Editting specified attribute with autolisp
10nji
10nji
Hello, I'm new in this forum, and I'd like you to help me.
I need to edit a lot of attribute values based on the database frequently. Doing it manually is very ineffficient, so I'd like to make it automated. This is an example I want solve (sorry it is Japanese version):
In the above picture, for example, I want to change the attribute value "B" to "D" by entering " ATT2 D  ". If possible, I also want to edit several block attributes simultaneously from a csv file.
Because of my poor English, this instruction may be hard to understand, so please ask me anything if you cannot understand well. Thank you.
3wood
You can try command ATTOUT and ATTIN to manage multiple attributes with a csv file.
ВeekeeCZ
Also, look at Lee's programs, he has quite a few for working with attributes.
http://www.lee-mac.com/programs.html
Sea-Haven
Yes can enter string "Att2 D" note when asked for string enclose in "    "
(defun c:wow ( / str obj oldtag )
; thanks to Lee-mac for this defun
; www.lee-mac.com
(defun _csv->lst ( str / pos )
	(if (setq pos (vl-string-position 32 str))
		(cons (substr str 1 pos) (_csv->lst (substr str (+ pos 2))))
		(list str)
(setq str (getstring "\Enter att tag and new val "))
(setq obj (vlax-ename->vla-object (car  (entsel "Pick Block"))))
(setq lst (_csv->lst str))
(foreach att (vlax-invoke obj 'getattributes)
(if (= (strcase (nth 0 lst)) (strcase (vla-get-tagstring att)))
(vla-put-textstring att (nth 1 lst))
(princ)
Why not hold Ctrl key down and pick attribute does the same much easier.
10nji
OK..... Thank you @3wood and @ВeekeeCZ , I found some information seemed useful, but it is difficult for me... I have to study harder at the time being. Thanks to your Information, I can understand my problem well..
