Entities inside a block
Message 1 of 18
When issuing a call to SSGET, I want to be able to search inside of the
defined blocks in the drawing and look for a text object with for example
the text "FOUNDME". I then want to change this text value to something else
such as "NEWTEXT". Issuing (ssget "x" '((1 . "FOUNDME"))) does not search
blocks defined in the drawing. I suspect that I need to search through the
block table using (TBLSEARCH). Thanks,
Ryan Small
Visit our website at http://www.braemarbldg.com
E-Mail: [email protected]
Replies (17)
Message 2 of 18
Yep.
Kind of.
Have to walk the block table, and then descend thru each block definition.
__________________________________
Michael Puckett
[email protected]
> Not < an Autodesk hall monitor.
Imagination makes all things possible.
Ryan Small wrote in message
news:01bf2c8e$6043d6a0$a3a43dcf@user3...
Ryan Small
Message 3 of 18
Ssget doesn't search inside of blocks, so you're forced to
do this manually. If you're using AutoCAD 2000, you could
do it much faster with ActiveX. Otherwise, you'd have to
iterate through the block table and manually examine each
entity in each block's definition.
This will replace all text in every block, that matches a
wildcard pattern with a specified replacement string:
(defun replace-nested-text (pattern replacetext / block ent data)
(while (setq block (tblnext block (not block)))
(setq ent (cdr (assoc -2 block)))
(while ent
(setq data (entget ent))
(if (and (eq (cdr (assoc 0 data)) "TEXT")
(wcmatch (cdr (assoc 1 data)) pattern)
(entmod (list (cons -1 ent) (cons 1 replacetext)))
(replace-nested-text "FOUNDME" "NEWTEXT")
> Ryan Small
/* Tony Tanzillo Design Automation Consulting */
/* Programming & Customization for AutoCAD & Compatibles */
/* [email protected] */
/* http://ourworld.compuserve.com/homepages/tonyt */
Message 4 of 18
How would I modify this routine to look for a certain block name and a certain text string and change the width of the text string?
Tim
Message 5 of 18
How are you getting the block? If it is text, then you can just select it
with 'nenetsel' and then change it from there, and since it is a peace of
text it will update all the blocks that are inserted. If it is an
attribute, then you will have to search the whole drawing for that block,
then seach each attribute to find the correct tag, and change all the
widths.
Tim
"A blind man lets nothing block his vision."
wrote in message news:[email protected]...
Tim
Message 6 of 18
I need to be able to do it without user input. I want to write it so that I can run it on a group of drawings.
Attributes are easy compared to this. I can not for the life of me figure out how to get to a subentity of a block...like text, and change that text width.
Sure I can redefine it with insert=, but this block will have title area info in it that will be different from drawing to drawing. I just need to change a specific text string's (I know the value) width. I also know the block name.
Thanks, Tim
Message 7 of 18
Okay here is how I would do it.
(defun ChangeTextWidth (BlkName TextStr TextWid)
(vlax-for Blk (vla-get-Blocks (vla-get-ActiveDocument
(vlax-get-Acad-Object)))
(if (= (strcase (vla-get-Name Blk)) (strcase BlkName))
(vlax-for Obj Blk
(if
(and
(=(vla-get-ObjectName Obj) "AcDbText")
(= (vla-get-TextString Obj) TextStr)
(vla-put-ScaleFactor Obj TextWid)
(princ)
Or even better, since this one won't search the whole block collection.
(defun ChangeTextWidth-v02 (BlkName TextStr TextWid / Blk)
(if (not (vl-catch-all-error (setq Blk (vl-catch-all-apply 'vla-Item (list
(vla-get-Blocks (vla-get-ActiveDocument (vlax-get-Acad-Object))))))))
(vlax-for Obj Blk
(if
(and
(= (vla-get-ObjectName Obj) "AcDbText")
(princ)
Watch for word wrap.
Tim
width.
block name.
Thanks, Tim
Message 8 of 18
Getting this error...
; error: no function definition: VL-CATCH-ALL-ERROR
Thanks, Tim
Message 9 of 18
vl-catch-all-error-p
Thanks, Tim
Message 10 of 18
Here is what I ran...
(ChangeTextWidth-v02 "PDMS_BACK" "SHELL EASTERN PETROLEUM (PTE) LTD." "0.9")
It ran now without errors, but the text did not change.
I verified the block name and text string. They are both valid.
Ideas?
Message 11 of 18
The text width is a real, not a string. Try it again without the quotes
around the 0.9.
Thanks Michael for catching the typo.
Tim
Ideas?
Message 12 of 18
I had already tried that and it didn't make a difference.
Is there something else [like (vl-load-com)] that you may be assuming that I have loaded that needs to be loaded?
Thanks....
Message 13 of 18
Did you regen after the command?
Tim
Thanks....
Message 14 of 18
yes
Message 15 of 18
Here is the DXF data for the text entity...
100
AcDbEntity
8
PDMS_BACK
62
2
100
AcDbText
10
661.17075
20
26.4877
30
0.0
40
3.75
1
41
0.9
7
O8111901
72
1
11
702.177
21
28.3627
31
0.0
BTW: Thanks for the help......
Message 16 of 18
If you were using v02, which I would, there was another typo. I forgot to
add the block name to the search. Here you go. Tested and works. Sorry
about that.
(if (not (vl-catch-all-error-p (setq Blk (vl-catch-all-apply 'vla-Item (list
BlkName)))))
(vlax-for Obj Blk
(if
(and
(vla-Regen (vla-get-ActiveDocument (vlax-get-Acad-Object)) acActiveViewport)
(princ)
Tim
yes
Message 17 of 18
bingo...thnx.....ura genuis....
I may come back at you for explanations as to what is doing what so I understand better.
Again...thanks for the help...
Tim
Message 18 of 18
You're welcome.
Tim
understand better.
Tim
