entget coordinates extraction has no precision - all end ".0"
robert.webster247M7
Message 1 of 17
robert.webster247M7
Hello. i am using Autocad 2023 and am trying to write a routine that extracts X,Y & Z coordinates from a 3D polyline.
The x & y coordinates have no precision, the z is to 3 dp (for level purposes, this is acceptable). eg (10 260974.0 824336.0 255.344).
I changed the units from mm to m and tried again without avail.
Has anyone else have this cause issues?
thanks
Replies (16)
Message 2 of 17
pbejse
What method did you use to extract the coordinates? I cannnot seem to replicate that result on AutoCAD 2023
Message 3 of 17
Moshe-A
@robert.webster247M7  hi,
Sounds like you are using convert format function [like (rtos)] check the XYZ value before the convertion
Moshe
Message 4 of 17
robert.webster247M7
Hi. Thanks for the reply.
I found some code online
"(setq obj (vlax-ename->vla-object (car (entsel "\nSelect a Polyline: "))))
(setq poly1 (vlax-get obj 'Coordinates))"
I have also checked manually at command prompt with the entget etc commands
Message 5 of 17
robert.webster247M7
Hi. Thanks for your reply.
I borrowed some code that I found on line
" (setq obj (vlax-ename->vla-object (car (entsel "\nSelect a Polyline: "))))
But I have also checked manually at the command prompt using entget etc.
Message 6 of 17
pbejse
Maybe your coordinate is like this --> X is at 11.030 Y at 13.024 Z as 25.366
with Luprec 1 it will show the same as you have 11.0 13.0 25.366
Try changing LUPREC variable to a higher number, say 3 then you will get to  "see" the other values
(10 11.03 13.024 25.366)
HTH
Message 7 of 17
robert.webster247M7
Hello. I've tried Luprec, which was initially 4, on 3, 8 (max) and 0 (min). it made no difference. I believe the problem lies in the no of digits it outputs. I scaled the plline by 1000 and achieved 3dp for x, y & z.
Message 8 of 17
Moshe-A
@robert.webster247M7 ,
create a new free polyline with snap off and report what is the result.
Message 9 of 17
pbejse
I like to get my hands on that drawing, are you saying the same drawing when opened on a lower version doent have that issue? perhaps a "Reset Settings to Default" is in order.
Anyway, let us know hot it goes
Message 10 of 17
ВeekeeCZ
thanks
I too have the same. (10 -650057.0 -1.15296e+06 0.0).
That's no issue. It is always like that, it shows just 6 digits. It's just a visual thing... the real precision is always 16 digits. Just convert it into a string and you'll see more. Use eg. this: (rtos (cadr (assoc 10 (entget (car (entsel))))) 2 12)
Message 11 of 17
robert.webster247M7
Attached is the 3dpolyline in dwg. it is showing the first vertice to 4dp in properties.
The start portion of the output at the bottom shows the output from the lisp
Message 12 of 17
ВeekeeCZ
Here is your new line to use.
(mapcar '(lambda (x) (rtos x 2 12)) (vlax-get (vlax-ename->vla-object (car (entsel "\nSelect a Polyline: "))) 'Coordinates))
Message 13 of 17
robert.webster247M7
Thank you very much. that is brilliant
Message 14 of 17
ВeekeeCZ
Rather read my first reply, that's the real solution.
Message 15 of 17
pbejse
RTOS ?I did not even consider that as an issue because that is what @Moshe-A  suggested at post # 3  😂
I thought its more sinister than that
Message 16 of 17
robert.webster247M7
A big thank you  to everyone, your help and time, much appreciated!!
Message 17 of 17
pbejse
You are welcome, just know that you can trust the API regardless what you see or NOT see.
Cheers
