Error control for selecting viewports
Message 1 of 11
I'm using this code to select a viewport
(setq ENT (entget (car (entsel "\nSelect viewport: "))))
If the user selects anything else I get this error: "error: bad argument
type: lentityp"
How do I provide error checking so that the user can only select a viewport.
Mark A. Carter
CAD Administrator
NJRA Architects
www.njraarchitects.com
Replies (10)
Message 2 of 11
Try this outline ...
(defun c:test ( / ent dat)
(if (setq ent (entsel "\nSelect viewport: "))
(cond
( (eq "VIEWPORT" (cdr (assoc 0 (setq dat (entget (car ent))))))
(princ "\nEntity selected WAS a viewport.")
; other code
( t
(princ "\nEntity selected was not a viewport.")
; other code
(princ "\nNo entity selected.")
(princ)
________________________________
puckettm@bantrel.com
> Not < an AutoDESK classroom monitor
Imagination makes all things possible
Mark Carter wrote in message <8b8pu5$6s321@adesknews2.autodesk.com>...
type: lentityp"
Mark A. Carter
CAD Administrator
NJRA Architects
Message 3 of 11
I think you have to break your code into 2 steps to avoid an
error caused by no entity (lentityp) being selected.
(setq ENT (car (entsel)))
(if ENT
(setq ENTEAL (entget ENT))
(cond
((= (cdr (assoc 0 ENTEAL) "VIEWPORT"))
... do something entertaining & worthwhile
(T
(princ "\nEntity selected not a VIEWPORT")
Something like that would work.
"Mark Carter" wrote in message
news:8b8pu5$6s321@adesknews2.autodesk.com...
> type: lentityp"
viewport.
> Mark A. Carter
> CAD Administrator
> NJRA Architects
Message 4 of 11
Try this. it allows you to specify what type of entity you will accept from
ENTSEL. (SelectEntity "viewport") for example. I'm sure there's a tighter
way to do this so I sure would appreciate any constructive criticism anyone
has to offer.
(defun SelectEntity (enttype / ent catch retval)
(while (not ent)
(setq
catch (vl-catch-all-apply
'entsel
(list (strcat "\nSelect a " (strcase enttype T) ": "))
(if (not (vl-catch-all-error-p catch))
(if (setq ent (car catch))
(if (= (cdr (assoc 0 (entget ent))) enttype)
ent
(progn
(princ
(strcat "\nThat entity is not a " (strcase enttype T))
(setq ent nil)
(princ "\nNothing selected. Try again.")
(progn
(setq ent T)
retval
Get free software and more at http://www2.stonemedia.com/franko
> type: lentityp"
viewport.
> Mark A. Carter
> CAD Administrator
> NJRA Architects
Message 5 of 11
That will still cause the error when someone picks
empty space (because you are attempting to (car nil). Do this:
(while (null (setq ENT (entsel
> (if ENT
color=#ff0000>     (setq ENTEAL (entget (car
ENT)))
(cond
>         ((= (cdr (assoc 0
ENTEAL)
"VIEWPORT"))
worthwhile
(T
VIEWPORT")
R. Robert Bell, MCSE
Network
Administrator (or, Modern-day Wizard)
face=Arial size=2>>     I think you have to break your code
selected.
> (if ENT
(cond
>         ((= (cdr (assoc 0
            ... do
        (T
           (princ "\nEntity
> "Mark Carter" <
href="mailto:marcar@njraarchitects.com">marcar@njraarchitects.com
> wrote
in message
href="news:8b8pu5$6s321@adesknews2.autodesk.com">news:8b8pu5$6s321@adesknews2.autodesk.com
> > If the
type: lentityp"
can only select a
> viewport.
> > Mark A. Carter
> > CAD Administrator
NJRA Architects
href="http://www.njraarchitects.com">www.njraarchitects.com
Message 6 of 11
That's ok - I didn't see you either 🙂
Joe Funk wrote in message <8b8seh$6s120@adesknews2.autodesk.com>...
(Sorry, Michael, I didn't see you.)
Message 7 of 11
I've been using "=" in these situations forever. I take it the
"=" works because it's comparing the numerical values of the
2 strings?
At any rate, it's "eq" for me henceforth.
"Michael Puckett" wrote in message
news:8b8rcf$6td31@adesknews2.autodesk.com...
> (cond
> ; other code
> ( t
> ; other code
> (princ)
> type: lentityp"
viewport.
> Mark A. Carter
> CAD Administrator
> NJRA Architects
Message 8 of 11
Thanks, to both of you. That did the trick.
I had my (cond) in the wrong place.
Mark A. Carter
CAD Administrator
NJRA Architects
Message 9 of 11
Be careful, there are laws against that in many states.
Mark Carter wrote in message <8b8spq$6rk25@adesknews2.autodesk.com>...
> I had my (cond) in the wrong place <
Message 10 of 11
    Of course. You're right .
style="BORDER-LEFT: #000000 2px solid; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px; PADDING-LEFT: 5px; PADDING-RIGHT: 0px">
picks empty space (because you are attempting to (car nil). Do
this:
> (if ENT
ENT)))
(cond
>         ((= (cdr (assoc
0 ENTEAL)
"VIEWPORT"))
worthwhile
(T
VIEWPORT")
Network
selected.
> (if ENT
(cond
>         ((= (cdr (assoc 0
            ... do
        (T
           (princ "\nEntity
> "Mark Carter" <
wrote in message
> > If the
type: lentityp"
can only select a
> viewport.
> > Mark A. Carter
> > CAD Administrator
NJRA Architects
Message 11 of 11
Let me rephrase, thanks to all who contributed.
P.S. Frank, I'm going to try your solution as well.
Mark A. Carter
CAD Administrator
NJRA Architects
