Entity selecting issues
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a subroutine that offsets entities on certain layers, relying on updating selection sets via points. However, when I try the subroutine on just 1 or the other of the red entities, it doesn't work, seemingly trying to select/offset nearby entities. Is that because the point values I'm relying on to update the selection set aren't very precise? Should I instead rely on xdata or something else? This seems to be the 1 weird edge case, it works for most other scenarios.
(defun c:OFFSETAUTO
( / miscOffset miscOSLayer mechOffset mechOSLayer ss1 ss2)
;;; HERE - work out bug (hypothesis: when ssget by pt, if zoomed out pts change (pts being used need to be more specific))
;;; Clean up code, make more readable, work w/ fewer selection sets if possible
;;; last steps:
; add undo marks (undo all & individual)
; turn CMDECHO off
(setvar "CMDECHO" 0)
; get current layer to set back to at end
(setq cLayer (getvar "CLAYER"))
; misc. and mech. obstructions offset vars
(setq
miscOffset 4
miscOSLayer "PV VENTS SKYLIGHTS ROOF DRAINS"
mechOffset 6
mechOSLayer "PV MECH EQUIP SETBACK"
; get current or prompt for selection set
(setq ss1 (ssget '((0 . "LINE,ARC,*POLYLINE,CIRCLE"))))
; get point list
(setq pointList (list))
(setq inc 0)
(repeat (sslength ss1)
(setq point (cdr (assoc 10 (entget (ssname ss1 inc)))))
; if circle, get point on circle's edge (center pt + rad)
(if (equal (cdr (assoc 0 (setq ent (entget (ssname ss1 inc))))) "CIRCLE")
(progn
(setq rad (cdr (assoc 40 ent)))
(setq x (nth 0 point))
(setq point (subst (+ rad x) x point))
(setq pointList (cons point pointList))
(setq inc (1+ inc))
; filter out circles and closed polylines from selection set to join
(setq inc 0)
(setq eName (ssname ss1 inc))
(setq ent (entget eName))
(if
(or
(equal (cdr (assoc 0 ent)) "CIRCLE") ; if ent is circle
(equal (cdr (assoc 70 ent)) 1) ; if ent is closed
(ssdel eName ss1)
; join entities
(if (/= (sslength ss1) 0) (polylineJoin ss1))
; construct list of entity names of newly joined entities (includes circles and closed polylines that were filtered out before joining)
(setq eNameList (mapcar '(lambda (pt)
(progn
; (princ (entget (ssname (ssget pt) 0)))
(princ pt)
(ssname (ssget pt '((8 . "PV Mechanical Obstructions,PV Misc Obstructions"))) 0)
pointList
; remove duplicates
(setq eNameList (LM:Unique eNameList))
; initialize empty selection sets
(setq ss2 (ssadd))
(setq ss3 (ssadd))
; add newly joined entities to ss2
(foreach eName eNameList (ssadd eName ss2))
(setq ssnum 0)
(repeat (sslength ss2)
; Get entity name and assoc list for each entity
(setq ename (ssname ss2 ssnum))
(setq entList (entget ename))
; DEBUGGING - Print ename of each entity in ss
(princ "\nEname:\n")
(princ ename)
; DEBUGGING - Print elist of each entity in ss
(princ "\nEntity:\n")
(princ entList)
; if entity is on "PV Misc Obstructions" layer and is CIRCLE/LWPOLYLINE, offset it
(offsetHandler entList "PV Misc Obstructions" miscOffset miscOSLayer)
; if entity is on "PV Mechanical Obstructions" layer and is CIRCLE/LWPOLYLINE
(offsetHandler entList "PV Mechanical Obstructions" mechOffset mechOSLayer)
(ssadd (entlast) ss3)
; increment ssnum
(setq ssnum (1+ ssnum))
; trim entities
(smartTrim ss3)
; reset current layer
(setvar "CLAYER" cLayer)
