Enforce Lisp execution order within a macro
pablo.odriozola
Message 1 of 9
pablo.odriozola
Hi there,
I've created 2 custom commands for AutoCAD as lisp files. When I run the macro:
^C^C_COMMAND-1;COMMAND-2
I get an alert that is coming from the second command before the first command is executed. How can I enforce the order of execution so that the alert from the second command only shows after the first command is fully executed?
Thanks for your help once again!
Replies (8)
Message 2 of 9
Kent1Cooper
I get an alert that is coming from the second command before the first command is executed. How can I enforce the order of execution so that the alert from the second command only shows after the first command is fully executed? ....
Does the first one partially execute?  Or does it fail entirely, and the macro then moves on to the second one?
[At first I suspected the latter because of the _underscore prefix on the first command.  That's not really appropriate to a custom command name.  It's to make native AutoCAD commands in their English-version names work in AutoCAD for other languages.  But I find with some of my custom commands that the underscore prefix doesn't cause any trouble.]
Or, does the first command fully execute eventually, but not until after the alert coming from the second command?
Kent Cooper, AIA
Message 3 of 9
pablo.odriozola
Hi Kent,
Answering your question, first I get the alert from the second command and then the first one gets executed (correctly)
Message 4 of 9
Kent1Cooper
Is there some way of determining whether it's only something like a delay in display updating until after the entire macro is done, and the first command is actually executed before the second one, but you just don't see it until after?
Kent Cooper, AIA
Message 5 of 9
pablo.odriozola
It's not just a delay because the alert would be different in case the first command was fully executed before the second one
Message 6 of 9
Sea-Haven
You may have to resort to loading a script.
(load "Mycommands")
Coomand1
Coomand2
Message 7 of 9
Moshe-A
@pablo.odriozola  hi,
To debug, add these 2 lines to each of your commands:
run the macro and tell us what is the result?
Moshe
(defun c:command-1 ()
 (getstring "\nEnter command-1...")
 ; your command-1 code start here
 (getstring "\nAbout to exit command-1...")
 (princ)
(defun c:command-2 ()
 (getstring "\nEnter command-2...")
 ; your command-2 code start here
 (getstring "\nAbout to exit command-2...")
 (princ)
Message 8 of 9
Sea-Haven
Nice idea I use (alert "Command 1 has completed") same thing forces a stop.
Message 9 of 9
Moshe-A
@Sea-Haven
thank you
after I sent that I realised that (getstring) requires a backslash char "\" in menu macro 😀
