entsel not working properly
rosader
Message 1 of 12
rosader
I am writing a lisp that prompts the user to select a beam line and then it changes the layer of the line (to a layer for moment frame beams) and adds triangle blocks to each end rotated 90 degrees perpendicular to selected line.
When I run the lisp, it prompts to select beam line to convert to MF line but when I do it says *invalid selection* and then prompts you to "select objects" so it's not recognizing the line saved with entsel. When I proceed with "select objects" it disregards the lisp and has you change properties manually. Can anyone show me what I'm doing wrong?
Here is the lisp code:
(vl-load-com)
(defun c:b2mf (/ l0 l1 l2 e1 p1 p2 beamang)
  (c:dunn_get_lay)
  (setq l0 (getvar "clayer") ;get current layer
l1 (strcat level "_S-BEAM-MF") ;set layer for moment frame beam
l2 (strcat level "_S-COLS-MF") ;set layer for moment frame triangle
e1 (car (entsel "\nSelect Beam to Convert: ")) ;selects beam and saves to e1
p1 (cdr (assoc 10 (entget e1))) ;gets first point of beam from e1
p2 (cdr (assoc 11 (entget e1))) ;gets second point of beam from e1
beamang (cdr (assoc 50 (entget e1))) ;gets angle of beam e1
  );setq
  (while (/= e1 nil)
    (progn
      (command "CHPROP" e1 "la" l1 "") ;select line saved to e1 and change layer to l1
      (setvar "clayer" l2) ;sets the layer for inserting moment frame triangles
      (command "INSERT" "MFTRIANGLE.dwg" p1 1 1 (+ beamang 90.0)) ;insert moment triangle block at point p1 rotated 90 degrees relative to e1
      (command "INSERT" "MFTRIANGLE.dwg" p2 1 1 (+ beamang 180.0)) ;insert moment triangle block at point p2 rotated 180 degrees relative to e1
    );progn
    (setq e1 (car (entsel "\nSelect Beam to Convert or <Enter> to Quit: "))
  );while
    (setvar "clayer" l0) ;returns current layer to l0
    (princ "Converted to Moment Frame Beam")
    (princ))
);defun
Replies (11)
Message 2 of 12
Kent1Cooper
You need to complete the object selection in the CHPROP command with Enter [""]:
(command "CHPROP" e1 "" "la" l1 "")
Kent Cooper, AIA
Message 3 of 12
Moshe-A
@rosader hi,
this is my untested fix  😀
Moshe
(vl-load-com)
 (c:dunn_get_lay)
  );setq
  (while (setq e1 (car (entsel "\nSelect Beam to Convert: "))) ;selects beam and saves to e1
   (setq p1 (cdr (assoc 10 (entget e1))) ;gets first point of beam from e1
   (command "CHPROP" e1 "" "la" l1 "") ;select line saved to e1 and change layer to l1
  );while
  (princ)
);defun
Message 4 of 12
paullimapa
It fails because right after your code request for e1 it requests entget of the following:
But if nothing is selected then p1, p2 & beamang won't be retrieved...
Then you again request for e1 at the end of while loop here:
 );progn
  );while
But since within your while loop you don't request for p1, p2 & beamang, then the code fails.
Though I cannot fully test since I don't have function c:dunn_get_lay, give this version a try:
  (vl-load-com)
  (c:dunn_get_lay)
  );setq
  (while (setq e1 (car (entsel "\nSelect Beam to Convert or <Enter> to Quit: "))) ;selects beam and saves to e1
    (if (eq "LINE" (cdr(assoc 0 (entget e1)))) ; check if LINE selected
      (progn
       (command "_.CHPROP" e1 "" "_la" l1 "") ;select line saved to e1 and change layer to l1
       (command "_.INSERT" "MFTRIANGLE.dwg" p1 1 1 (+ beamang 90.0)) ;insert moment triangle block at point p1 rotated 90 degrees relative to e1
       (command "_.INSERT" "MFTRIANGLE.dwg" p2 1 1 (+ beamang 180.0)) ;insert moment triangle block at point p2 rotated 180 degrees relative to e1
      (princ"\nObject Selected Not a Line.")
	) ; if
  );while
  (princ "Convert to Moment Frame Beam completed")
  (princ)
);defun
Paul Li
IT Specialist
@The Office
Message 5 of 12
rosader
Thank You. I tried yours and it definitely changes the layer of the line correctly now. After that though, it has you manually rotating the mf triangle block at p1 and then it does not insert the mf triangle block at p2. Does autolisp not recognize that input (+ beamang 90.0) for the rotation angle?
Message 6 of 12
paullimapa
there's no 50 assoc pair for LINE objects
so the way to get the angle is this:
(defun RtD (r) (* 180.0 (/ r pi))) ; function to convert radians to degrees
(setq beamang (rtd(angle p1 p2))) ; returns angle of line
Paul Li
IT Specialist
@The Office
Message 7 of 12
rosader
I'm not sure what I'm doing wrong. I put the code in to convert radians to degrees. I did the angle of beamang based on p1 and p2 and it still wants me to manually set rotation of block.
Message 8 of 12
paullimapa
does MFTRIANGLE.dwg contain attributes?
post this block you want to insert in
Paul Li
IT Specialist
@The Office
Message 9 of 12
rosader
No attributes. Here is the block
Message 10 of 12
paullimapa
if block comes in with 0 rotation it'll look like this when you have a 45 degree line vs 0 degree
depending on the rotation angle you want to rotate at p1 vs p2
this is what you'll have to figure out to program into your code
Paul Li
IT Specialist
@The Office
Message 11 of 12
komondormrex
used 2d solid instead of block. rotation or drafting of solids should be tuned.
(defun draw_solid (point_vertex back_point_vertex)
	(vla-addsolid (vla-get-block (vla-get-activelayout (vla-get-activedocument (vlax-get-acad-object))))
				  (vlax-3d-point (trans point_vertex 1 0))
				  (vlax-3d-point (trans (polar point_vertex (- (angle point_vertex back_point_vertex) (/ pi 6)) 6) 1 0))
				  (vlax-3d-point (trans (polar point_vertex (+ (angle point_vertex back_point_vertex) (/ pi 6)) 6) 1 0))
(defun c:b2mf ( / beam beam_layer mf_triangle_layer)
	(setq beam (car (entsel "\Pick a beam line: "))
		  beam_layer (strcat (getvar 'clayer) "_S-BEAM-MF")
		  mf_triangle_layer (strcat (getvar 'clayer) "_S-COLS-MF")
	(entmod (subst (cons 8 beam_layer) (assoc 8 (entget beam)) (entget beam)))
	(draw_solid (cdr (assoc 10 (entget beam))) (cdr (assoc 11 (entget beam))))
	(entmod (subst (cons 8 mf_triangle_layer) (assoc 8 (entget (entlast))) (entget (entlast))))
	(draw_solid (cdr (assoc 11 (entget beam))) (cdr (assoc 10 (entget beam))))
	(princ)
Message 12 of 12
Sea-Haven
Using pline with start width 0.0 end width the size of arrow is a alternative to solid.
