error: bad argument type: stringp nil
Hello
I really need help, I wrote this lisp 18 years ago, I try to make it work on windows 10 and autocad 2019, I have an error on the command "regenkey" and "mobicadcod", if you can help me, thank you in advance. Atached you have the lsp file.
cadffm
STRINGP is the feedback of an internal predicate function.
For example: SUBSTR need a STRING as first argument,
stringp checks the first argument for "Is it a string?" string predicate / STRINGP
Error STRINGP means: Need a string, but it wasn't a string.
Where is the problem? Your old RegKeys doesn't match  the RegKeys of your current windows version.
You have to find where the information is stored in this windows version.
(defun codblocare# ()
(setq keya1 ( vl-registry-read "HKEY_local_machine\\SOFTWARE\\microsoft\\WINDOWS\\currentversion" "productkey"))
keya1 is NIL, because there is no vl-registry-read "HKEY_local_machine\\SOFTWARE\\microsoft\\WINDOWS\\currentversion(\\productkey), right?
(setq ccd1 (substr keya1 2 1 ))
SUBSTR want a String, but keya1 is nil (and nil is nothing), the error: bad argument type: stringp nil appears
Sebastian
thanks for the reply, that's right, I managed to solve it
