Edit lisp so it can be used on MTEXT
Hi There,
Can anyone help with this lisp so it can also be used on MTEXT?
Many thanks if you can help.
Cheers
Al
(PROMPT "\nLOADING FILE .........")
;  CHANGE THE ROTATION OF SELECTED TEXT
(defun C:TT ( / selset newscl l n e as)
   (setq olderr *error* *error* err)
   (command "undo" "begin")
   (GETSYS)
;;LCA - COMMENT: The UCS command has new options.
   (COMMAND "UCS" "W")
   (setq selset (ssget)
      newrot (getorient "\nNew Orientation,Pick 2 points (Return to leave same): ")
      newscl (getreal   "\nNew Height   (Return to leave same): ")
   (if selset
      (progn
         (setq l 0 n (sslength selset))
         (while (< l n)
            (if (= "TEXT" (cdr (assoc 0 (setq e (entget (ssname selset l))))))
               (progn
                  (prompt ".")
                  (if newscl
                     (progn
                        (setq s (cdr (setq as (assoc 40 e))))
                        (setq e (subst (cons 40 newscl) as e))
                        (entmod e)
                  (if newrot
                     (progn
                        (setq s (cdr (setq as (assoc 50 e)))
                           ;             cur (getvar "UCSNAME")
                           ;             n (cdr (assoc 12 (tblsearch "UCS" cur)))
                           ;             m (cdr (assoc 10 (tblsearch "UCS" cur)))
                           ;             ax (- (cadr n) (cadr m) ) bx (- (car n) (car m) )
                           ;             alpha (atan ax bx)
                        (setq e (subst (cons 50 newrot) as e))
                        (entmod e)
            (setq l (1+ l))
   (command "ucs" "p")
   (command "osnap" "none")
   (command "move" "P" "" pause pause)
   (resetsys)
   (command "undo" "end")
   (princ)
paullimapa
Have you tried using the Express Tool command: TORIENT
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
Paul Li
IT Specialist
@The Office
Hi There,
Thanks for your reply.
For drafting purposes to get this to work in this Lisp is much more efficient for us.
Allan
ВeekeeCZ
@Anonymous wrote:
Hi There,
Cheers
Al
This could be very simple... just change of one line..
Spoiler
  (setq selset (ssget))
   (GETSYS)
   (COMMAND "UCS" "W")
   (setq
      newrot (getorient "\nNew Orientation, Pick 2 points (Return to leave same): ")
   (if selset
      (progn
         (while (< l n)
            (if (wcmatch "*TEXT" (cdr (assoc 0 (setq e (entget (ssname selset l))))))
               (progn
                  (prompt ".")
                  (if newscl
                     (progn
                        (entmod e)
                  (if newrot
                     (progn
                        (entmod e)
            (setq l (1+ l))
   (command "ucs" "p")
   (resetsys)
   (princ)
Also I do recommend to separate ssget function and move it in front of first command function. This allows you preselection.
allanthebruce
Thanks for your reply, Did you test this, I still cant get it to rotate to the direction I am wanting? It seems to ignore my rotation I am specifying??
Any ideas is much appreciated.
Allan
ВeekeeCZ
I did... but something else. wcmatch must be otherwise... Sorry about it.
(if (wcmatch (cdr (assoc 0 (setq e (entget (ssname selset l))))) "*TEXT")
allanthebruce
Legend! Thanks so much!!
Cheers
Al
