Block seperation using WBlock routine
oosterop
oosterop
I am looking for a routine that can make individual DWGs of all existing blocks in one drawing.
What I mean: we have a drawing with around 1000 blocks in it, which we want to store in separate DWGs
Thanks in advance.
Kr Erwin
ВeekeeCZ
It's really like 2 sec of googling.
HERE or THIS
ronjonp
Here's my simple offering:
(defun c:exportblocks (/ p)
  (setvar 'cmdecho 0)
  (setq p (strcat (getvar 'dwgprefix) "_ExportedBlocks\\"))
  (vl-mkdir p)
  (vlax-for b (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))
    (if	(= 0 (vlax-get b 'isxref) (vlax-get b 'islayout))
      (command "._-wblock" (strcat p (vla-get-name b) ".dwg") (vla-get-name b))
  (setvar 'cmdecho 1)
  (alert p)
  (princ)
oosterop
Thanks for your message, @ronjonp ! I've tested it and it works perfectly. Apologies for this very delayed response, I've been out of action for a while, hence the delay.
If I may delve a bit deeper into my question and your solution.
We're dealing with a lot of embedded blocks, and manually going through everything is impossible for this quantity. Could you modify the routine so that it creates a separate folder named after the embedded block, and then separates the underlying block within it? After or during the process of going through the first list of blocks (your initial routine).
Many thanks in advance.
Kr Erwin
ronjonp
@oosterop
Post a sample file.
