Yup it nils me.
I have 6 line# routines and 6 text# routines in this one lisp. If I
understand (progn) right. I should be able to use...
(if (setq a (ssget "x" '((0 . "line,arc,circle,polyline,lwpolyline") (8
."cloud") (62 . 6))))
(progn...
(setq n (sslength a))....
(entmod b2)
for each occurance?
J. Logan
"James Maeding" wrote in message
news:5387004@discussion.autodesk.com...
it will give nil right?
put an if statement to say:
( if (setq a (ssget "x" '((0 . "line,arc,circle,polyline,lwpolyline") (8
(progn....
then it will only run the stuff if it finds items to run on.
J. Logan
|>Let's say I run this routine on a drawing that doesn't contain any ((0 .
|>(8 . "cloud") (62 . 6))))
|>I knowwww... hard to believe but just for arguement sake.
|>How do I insure that the routine continues on, to search for text objects
|>without bombing out?
|>J. Logan
|>(defun line5 (/ a ln n index b1 c d b2)
|> ;;(defun line5 ()
|> (graphscr)
|> (princ "\nConverting Ojbects on CLOUD Layer to Correct Layers")
|> (setq ln "line5")
|> (setq a (ssget "x" '((0 . "line,arc,circle,polyline,lwpolyline") (8 .
|> (setq index 0)
|> (repeat n
|> (setq b1 (entget (ssname a index)))
|> (setq index (1+ index))
|> (setq c (assoc 8 b1))
|> (setq d (cons (car c) ln))
|> (setq b2 (subst d c b1))
|> (entmod b2)
|>(defun Text0 (/ a tn n index b1 c d b2)
|> ;;(defun text0()
|> (graphscr)
|> (setq tn "Text0")
|> (setq a (ssget "x" '((0 . "text") (8 . "cloud") (62 . 7))))
|> (setq index 0)
|> (repeat n
|> (setq d (cons (car c) tn))
|> (entmod b2)
|>(defun abylayer ()
|>(setq SS1 (ssget "x" '((-4 . ""))))
|>(command "change" SS1 "" "p" "color" "bylayer" "")
|>(princ)
|> (defun redrw ()
|> (command "redraw")
|>;; Execute command, calling constituent functions
|>(defun C:CLC () ;;cloudlayerclean
|> ;;(set_vars)
|> (line5)
|> (text0)
|> (abylayer)
|> (redrw)
|> (princ "\nCONVERSION COMPLETE")
|> (Princ)
James Maeding
Civil Engineer and Programmer
jmaeding - athunsaker - com