; turn CMDECHO on
(setvar "CMDECHO" 1)
; exit quietly
(princ)
; POLYLINE JOIN - joins all joinable entities in selection set
; From Kent Cooper - https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/lines-to-pline-in-one-step/m-p/3539784/highlight/true#M305510
;;; SHOULD also return selection set of newly joined entities
;;; FIX in case someone selects only a circle
(defun polylineJoin
(pjss / *error* doc svn svv nextent pjinit inc edata pjent)
; VARLIST
;; INPUTS
;;; pjss - input selection set, must be filered before inputting: '((0 . "LINE,ARC,*POLYLINE")) (PICKSET)
;; LOCAL VARS
;;; *error* - local error handling function (SYM)
;;; doc - AutoCAD active document, for purposes of end/start undo mark (VLA-OBJECT)
;;; svn - system variable names (LIST)
;;; svv - system variable values (LIST)
;;; nextent - entity used as starting point to check for new entities to join (ENAME)
;;; pjinit - initial number starting for loop (INT)
;;; inc - for loop incrementer (INT)
;;; edata - entity definition data, for purposes of removing invalid entities or fixing joined entities (ASSOC LIST)
;;; pjent - entity to be deleted from selection set if invalid shape (ENAME)
;; NON-LOCAL VARS
; general error handling
(defun *error* (errmsg)
(if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break"))
(princ (strcat "\nError: " errmsg))
; reset system variables, end undo, exit quietly
(mapcar 'setvar svn svv)
(vla-endundomark doc)
(princ)
; if there is a valid selection set
(if pjss
(progn
; start undo mark
(vla-startundomark (setq doc (vla-get-activedocument (vlax-get-acad-object))))
; get initial system vars and next joining entity reference
(setq
svn '(cmdecho peditaccept)
svv (mapcar 'getvar svn)
nextent (entlast)
; loop through selection set
(repeat (setq pjinit (sslength pjss) inc pjinit)
; remove any 2D "heavy", 3D polylines, or splined/fitted 2D lines from selection set
(if
(and
(cdr (assoc 0 (setq edata (entget (setq pjent (ssname pjss (setq inc (1- inc))))))))
"POLYLINE" ; 2D "heavy" or 3D Polyline
(= (cdr (assoc 100 (reverse edata))) "AcDb3dPolyline"); 3D
(member (boole 1 6 (cdr (assoc 70 edata))) '(2 4)); splined or fitted 2D
(ssdel pjent pjss)
; turn off command echo, turn on peditaccept
(mapcar 'setvar svn '(0 1))
; in case of older polylines (extreme edge case)
(setvar 'plinetype 2)
; if the remaining selection set is valid
(if pjss
; join entities based on different scenarios
(cond
( (= pjinit (sslength pjss) 1); selected only one, and it qualifies
(command "_.pedit" pjss "_join" "_all" "" ""); join everything possible to it
); single-selection condition
( (> (sslength pjss) 1); more than one qualifying object
(command "_.pedit" "_multiple" pjss "" "_join" "0.0" "")
); multiple qualifying condition
((prompt "\nSingle object not viable, or no more than 1 of multiple selection viable."))
; else
(prompt "\nNothing viable selected.")
; look through entities in selection set to set arcs/lines back to arcs/lines (may have gotten converted to plines)
(while (setq nextent (entnext nextent))
(setq edata (entget nextent))
(if
(and
(= (cdr (assoc 90 edata)) 2) ; transformation of entity allowed
(not (vlax-curve-isClosed nextent))
(command "_.explode" nextent)
; reset system vars, end undo mark
(prompt "\nNo qualifying object(s) selected.")
