ERROR Converting (command) calls to (command-s) is recommended.
sunlight1
Message 1 of 12
sunlight1
hi,
im trying to write a lisp that insert blocks fast by name with default settings (scale, angel etc)
if im writing the name of the block ok, everything is fine. (and i have no error)
but if im wrong, the lisp repeat itself like i wanted,
and even im writing ok, insert the block, all good.
after that i get an error
"Can't find file in search path:"
**here is a list of all my search paths**
"error: Function cancelled
Cannot invoke (command) from *error* without prior call to (*push-error-using-command*).
Command: *Cancel*"
why  i get that?
i thought if the 2nd time i do write the name of the block right, it wouldnt get me that error.
(defun c:IB (/ Bname )
		(setq Bname (getstring "enter block name: "))
		(if
			(null (findfile (strcat Blocks_path Bname ".dwg")))
			(progn
				(alert (strcat "Can't find  " Bname ".dwg in BLOCKS folder"
				"\nPlease try again"))
				(c:IB)
			);progn
		);if
		(command "_.insert" (strcat Blocks_path Bname ".dwg") pause)
		(while (> (getvar "CMDACTIVE") 0)
			(command "")
		);while
		(command ".explode" (entlast))
	(princ)
	);defun
Bname - is the block name
Blocks_path - is my blocks path folder already set in my accaddoc file
tnx for ure help 😃
Replies (11)
Message 2 of 12
Kent1Cooper
If you close AutoCAD and start over, and run no other routines before you try this, does it still give you that error?  I suspect you have some other AutoLisp routine that sets an *error* handler involving some (command) function(s), which has been frowned upon since [I think] Acad 2015, but only within custom *error* handlers.  A routine with a faulty one must not be setting AutoCAD's regular one back properly, but restarting should.  If that fixes it, any routines that have *error* handling should be corrected to assure they properly reset AutoCAD's.
Kent Cooper, AIA
Message 3 of 12
ВeekeeCZ
Not sure about your error but this recursive calling of yours is definitely not right. You can think of why.
Edit: I did not read your issue carefully - your issue actually is the wrong usage of recursive calling.
Say, you typed the wrong name. The routine re-calls itself. Now you type the right one (for simplicity). The routine will go thru to the end successfully. But after that, it continues to evaluate the rest of the routine from the initial wrong-name run.
  (if
    (progn
      (c:IB) ; it runs itself from here, and when is done, continues from here to finish the code
      );progn
    );if
	   (command "")
	   );while
    (princ)
    );defun
Then it fails on Bname still holding a wrong name - since it's localized it's not overwritten by the correct one from the new run.
Spoiler alert!
  (while (not (and (setq Bname (getstring t "Enter block name: "))
		   (or (findfile (strcat Blocks_path Bname ".dwg"))
		       (alert (strcat "Can't find  " Bname ".dwg in BLOCKS folder" "\nPlease try again"))))))
  (command "_.insert" (strcat Blocks_path Bname ".dwg") "_s" 1 "_r" 0 pause)
  (while (> (getvar "CMDACTIVE") 0) (command ""))
  (princ)
Message 4 of 12
Sea-Haven
The other option is also add is this block in dwg already, (tblsearch "block" bname).
If you wrap your enter block name in a while you can exit by say press Enter when you get frustrated with wrong answers.
(while (/= (setq Bname (getstring "\nenter block name: ")) "")
Message 5 of 12
ВeekeeCZ
Now, a challenge for ya. Why this code, still using a recursive call, is working just fain...
  (if (or (findfile (strcat Blocks_path Bname ".dwg"))
	  (c:IB))
	     ".explode" (entlast)))
  ; (princ)
  );defun
Message 6 of 12
sunlight1
first of all i was busy on the weekend, so im sorry that i couldnt answer faster.
@Kent1Cooper  i did restart and the problem didnt go anywhere.
@ВeekeeCZ
first of all i knew that "(c:IB)"  is probably a wrong way to go with.
but i couldnt think of another way, myb i went for the "short lazy way"
this is intersting what ure saying
since Bname is localized,  combine with recall IB  im ending with 2 different lisps
1 successfully closed and 1 still open with a  wrong value.
what a mess =(
i wont go with recalling again.
anyway, ure spoiler is working tnx. thats a better way to do it
and for ure last messege - its working fine cos u use OR, which is filtering all wrong values of Bname and stuck them in the IF.
only 1 TRUE  Bname will send him free to the insert command,
while i went on the NULL "way" ,  collected all the wrong values and activate PROGN on them and sent them free from the loop with calling IB again.
i hope i got it.
BTW u have ";" at the (princ) 🙂
Message 7 of 12
ВeekeeCZ
Ok, ok, you're good!!
Yeap! That's the one! The challenge. Why I did do it? And can you fix it for me? It's not nice. 🤔
Message 8 of 12
sunlight1
@ВeekeeCZ
no im not THAT good.
im still learning, started 8 months ago fron 0 lol so far i know how the code goes, but sometimes not the details.
so plz explain why did u do it.
i know princ at the end came to clear the end line
but why in ure code if i use princ it will get error?
i tried to search about it but no luck.
i guesss shame on me if u thought i know that
i just pointed on the ";" cos u didnt activated the (princ), i thought the princ should be there.
while the opposite is correct.
Message 9 of 12
ВeekeeCZ
No worries. Called it a challenge for a reason.
Here's a hint for you: (and (princ))
Message 10 of 12
sunlight1
ok i got it.
but now please explain to me what true about that princ? or why he has to be inside ?
and my lisp still returns nil at the end? is that cos the "and" returns nil?
so basictly ill always get nil in that lisp structure. (i dont care much but just for explaining what happend here)
p.s- acording to that lisp below , i dont need the while  CMDACTIVE-0 from my post? seems to me that its working just fine, even on Dynamic blocks
(defun c:IB (/ Bname ) ;insert block by name
	(and
			(c:IB))
		);if
	(princ)
	);and
);defun
Message 11 of 12
ВeekeeCZ
	  (c:IB))
  ; (princ)
  );defun
Remember, any value but nil, is True.
So, when it's returning from the second run to finish the first one, you need to make sure that (c:IB) returns nil, -> OR=nil, IF=nil, therefore it's not inserting any other block.
(c:IB) function returns the value of the last expression inside. In this case, it was (princ), which is T. If (princ) is commented out, then the last one would be IF. And IF would return:
- if the condition statement of IF is T, it returns T/nil of THEN statement, which is (command...) which returns always nil.
- if cond of IF is nil, and there is no ELSE statement, then the result is nil (never happens in this case)
- if cond of IF is nil, and there is some ELSE statement, it returns T/nil of ELSE (irrelevant for this case).
So... another possible solution is:
	  (not (c:IB))
	     "_.explode" (entlast)))
  (princ)
Your solution....It's a mess that luckily works and you have no idea why.
Message 12 of 12
sunlight1
its a mess right lol
but after ure explanation, i know what i didnt knew before
that i had to ensure c:IB is nil before the end.
after u said it, i know why my lisp is working.
my last expression is AND which has IF and PRINC
the IF will always return NIL cos the THEN is a command that always returns NIL.
so the AND will always return NIL.
then c:IB will get NIL.
yea, i didnt know that, thats why i asked for an explanation.
tnx for the challenge it was great !
