Error: extra cdrs in dotted pair on input
alexander_palsson4FQND
Message 1 of 11
Hi
I have  tried to modify a Lisp routine my predecessor  made. Originally it changed layers on certain objects in a drawing. I also want to delete certain objects that are superfluous. I thought I got the hang of it when I sucessfully tested my modified Lisp on a specific object, but after adding code to cover the rest of the objects I wanted to get rid of, it no longer worked. The Lisp routine does not load on start as before and when I use drag and drop the command prompt reads "; error: extra cdrs in dotted pair on input".
Replies (10)
Message 2 of 11
EnM4st3r
in Line 73 you are missing a Quote
Message 3 of 11
You made my day, thank you! Any tips on how to debug my code? I use notepad to edit but when the lines starts to add up...
Message 4 of 11
paullimapa
You are missing quotes here in this section of your code:
Now it successfully loads but not sure if it all runs properly.
You'll have to test the various functions on your drawings.
Paul Li
IT Specialist
@The Office
Message 5 of 11
EnM4st3r
Im using Visual Studio Code with AutoLisp extension for debugging. You can link it with your open drawing, works pretty well for me.
Oh and also you maybe already saw it but there are also quotes missing in the Lines 75,77 and 79. 😉
Message 6 of 11
paullimapa
I use Visual Studio Code.
The way I debugged this is copying out various sections of your code to see if those load successfully.
Paul Li
IT Specialist
@The Office
Message 7 of 11
komondormrex
hey,
you need not compare sset with nil like this.
(if (/= (ssget "_X" '((8 . "Baskarta_grafikAgoslagsgrans_s"))) nil)
if it is it is, othewise nil.
(if (ssget "_X" '((8 . "Baskarta_grafikAgoslagsgrans_s")))
Message 8 of 11
EnM4st3r
wait you not using the AutoLisp extension? Because this gives you the Line and the positon in an instant
Message 9 of 11
paullimapa
these are the extensions I currently have loaded:
Paul Li
IT Specialist
@The Office
Message 10 of 11
Interesting I was actually wondering about that particular part of the code. Your solution looks a lot better :). Thank you!
Message 11 of 11
Thank you everyone for fixing my error and your tips on editor. I have just installed Visual code and I love it!