(princ)
; UNIQUE - returns list with duplicates removed
; From Lee Mac - http://lee-mac.com/uniqueduplicate.html
(defun LM:Unique ( l )
(if l
(cons (car l)
(LM:Unique (vl-remove (car l) (cdr l)))
; OFFSETHANDLER - checks that entity is on correct layer and is CIRCLE/LWPOLYLINE, then offsets
(defun offsetHandler (entList entLayer osDist osLayer / entEname)
; VARLIST
;; INPUTS
;;; entList - offset entity definition (ASSOC LIST)
;;; entLayer - correct entity layer of entity to offset (STR)
;;; osDist - amount to offset by (INT)
;;; osLayer - layer of offset entity (STR)
;; LOCAL VARS
;;; entEname - entity name of entity to offset (ENAME)
; get ename of entity
(setq entEname (cdr (car entList)))
; if entity is on correct layer and is CIRCLE/LWPOLYLINE, offset
(if
(and
(equal
(cdr (assoc '8 entList))
entLayer
(wcmatch
(cdr (assoc '0 entList))
"CIRCLE,LWPOLYLINE"
; offset entity (if error in offset, run offsetOuterError func)
(progn
(setq errObject (vl-catch-all-apply 'offsetOuter
(list entEname osDist osLayer)
(if (vl-catch-all-error-p errObject)
(offsetOuterError entEname osDist osLayer)
; OFFSETOUTERERROR - for handling error of inner offset on entity too small, offsets given polyline or circle entity by given amount and on given layer & color
(defun offsetOuterError (eName osDist osLayer / offsetEList)
; VARLIST
;; INPUTS
;;; eName - entity name of entity to offset (ENAME)
;;; osLayer - offset layer (STR)
;; LOCAL VARS
;;; offsetEList - offset entity definition (ASSOC LIST)
; error handling version if vla-offset attempts to inner-offset an entity too small (offset wouldn't fit inside entity)
; convert entity name to vla-object, then offset by negative osDist amount
(vla-offset (vlax-ename->vla-object eName) (- osDist))
; get offset assoc list
(setq offsetEList (entget (entlast)))
; change offset layer
(setq offsetEList (subst (cons '8 osLayer)
(assoc '8 offsetEList)
offsetEList
(entmod offsetEList)
; OFFSETOUTER - offsets given polyline or circle entity by given amount and on given layer & color
(defun offsetOuter (eName osDist osLayer / originalArea offsetEName offsetArea offsetEList)
; VARLIST
;; INPUTS
;; LOCAL VARS
;;; originalArea - area of entity to offset (REAL)
;;; offsetEName - entity name of offset entity (ENAME)
;;; offsetArea - area offset entity (REAL)
; inspired by Kent Cooper's offset subroutine (comparing offset area with entity area): https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/offset-multiple-objects-at-once/m-p/8172189/highlight/true#M372175
; convert entity name to vla-object, then offset by osDist amount
(vla-offset (vlax-ename->vla-object eName) osDist)
; get area of original entity
;; NOTE: For open entities, vla-get-area draws line between 2 unaligned points
;;;;;;;; If points are aligned, vla-get-area assumes rectangle
;;;;;;;; Algorithm should still work though
(setq originalArea (vla-get-area (vlax-ename->vla-object eName)))
; get area of offset
(setq offsetEName (entlast))
(setq offsetArea (vla-get-area (vlax-ename->vla-object offsetEName)))
; compare area of offset to area of original, delete and redo offset if offset area is smaller
(if (< offsetArea originalArea)
(progn
(entdel offsetEName)
; get new offset assoc list
offsetEList
; SMARTTRIM - trims groups of entities on the same layer
(defun smartTrim (ss / ssMech inc ent eName ssMisc ssMiscRegion newEname regionToExplode ssMechRegion)
; split selection set into 1 ss for each layer
(setq ssMech (ssadd))
(repeat (setq inc (sslength ss))
(setq ent (entget (ssname ss (setq inc (1- inc)))))
(if (equal (cdr (assoc '8 ent))
"PV Mech Equip Setback"
(progn
(setq eName (cdr (assoc '-1 ent)))
(ssadd eName ssMech)
(ssdel eName ss)
; renaming
(setq ssMisc ss)
; trimming PV VENTS SKYLIGHTS ROOF DRAINS (make all offsets a REGION for purposes of UNIONing)
(command-s "_.-LAYER" "_SET" "PV Vents Skylights Roof Drains" "")
(setq ssMiscRegion (ssadd))
(repeat (setq inc (sslength ssMisc))
(setq ent (entget (ssname ssMisc (setq inc (1- inc)))))
(setq eName (cdr (assoc -1 ent)))
(command-s "_.REGION" eName "")
(setq newEname (entlast))
(ssadd newEname ssMiscRegion)
(ssdel eName ssMisc)
; free from memory
(setq ssMisc nil)
; UNION regions and EXPLODE
(command-s "_.UNION" ssMiscRegion "")
(setq regionToExplode (entlast))
(command-s "_.EXPLODE" regionToExplode "") ;;; HERE - explode not working
; trimming PV MECH EQUIP SETBACK - same as above
(command-s "_.-LAYER" "_SET" "PV Mech Equip Setback" "")
(setq ssMechRegion (ssadd))
(repeat (setq inc (sslength ssMech))
(setq ent (entget (ssname ssMech (setq inc (1- inc)))))
(ssadd newEname ssMechRegion)
(ssdel eName ssMech)
(setq ssMech nil)
(command-s "_.UNION" ssMechRegion "")
(command-s "_.EXPLODE" regionToExplode "") ;;; HERE - explode not working - could try getting entities to explode by points
