Erase Dublicate entities
GeryKnee
GeryKnee
I need a lisp coda, doing as following :
Compares every object iObj of the selected objects collection with every one next of it objects jObj.
if jObj  is same as iObj (that means ::: jObj sould be created as a COPY of iObs prom a position to the same position),  then erase jObj objext.
Gery
ronjonp
Try the OVERKILL command.
GeryKnee
Yes, that' i need.
But overkill allways opens the options dialog.
sending command -overkill it's working as i wish to.
I wish just to type Ed and to get as i typed -overkill
So i wrote to acad.lsp the following command Ed :
(defun c:Ed (); EraseDublicateObjects / OverKill
(command "-overkill" "")
(princ)
But i get
ED -overkill Unknown command "-OVERKILL". Press F1 for help.
Command: ED Unknown command "ED". Press F1 for help.
How can i fix this?
ronjonp
Perhaps:
(command ".-overkill" "_all" "" "_d")
GeryKnee
I get
Command: ed
.-overkill Unknown command "-OVERKILL". Press F1 for help.
Command: _all Unknown command "ALL". Press F1 for help.
Command: _d Unknown command "D". Press F1 for help.
Command:
By typing -OVERKILL i get
Command: -OVERKILL
Initializing...
and continues properly
roland.r71
What version of ACAD are you using?
It used to be ExpressTools with old versions, which might explain why its not working with command.
