Error boundary Xline
martin_leiter
Message 1 of 24
martin_leiter
Please help.
I have the following Lisp:
(defun c:umgrxlinien (/ AWS)
(setvar "HPISLANDDETECTIONMODE" 0)
(setvar "HPISLANDDETECTION" 2)
(if(setq AWS(ssget "X"
'( (-4 . "<OR")
(0 . "XLINE")
(0 . "Ray")
(-4 . "OR>")
(command-s "-umgrenzung" "o" "U" "N" AWS "" "" "_non" Pause))
(princ)
The error only occurs in Acad 2025. In Acad 2024 everything works normally and a boundary is created within the Xlines.
In 2025, however, if a line crosses the boundary of the Xlines, only the part up to this line is recognized as a boundary.
I have tried many things but nothing works.
Can someone help?
Martin
Replies (23)
Message 21 of 24
martin_leiter
Henrique this works very well for me!
Thanks!
Message 22 of 24
hmsilva
Thanks!
You're welcome, @martin_leiter
Glad I could help
The -boundary command in AutoCAD 2025 does not have the same behavior that it had in previous versions.
Let's hope next update will correct the -boundary command, @ambrosl @artc2 or someone from Autodesk give us some help...
Henrique
Message 23 of 24
ambrosl
Hello @hmsilva and @martin_leiter,
Thanks for the heads up on this problem.  I will pass this along to software development for research.
Lee Ambrosius
Senior Principal Content Experience Designer
For additional help, check out the AutoCAD Developer Documentation
Message 24 of 24
hmsilva
Thanks @ambrosl
Henrique
