SSGET Anonymous Blocks
john.uhden
Mentor Mentor
john.uhden
I ran into something illogical trying to ssget anonymous (unnamed) blocks.
You can entmake anonymous blocks.  Just use the name "*U" and AutoCAD will add a numeric end to the name, as in "*U65."
One would think that you could select them with (ssget "X" '((0 . "INSERT")(2 . "*U*"))), just like...
Command: (wcmatch "*U*" "*U*") T
But NO.  You must precede the first asterisk with a reverse quote ` for the filter to work, as in (ssget "X" '((0 . "INSERT")(2 . "`*U*"))).
I mean, once you know that, if you can remember it, then fine.  But it's still illogical to me.
BTW, years ago I thought that anonymous blocks could not contain attributes.  Maybe that was true in R11 or something, but yes they can contain attributes.
John F. Uhden
cadffm
Every Table, Array, Dimension or dynamic Block are displayed through anonyme Inserts,
that Acad internal Blocks like anonyme Layer and more, not created for Useraccess.
And Attributes, no problem (But of course: R11 is pre CADffm-Adesk time)
You´re right:  once you know that, if you can remember it, then fine.
F1 - About Wild-Card Patterns in Selection Set Filter Lists (AutoLISP)
Sebastian
Ranjit_Singh
Release 11 added wildcard support to ssget function
2006 brought along dynamic blocks and I guess now they needed some way of distinguishing between * as part of the name of block vs wildcard.
cadffm
It came not late with dynamic Blocks.
2004 Help attachment and R14(German)
Sebastian
john.uhden
To quote your help file excerpt, "The wild-card patterns recognized by ssget are the same as those recognized by the wcmatch function."
But it is not the same.  (wmatch "*U*" "*U*") returns T.  There is no need for a reverse quote.
Yes, I read the following sentence and if those are the rules, then fine.  I have run into situations requiring literal interpretation before, and the reverse quote is often required.  Enough, I'm over it.
BTW, I managed to create an elock-violation in that MTJOIN thing.  I'll figure it out.
John F. Uhden
cadffm
oups, my attachment lost in Space
(elock-violation - if you want help, send a message)
Sebastian
john.uhden
You had better keep that platzhaltermonster in your pants.  You certainly don't want it filterbustering all over everyone.  :]
John F. Uhden
