Elevation Marker LISP Routine - Help Please
Hello Good People,
I have been working on this LISP I have found to suit our purposes.
So far most things I changes have work but for some reason this routine fails at the the most important stage.
If I set the datum to 88 for example and then apply 1000 vertical scale it does not insert the correct height.
And if do it at 100 vertical it doubles!?
I assume it has something to do with insertion point or how the block being made within the LISP.
It would also be good for this LISP to round up to 1 decimal place.
If someone could please help it would be highly appreciated as I simply can't find the issue.
Thanks.
                                 ;; Title   : Elevation Marker             ;;
                                 ;; Purpose : To get Elevation             ;;
                                 ;; System requirement : Autocad 2007      ;;
                                 ;; Command : Dat, Ele & uw                ;;
;;-------------------------------------------* error *-----------------------------------------------------
(defun trap1 (errmsg)
           (setq *error* temperr)
           (setvar "clayer" clay)
           (prompt "\nEnter Command UW to make UCS origin to World")
(princ)
) ;defun
;;-----------------------------------sub function to create block---------
(defun elblock ( )
    (if (not (tblsearch "BLOCK" "ELBLK"))
        (progn
            (if (not (tblsearch "STYLE" "Gen-Text"))
                (entmake
                    (list
                        (cons 0 "STYLE")
                        (cons 100 "AcDbSymbolTableRecord")
                        (cons 100 "AcDbTextStyleTableRecord")
                        (cons 2 "Gen-Text")
                        (cons 70 0)
                        (cons 40 300.0)
                        (cons 3 "Arial narrow.ttf")
                 (entmake
                    (list
                        (cons 0 "BLOCK")
                        (cons 8 "0")
                        (cons 370 0)
                        (cons 2 "ELBLK")
                        (cons 70 2)
                        (cons 4 "Block to Place Trial pit Locations")
                        (list 10 0.0 0.0 0.0)
                 (entmake
                    (list
                        (cons 0 "LWPOLYLINE")
                        (cons 100 "AcDbEntity")
                        (cons 100 "AcDbPolyline")
                        (cons 8 "0")
                        (cons 370 0)
                        (cons 90 4)
                        (cons 70 1)
                        (list 10 2000.0 2000.0)
                        (list 10 0.0 0.0)
                        (list 10 -2000.0 2000.0)
                 (entmake
                    (list
                        (cons 0 "ATTDEF")
                        (cons 8 "0")
                        (cons 370 0)
                        (cons 7 "Gen-Text")
                        (list 10 -1000.0 2750.0 0.0)
                        (list 11 -1000.0 2000.0 0.0)
                        (cons 40 3000.0)
                        (cons 1 "±0.000m")
                        (cons 3 "Elevation")
                        (cons 2 "EL")
                        (cons 70 0)
                        (cons 72 0)
                        (cons 74 1)
                        (cons 280 1)
                 (entmake
                   (list
                       (cons 0 "ENDBLK")
                       (cons 8 "0")
           ;;--- To set block units in metre 70-6
                (lambda ( lst )
                    (regapp "ACAD")
                    (entmod
                        (append (subst (cons 70 6) (assoc 70 lst) lst)
                            (list
                               (list -3
                                   (list "ACAD"
                                       (cons 1000 "DesignCenter Data")
                                       (cons 1002 "{")
                                       (cons 1070 1)
                                       (cons 1070 1)
                                       (cons 1002 "}")
                (entget (cdr (assoc 330 (entget (tblobjname "BLOCK" "ELBLK")))))
 ;;;--- To make block annotative
                (lambda ( lst )
                    (regapp "ACAD")
                    (regapp "AcadAnnotative")
                    (entmod
                        (append (subst (cons 70 1) (assoc 70 lst) lst)
                            (list
                               (list -3
                                   (list "ACAD"
                                       (cons 1002 "{")
                                       (cons 1070 1)
                                       (cons 1070 1)
                                       (cons 1002 "}")
                                   (list "AcadAnnotative"
                                       (cons 1000 "AnnotativeData")
                                       (cons 1002 "{")
                                       (cons 1070 1)
                                       (cons 1070 1)
                                       (cons 1002 "}")
       ;;;--- to disable allow explod-----
       (vl-load-com)
       (setq BLOCKS
       (vla-get-Blocks
        (vla-get-activedocument
         (vlax-get-acad-object)
      BLK (vla-Item BLOCKS "ELBLK")
   (vla-put-explodable (vla-Item BLOCKS "ELBLK") :vlax-false)
;;;--- end to disable allow explod-----
    (princ)
;;-------------------------------------------Set Datum-----------------------------------------------------
(defun C:edat (/ enum eop esta epga estb epgb)
        (command "cmdecho"0)
    ;;; input x
      (setq enum 0)
   ;;; input y
        (if (not esf-ss) (setq esf-ss 0.0))    ; default number
        (setq esum (getreal (strcat "\nEnter vertical datum (Elevation) <" (rtos esf-ss 2 3) ">: ")))
        (if (not esum) (setq esum esf-ss) (setq esf-ss esum))
   ;;; set orign point
        (setq eop (getpoint "\nPick datum orgin point: "))
        (setq esta (car eop))
        (setq epga (cadr eop))
        (setq estb (- esta enum))
        (setq epgb (- epga esum))
        (command "ucs" "m" (list estb epgb 0))
        (prompt "\nOrigin moved to new loaction - Enter Command ELE to place Marker")
  (princ)
) ;defun
;;-------------------------------------------Place Text----------------------------------------------------
(defun C:ELE ()
   (if (not esum) (alert "\n  Set Vertical DATUM \n   Command - EDAT ")(estn1))
 ) ;defun
(defun estn1 (/ epnt1 ep1y estdy e ele-text ptlist)
         (setq clay (getvar "clayer"))
         (setq temperr *error*)
         (setq *error* trap1)
         (if (not (tblsearch "layer" "Elevation Marker")) (command "-LAYER" "N" "Elevation Marker" "C" "7" "Elevation Marker" "LT" "Continuous" "Elevation Marker""LW" "0.00" "Elevation Marker" ""))
         (command "CLAYER" "Elevation Marker")
  ;;; input Vertical scale
 (if (not hs) (setq hs 1))    ; default number
     (setq hsm (getreal (strcat "\nEnter Vertical Scale factor <" (rtos hs 2 2) ">: ")))
        (if (not hsm) (setq hsm hs) (setq hs hsm))
        (if (not esum) (prompt "\nSet Datum Point"))
 (setq ptlist nil) ; for while command
  (while
     (progn
          (setq epnt1 (getpoint "\nPick Elev. point: "))
          (setq ep1y (cadr epnt1)) ;y coord
          (setq estdy (rtos (+ (/ (- ep1y esum)hsm) esum) 2 3))  ;; vertical scale calculation
          (elblock)
          (setq ele-text (strcat "%%URL " estdy)) ; combine text into one variable
   (command "-insert" "ELBLK" epnt1 "1" "1" "0" ele-text)
          (setq by (strcat (Chr 66)(Chr 73)(Chr 74)(Chr 79)(Chr 89)(Chr 183)(Chr 86)(Chr 183)(Chr 77)))
          (setq ptlist (append ptlist (list pt))) ; to stop while command
     ) ;progn
   ) ;while
  (princ)
) ; defun
;;----------------------------------------Back to UCS World-----------------------------------------------------
(defun C:uw ()
        (command "ucs" "w")
        (prompt "\nUCS Origin is set to World")
  (princ)
) ; defun
;;----------------------------------------------End-----------------------------------------------------
Does anyone understand why this happening?
Thanks.
Anyone at all?
