Checking DCL Input isBlank
thabit79BL3
thabit79BL3
I am writing to request your assistance with a problem I am encountering with my AutoLisp code. Specifically, I am trying to create a function that will check whether the input of a dcl is blank. If the input is blank, I would like the function to execute one command, and if the input is not blank, I would like the function to execute another command.
I have tried using the following code, but it has not been successful:
(setq result (get_tile rcdName))
(if (or (null result) (equal result ""))
   (progn
      (c:wd_wire rcdWirePointStart rcdWirePointEnd "")
   (progn
       (command .....)
Could you please advise me on how I can modify this code to achieve the desired functionality? I would greatly appreciate your assistance.
Thank you for your time and attention.
@paullimapa
paullimapa
hard to tell without the rest of the code including dcl.
but my first guest is that this code:
should look like this?
(setq result (get_tile "rcdName"))
Paul Li
IT Specialist
@The Office
Sea-Haven
Maybe, get_tile returned ("6" "" "6" "3/4") for my test of 4 get tiles note second answer is "" which is a blank string. Not a null or nil. Still a string but with no value. Bit like getstring does similar for press Enter.
paullimapa
note: to test, just simply do this:
(setq result "")
then run the OP's code and it'll still return T:
Paul Li
IT Specialist
@The Office
Sea-Haven
(if (= (strlen result) 0) then its blank. A space etc looks like its blank will return 1.
