Entsel in scripts
Entsel in scripts
Message 1 of 14
Entsel in scripts
I have a lisp routine that uses entsel to ask the user for a selection. When
I run the routine in a script, the script does not wait for the selection
and the entsel recieves the next script command as its input, causing an
error.
Is there any way to have the script pause until the lisp routine is
completed?
Thanks again,
Jon Crouch.
Replies (13)
Message 2 of 14
Hello Jon, I'm Rudy.
Why not use 'nentselp' .
Have your script search for the entity you wish to acquire, then extract
the point of insertion or point of reference, then assign it to the
nentselp. There by allowing it to rebuild the script and continuing.
Rudy@whainc.com
Programmer/Developer/MIS Assist.
Jon Crouch wrote in article
<7uibj7$t5v19@adesknews2.autodesk.com>...
When
> error.
> completed?
> Thanks again,
> Jon Crouch.
Message 3 of 14
Rudy Tovar wrote in message
news:01bf1a62$0f74e720$1b09a8c0@mail.whainc.com...
I have no idea how to do this...the entity will be one of numerous text
items on the dwg and could be at any location.
> Rudy@whainc.com
> When
selection
> > error.
> > completed?
> > Thanks again,
> > Jon Crouch.
Message 4 of 14
If this is text then have the script search for the text and replace or
modify the given value you wish to change. You will not have to use the
entsel or entselp function if you use 'SSGET' "X".
<7uihkp$t7b25@adesknews2.autodesk.com>...
extract
> > Rudy@whainc.com
selection.
> > When
> selection
an
> > > error.
> > > completed?
> > > Thanks again,
> > > Jon Crouch.
Message 5 of 14
But I don't know what the text will say..
news:01bf1a6b$c763e9e0$1b09a8c0@mail.whainc.com...
> extract
> > > Rudy@whainc.com
> selection.
> > > When
> > selection
causing
> an
> > > > error.
> > > > completed?
> > > > Thanks again,
> > > > Jon Crouch.
Message 6 of 14
Let me ask you something Jon.
What's the application going to be used for?
<7uiion$1tt2@adesknews2.autodesk.com>...
> > extract
text
continuing.
> > > > Rudy@whainc.com
> > selection.
> > > > When
> > > selection
> causing
> > an
> > > > > error.
is
> > > > > completed?
> > > > > Thanks again,
> > > > > Jon Crouch.
Message 7 of 14
Scripts cannot be used interactively so your calls to entsel will fail. If
you must use the routine in a script, you have to replace entsel with
nentselp. Perhaps you can have the lisp routine build a selection set and
then call the script to act on it. But if you're gonna go that far, might as
well let the lisp routine handle the whole operation.
Jon Crouch wrote in message
news:7uibj7$t5v19@adesknews2.autodesk.com...
When
> error.
> completed?
> Thanks again,
> Jon Crouch.
Message 8 of 14
Hello Frank.
You should have followed the thread.
Rudy@whainc.com
Frank Oquendo wrote in article
<7uir9i$1uv17@adesknews2.autodesk.com>...
If
as
> When
selection
an
> > error.
> > completed?
> > Thanks again,
> > Jon Crouch.
Message 9 of 14
I did. SSGET "X" wasn't going to help him. He seems to be trying to do the
impossible: create an interactive or decision-making script. Neither is
possible. The obvious solution is a LISP routine, not a script.
news:01bf1a8f$14b95900$1b09a8c0@mail.whainc.com...
> Hello Frank.
> Rudy@whainc.com
> If
and
might
> as
selection.
> > When
> selection
> an
> > > error.
> > > completed?
> > > Thanks again,
> > > Jon Crouch.
Message 10 of 14
I beg to differ.
I've created interactive decision making scripts.
This is not impossible.
If he is trying to go from drawing to drawing.
Rudy@whainc.com
<7uko02$6qh7@adesknews2.autodesk.com>...
the
> > Hello Frank.
> > Rudy@whainc.com
fail.
> > If
> and
> might
> > as
> selection.
> > > When
> > selection
causing
> > an
> > > > error.
> > > > completed?
> > > > Thanks again,
> > > > Jon Crouch.
Message 11 of 14
Since a script does not allow user input and has no decision constructs, I
am interested in hearing of your interactive scripts. Coupled with a LISP
routine, scripts can be quite powerful but in and of itself a script isn't
even as smart as a DOS batch file.
news:01bf1b23$46b2ee00$1b09a8c0@mail.whainc.com...
> I beg to differ.
> Rudy@whainc.com
> the
> > > Hello Frank.
> > > Rudy@whainc.com
> fail.
> > > If
with
set
> > and
> > might
> > > as
> > selection.
> > > > When
> > > selection
> causing
> > > an
> > > > > error.
is
> > > > > completed?
> > > > > Thanks again,
> > > > > Jon Crouch.
Message 12 of 14
The trick is to create a function that generates the script with the lisp
code that will be processed while the script is running.
Try it you'll like it.
As with lisp, most functions are process prior to activating the lisp. I've
created my own dialogs with cataloging properties that maintain sorting and
processing order, which gets generated into the script, which gets
activated after accepting all properties defined. This is so you can go
from drawing to drawing reprocessing a differing structure. This also
depends on what your end goal will be. Consider this: (1)processing
drawings (2)editing drawings (3)searching information, etc.
Rudy@whainc.com
www.wharchitects.com
<7ul666$6qc31@adesknews2.autodesk.com>...
I
isn't
> > I beg to differ.
> > Rudy@whainc.com
do
> > the
is
> > > > Hello Frank.
> > > > Rudy@whainc.com
> > fail.
> > > > If
> with
> set
> > > and
far,
> > > might
> > > > as
> > > selection.
> > > > > When
> > > > selection
> > causing
> > > > an
> > > > > > error.
routine
> is
> > > > > > completed?
> > > > > > Thanks again,
> > > > > > Jon Crouch.
Message 13 of 14
oh god! rudy again.
you have to check in your routine if a script is active.
see the docs on (getvar "CMDACTIVE")
if so avoid entsel and supply a correct entity for the following code.
this way the user (and in the script case the next commands) are not
bothered.
or, better, supply a correct pick (list of entity and point) to your
script.
> When
> > error.
> > completed?
Message 14 of 14
Ok...Here's what I'm trying to do:
I have about 2000 dwgs and I want to create a database (probably an HTML
page) listing the dwg#, title, paper size, author etc. The drawings use
various title blocks that dont use text attributes, and there may be
additional text info i need to extract from the dwgs. I have written a lisp
routine that prompts me to click on the title, author etc. (using entsel),
then stores the texts in a list and writes them to HD ready for processing
and HTML conversion. However...at present I have to manually open each dwg
and then run the routine, so I wanted a script that would open the dwgs for
me and run the routine so that all I have to do is click the text items I
need.
news:01bf1a72$78ef3600$1b09a8c0@mail.whainc.com...
or
the
> > > extract
> text
the
> continuing.
> > > > > Rudy@whainc.com
> > > selection.
> > > > > When
> > > > selection
> > causing
> > > an
> > > > > > error.
> is
> > > > > > completed?
> > > > > > Thanks again,
> > > > > > Jon Crouch.
