** Error: bad argument type: stringp nil ** when using "LayerExtractV1-4" of LeeMac
nislam04
nislam04
Hi everybody,
when using "LayerExtractV1-4" of LeeMac having the following error message on a PC while working well on others.
Any solution please? System variable problem?
Thank you
paullimapa
Are you sure you loaded the lisp file using the correct quotation mark?
(load"LayerExtractV1-4")
Paul Li
IT Specialist
@The Office
nislam04
Dear sir,Thank you for your response.
The thing is; I was testing this lisp for some improvement/modification. For that I had to load this lisp for many times. It worked every time but suddenly it stopped. But when I tried on another pc it was working and even it was working on the same pc's other user account.
Thank you
ВeekeeCZ
It seems that the routine writes some files on the drive, I would locate them and remove them.
