equal spacing
equal spacing
equal spacing
hello everyone,
I have used this forum a lot and it has been VERY helpful, so to start off..Thank you!
What I am looking for help on this time
Need to have a shape equally spaced while putting in lines.
I will add a picture to describe what I am looking for as putting it into words will be very difficult.  In the attachment...the "1's" are to be equal along the height and the "2's" are to be equal along the base.  The space between the two green lines, needs to be variable as it could be 7/8", 3/8", 5/8", whatever size bar the customer picks.  My attachment shows a 3x3 pattern but it could be anything really.  the important part is having the spacing equal.
so the user would pick the bottom left corner.  pick the top right corner.  input the bar width and the number of 2's and 1's and the lisp routine would do the rest.
Thank you in advance for your time and attention
Kent1Cooper
Check this out.  It doesn't put the center-lines in, but could presumably be adjusted to do so.
Kent Cooper, AIA
oh my goodness.  thank you so super much.
so very not professional but i could give you a virtual hug right now.  i wont cause well that would be awkward.
again thank you
