_1_LVL_0_SIDE_SETBACK1" "CO" 171 "")
(COMMAND "RECTANGLE" LP2 "D" ELS ORSL P1) ; LEFT SIDE SET BACK
(SETQ OBJ3 (ENTLAST))
; Change the layer and color of the third rectangle
(COMMAND "CHPROP" OBJ3 "" "LA" "BLK_1_LVL_0_SIDE_SETBACK2" "CO" 102 "")
(COMMAND "RECTANGLE" FP1 "D" OFSL EFS P1) ; FRONT SIDE SET BACK
(SETQ OBJ4(ENTLAST))
; Change the layer and color of the fourth rectangle
(COMMAND "CHPROP" OBJ4 "" "LA" "BLK_1_LVL_0_FRONT_SETBACK" "CO" 2 "")
(SETQ P1 (POLAR BP1 0 10))
(COMMAND "RECTANGLE" P3 "D" OFSL EBS P1) ; BACK SIDE SET BACK
; Change the layer and color of the fifth rectangle
(COMMAND "CHPROP" OBJ4 "" "LA" "BLK_1_LVL_0_REAR_SETBACK" "CO" 11 "")
(SETQ P1 (POLAR BP1 (+ PI (/ PI 2)) 10))
(COMMAND "RECTANGLE" BP1 "D" OFSL ORSL P1) ; BUILT UP AREA
(SETQ OBJ5(ENTLAST))
; Change the layer and color of the sixth rectangle
(COMMAND "CHPROP" OBJ5 "" "LA" "BLK_1_FLR_0_BLT_UP_AREA" "CO" 1 "")
(COMMAND "TEXT" "J" "MC" TP2 0.5 0 "Built up Area Draw Plan" "")(SETQ OBJ6(ENTLAST))
(COMMAND "CHPROP" OBJ6 "" "LA" "0" "CO" 7 "")
(COMMAND "COPY" OBJ5 OBJ6 "" ST MP1 "")
(COMMAND "COPY" OBJ5 "" "20,0" "20,0" "")(SETQ COBJ4(ENTLAST))
(COMMAND "CHPROP" COBJ4 "" "LA" "BLK_1_LVL_0_BLDG_FOOT_PRINT" "CO" 1"")
(COMMAND "COPY" OBJ5 "" "22,0" "22,0" "")(SETQ COBJ5(ENTLAST))
(COMMAND "CHPROP" COBJ5 "" "LA" "BLK_1_FLR_0_ROOF_AREA" "CO" 54 "")
(COMMAND "COPY" OBJ5 "" "24,0" "24,0" "")(SETQ COBJ6(ENTLAST))
(COMMAND "CHPROP" COBJ6 "" "LA" "BLK_1_COVERED_AREA" "CO" 140 "")
THIS CODE RUN SOMETIMES CORRECT MANY TIMES ERROR WHAT I MISTAKE THIS I ATTACHED FILE IN DETAIL EXPLAIN
Tell the exact values when it works and when not
See this command line listing. This is your help. One issue per bolded lines that needs to be fixed. Usually it's one extra "" or something like that.
Command: PS
Enter WIDTH OF PLOT:9.85
Enter LENGTH OF PLOT:15.83
ENTER ROAD WIDTH:3.00
Enter PLOT RIGHTSIDE SET BACK 1:0.76
Enter PLOT LEFTSIDE SET BACK 2:0.76
Enter PLOT FRONTSIDE SET BACK:3.00
Enter PLOT REARSIDE SET BACK:0.76
Pick a point:RECTANGLE
Specify first corner point or [Chamfer/Elevation/Fillet/Thickness/Width]:
Specify other corner point or [Area/Dimensions/Rotation]: D
Specify length for rectangles <8.33>: 9.849999999999999
Specify width for rectangles <12.07>: 15.83
Command: RECTANGLE
Specify length for rectangles <9.85>: 9.849999999999999
Specify width for rectangles <15.83>: 3
Command: CHPROP
Select objects: 1 found
Select objects:
Enter property to change [Color/LAyer/LType/ltScale/LWeight/Thickness/TRansparency/Material/Annotative]: LA
Enter new layer name <BLK_1_FLR_0_ROOM_1_LIGHT_VENTILATION_1>: ROAD_WIDTH
Enter property to change [Color/LAyer/LType/ltScale/LWeight/Thickness/TRansparency/Material/Annotative]: CO
New color [Truecolor/COlorbook] <1 (red)>: 1
Command: CHPROP
Select objects:
Enter new layer name <BLK_1_FLR_0_ROOM_1_LIGHT_VENTILATION_1>: PLOT_BOUNDARY
New color [Truecolor/COlorbook] <1 (red)>: 70
Command: COPY
Select objects:
Specify base point or [Displacement/Multiple] <Displacement>: 12,0
Specify second point or [Array] <use first point as displacement>: 12,0
Command: PS
Unknown command "PS". Press F1 for help.
