Hello all,
Probably a very easy question for you, but not for me because of my lisp knowledge;
To clean up drawings I use 2 lisps to change blocks. One lisp makes all layers included in the block the same layer as the block itself and the other lisp makes the color of the block the same as the layer of the block.
Now I can select any block I want to change with the 1st lisp. However, if I use the 2nd lisp, all blocks in the drawing are automatically changed.
Now it says in this lisp
(COMMAND "change" "all" "" "p" "c" "bylayer" "") how should this be changed so that I first have to select 1 or more blocks to change the colors of only these blocks and not all blocks?
Thank you
Solved by paullimapa. Go to Solution.
(if (setq ss (ssget '(( 0 . "Insert"))))
(COMMAND "_.change" ss "" "_p" "_c" "bylayer" "")
(princ"\nNo Blocks Selected")
Hello Paullimapa
If I change
into
then I only have to select the blocks after all the blocks in the whole drawing have already changed to "color bylayer".
Yes. That change will now let you select the blocks instead of automatically selecting all blocks.
Reviewing the contents of the lisp code you attached, this line of code you thought was the one that selected all blocks to process is not it.
Actually, towards the beginning of the code these are the lines that automatically selects all the blocks in the drawing:
(setq blk_list (ai_table "block" 12)) ; no Xrefs or
; Xref dependents.
(if (>= (getvar "maxsort") (length blk_list)) ; Alphabetize if greater
(if blk_list (setq blk_list (acad_strlsort blk_list))) ; than maxsort.
To allow you to select the bocks you want to process replace the above with this:
; ss_blk returns a list of block names from selection
(defun ss_blk (/ en i lst nam obj ss tbl)
(vl-load-com)
(if(setq ss (ssget '(( 0 . "INSERT"))))
(progn
(repeat (setq i (sslength ss))
(setq en (ssname ss (setq i (1- i))) ; get entity
obj (vlax-ename->vla-object en) ; convert to obj
nam (vla-get-effectivename obj) ; get blknam
tbl (tblsearch"BLOCK" nam) ; get blktbl
(if (and
(not(assoc 1 tbl)) ; chk if xrf
(not(member nam lst)) ; chk if already in list
(setq lst (append (list nam) lst)) ; add to list
) ; if
) ; repeat
(if(> (length lst) 1) ; if more than 1 item found
(setq lst (vl-sort lst '(lambda (a b)(< (strcase a) (strcase b))))) ; sort
) ; progn
(princ"\nNothing selected.")
; return list of selected blk names
lst
) ; defun
(setq blk_list (ss_blk))
Hello Paullimapa,
First of all, thank you for your quick response.
However, after adjusting the lisp, I now encounter the following problem.
To make it clearer I added an image.
The top 3 circles represent the situation before I perform the lisp. The 1st of these is a block, the 2nd and 3rd a normal circle.
The circle in the block has a different color than the layer of the block itself. The 2nd is correct and the 3rd circle is not the color of the layer itself but a color that does not need to be adjusted / should remain that way.
If you look at the bottom row, this is the view after executing the lisp.
Here I first had to select the block that was not the color of the layer. The circle in the block now changes to the correct color. However, the color of the 3rd circle now also changes to its original color, while I only want to change the block that I have selected.
So the 3rd circle should remain magenta.
Remember this
This changes everything like that Circle color which is not a Block to bylayer
Make sure that’s no longer in the code
Stupid..... 😁
I actually forgot to delete it during the last change.
Always make a copy of the original first if I am going to change something.
So this row was included again.
Thank you @paullimapa. The code now works as I want it to.
Glad that finally worked out for you…cheers!!!
