Entity name from blocks
Henrik_Lo
Message 1 of 10
Henrik_Lo
HI
Is it possible use (ssget “X”), to automatic select, in this case is it blocks, I am only using 2
blocks. I like to isolate them and get there entity name, I can´t remember how to do this task.
I do also know the block names.
This is my simple test code to manually selecting the block. 
(defun c:BNA ()
   (setq qqq (ssget))
   (setq qqqq (ssname qqq 0))
   (setq y (entget qqqq))
   (setq qqqqa (entget qqqq))
   (Setq EName (assoc -1 qqqqa))
);defun
Regards
Henrik
Replies (9)
Message 2 of 10
cadffm
Your result is the same like
(cdr(entsel))
If you like to do it without interacting.. think about it is possible to have multiple blockreferences (not blocks) in a drawing,(ssname ss 0) is just the first one.
This works just for non dynamic blocks:
(if(setq ss (ssget "_X" '((0 . "INSERT")(2 .  "BLOCKNAME"))))(ssname ss 0))
Sebastian
Message 3 of 10
Kent1Cooper
blocks. I like to isolate them and get there entity name, .... I do also know the block names.
(defun c:BNA ()
   (setq qqq (ssget))
);defun
Are they two Blocks of different names?  If so, and they are not dynamic Blocks, you can find more than one Block name's insertions [however many insertions of them there are] this way:
(setq ss (ssget "_X" '((2 . "BlockName1,BlockName2"))))
You can, if you want, but don't really need to, include the (0 . "INSERT") entry in the filter list -- I think Block insertions are the only drawn  things it can find with the 2-code entry [that's always a name, and other things with names are non-drawn things like Layers and Styles, and in any case, not likely to have the same names as your Blocks].
Your code goes to a lot more trouble than necessary.  It gets the entity name, pulls the entity data for that, and then gets the entity name again  out of that entity data.  The entity name is what (ssname) returns to begin with, so to get to it you can skip several of your steps:
(defun c:BNA ()
   (setq qqq (ssget))
   (setq EName (ssname qqq 0))
);defun
If you mean that you have two Block insertions  [whether or not of different Block names], that you want to find and isolate:
(defun c:BNA ()
  (setq
qqq (ssget "_X" '((2 . "BlockName1,BlockName2"))))     EName1 (ssname qqq 0)
Ename2 (ssname qqq 1)
) );defun
Or, if they're two insertions of the same  Block name, you can just list that one name in the (ssget) filter, and both will be found.
When as in your original you're after the entity name of a single  Block [or anything else] that the User is to select, that can be done without involving (ssget) or (ssname) to pull the entity name from the result:
(setq EName (car (entsel)))
Kent Cooper, AIA
Message 4 of 10
Henrik_Lo
HI al
it is dynamic blocks i like to enter, they area with different names
thangs for helping out me
Regards
Henrik
Message 5 of 10
Kent1Cooper
In that case, I think the approach needs to be to have (ssget "_X"...) find all  Blocks, and step through them all looking for a match of each one's "effective name" to the names you know them by.  Search for (vla-get-effectivename ... in this Forum, and you'll find many examples of how to do that.
Kent Cooper, AIA
Message 6 of 10
Henrik_Lo
HI Kent
I´ll will try to see how this will work out then, iam not into visual lisp but only the old lisp.
regards
Henrik
Message 7 of 10
Henrik_Lo
HI Kent
This code, showed to me worked as I expected, and gave me 2 blocks and names, and worked perfect, but as explained only on normal blocks.
 (setq qqq (ssget "_X" '((2 . "aaaa"))))
 (setq EName1 (ssname qqq 0))
 (setq Ename2 (ssname qqq 1))
I then found a code, an tried to modify, but no luck, I have 2 blocks to find. And need the entity names, because I need to modify the variables
Dynamic Block1:     Masche Seitensnsich
Dynamic Block1:     LTmask
(defun c:sb (/ e name n o out ss)
(if (setq name "Masche Seitensnsicht"
ss (ssget "_X" (list '(0 . "INSERT") (cons 2 (strcat name "Masche Seitensnsicht"))))
n -1
out (ssadd)
(while (setq e (ssname ss (setq n (1+ n))))
(if (and (vlax-property-available-p (setq o (vlax-ename->vla-object e)) 'effectivename)
(wcmatch (strcase (vla-get-effectivename o)) (strcase name))
(ssadd e out)
(if (/= 0 (sslength out))
(progn (sssetfirst nil out) (princ (strcat (itoa (sslength out)) " " name " blocks found...")))
(princ (strcat "No Dynamic Block found by the Name - " name))
(princ)
(vl-load-com)
Regards
Henrik
Message 8 of 10
Kent1Cooper
It won't be able to find dynamic Blocks by the name in that way, because the 2-code entry will be an anonymous-Block name.  That's why you need to find all  Blocks, and step through them looking at each one's effective name.  I think without testing that the line quoted above should be just:
  ss (ssget "_X" (list '(0 . "INSERT")))
Kent Cooper, AIA
Message 9 of 10
dlanorh
Lee Mac has an autolisp only 'effectivename function HERE
You can select anonymous blocks using
(setq ss (ssget "_X" '((0 . "INSERT") (2 . "'**"))))
See HERE
I am not one of the robots you're looking for
Message 10 of 10
Henrik_Lo
HI
Thangs a lot for helping med out, great help, I will try through the weekend to get my function to work
Regards
Henrik
