ERRO: _ai_selall
ERRO: _ai_selall
rolisonfelipe
ERRO: _ai_selall
rolisonfelipe
(DEFUN C:MOVELAY ()
  (PRINC "\n START \n")
(command "_.zoom" "e"); ZOON EXTEND FOR SEE OBJECT
(if (= (tblsearch "LAYER" " NAME LAYER "))
(command "-LAYER" "M" " NAME LAYER " "c" "7" "" "LT" "Continuous" "" "LW" "0.00" "" "")); FIND AND BORN LAYER
(setq name  (command _ai_selall )); ERRO SELECT ALL OBJECT
(command "chprop" name  "" "LA" " NAME LAYER " ""); MODIFY LAYER OBJECT
(command "_.purge" ); PURGE ALL LAYER NOT USED
(command "_.qsave"); SAVE
(command "_.quit"); CLOSE FILE
  (princ)
Sea-Haven
(command "_.purge" "LA" "*" "N" ); PURGE ALL LAYER NOT USED
rolisonfelipe
how can i enter select all command (command _ai_selall ) , because no command line works correctly, but in lsp it doesn't run
ВeekeeCZ
(c:ai_selall)
It's just another lisp routine defined at acad2022doc.lsp file.
BTW
You can just select all directly from CHPROP
(command "chprop" "all" "" "LA" " NAME LAYER " "")
Also, I guess it's just an imaginary name, but you really cannot start a layer name with a SPACE.