Command: CHPROP
Select objects:
Enter new layer name <PLOT_BOUNDARY>: FMB_OR_PLR
New color [Truecolor/COlorbook] <70>: 70
Command: COPY
Select objects:
Specify base point or [Displacement/Multiple] <Displacement>: 16,0
Specify second point or [Array] <use first point as displacement>: 16,0
Command: PS
Command: CHPROP
Select objects:
Enter new layer name <PLOT_BOUNDARY>: AS_AT_SITE
New color [Truecolor/COlorbook] <70>: 6
Command: COPY
Select objects:
Specify base point or [Displacement/Multiple] <Displacement>: 18,0
Specify second point or [Array] <use first point as displacement>: 18,0
Command: PS
Command: CHPROP
Select objects:
Enter new layer name <PLOT_BOUNDARY>: SUPER_IMPOSED
New color [Truecolor/COlorbook] <70>: 5
Command: RECTANGLE
Specify length for rectangles <9.85>: 0.76
Specify width for rectangles <3.00>: 12.07
Command: CHPROP
Select objects:
Enter new layer name <BLK_1_FLR_0_ROOM_1_LIGHT_VENTILATION_1>: BLK_1_LVL_0_SIDE_SETBACK1
New color [Truecolor/COlorbook] <1 (red)>: 171
Command: RECTANGLE
Specify length for rectangles <0.76>: 0.76
Specify width for rectangles <12.07>: 12.07
Command: CHPROP
Select objects:
Enter new layer name <BLK_1_FLR_0_ROOM_1_LIGHT_VENTILATION_1>: BLK_1_LVL_0_SIDE_SETBACK2
New color [Truecolor/COlorbook] <1 (red)>: 102
Command: RECTANGLE
Specify length for rectangles <0.76>: 8.33
Specify width for rectangles <12.07>: 3
Command: CHPROP
Select objects:
Enter new layer name <BLK_1_FLR_0_ROOM_1_LIGHT_VENTILATION_1>: BLK_1_LVL_0_FRONT_SETBACK
New color [Truecolor/COlorbook] <1 (red)>: 2
Command: RECTANGLE
Specify length for rectangles <8.33>: 8.33
Specify width for rectangles <3.00>: 0.76
Command: CHPROP
Select objects:
Enter new layer name <BLK_1_FLR_0_ROOM_1_LIGHT_VENTILATION_1>: BLK_1_LVL_0_REAR_SETBACK
New color [Truecolor/COlorbook] <1 (red)>: 11
Command: RECTANGLE
Specify width for rectangles <0.76>: 12.07
Command: CHPROP
Select objects:
Enter new layer name <BLK_1_FLR_0_ROOM_1_LIGHT_VENTILATION_1>: BLK_1_FLR_0_BLT_UP_AREA
Command: TEXT
Current text style: "Standard" Text height: 0.77 Annotative: No Justify: Left
Specify start point of text or [Justify/Style]: J Enter an option [Left/Center/Right/Align/Middle/Fit/TL/TC/TR/ML/MC/MR/BL/BC/BR]: MC
Specify middle point of text:
Specify height <0.77>: 0.5
Specify rotation angle of text <0>: 0
Enter text: Built up Area Draw Plan
Command: PS
Command: CHPROP
Select objects:
Enter new layer name <BLK_1_FLR_0_ROOM_1_LIGHT_VENTILATION_1>: 0
Command: COPY
Select objects: 1 found, 2 total
Select objects:
Command: PS
Command: COPY
Select objects:
Specify base point or [Displacement/Multiple] <Displacement>: 20,0
Specify second point or [Array] <use first point as displacement>: 20,0
Command: PS
Command: CHPROP
Select objects:
Enter new layer name <BLK_1_FLR_0_BLT_UP_AREA>: BLK_1_LVL_0_BLDG_FOOT_PRINT
Command: COPY
Select objects:
Specify base point or [Displacement/Multiple] <Displacement>: 22,0
Specify second point or [Array] <use first point as displacement>: 22,0
Command: PS
Command: CHPROP
Select objects:
Enter new layer name <BLK_1_FLR_0_BLT_UP_AREA>: BLK_1_FLR_0_ROOF_AREA
New color [Truecolor/COlorbook] <1 (red)>: 54
Command: COPY
Select objects:
Specify base point or [Displacement/Multiple] <Displacement>: 24,0
Specify second point or [Array] <use first point as displacement>: 24,0
Command: PS
Command: CHPROP
Select objects:
Enter new layer name <BLK_1_FLR_0_BLT_UP_AREA>: BLK_1_COVERED_AREA
New color [Truecolor/COlorbook] <1 (red)>: 140
To add to the above, LISP version of the COPY command is different from the current built-it version. It's not multiple!
