Edit lisp help
Edit lisp help
chan230984
Message 1 of 15
Edit lisp help
chan230984
Hi all,
I'm looking for some help editing a lisp
I have Lisp and I want some help.
After Command asks Next level Position, I want to select object of the all circle.
And get results as in the picture
thanks !
(defun LM:UnFormat ( str mtx / _replace rx )
(defun _replace ( new old str )
(vlax-put-property rx 'pattern old)
(vlax-invoke rx 'replace str new)
(if (setq rx (vlax-get-or-create-object "VBScript.RegExp"))
(progn
(setq str
(vl-catch-all-apply
(function
(lambda ( )
(vlax-put-property rx 'global actrue)
(vlax-put-property rx 'multiline actrue)
(vlax-put-property rx 'ignorecase acfalse)
(foreach pair
("\032" . "\\\\\\\\")
(" " . "\\\\P|\\n|\\t")
("$1" . "\\\\(\\\\[ACcFfHLlOopQTW])|\\\\[ACcFfHLlOopQTW][^\\\\;]*;|\\\\[ACcFfHLlOopQTW]")
("$1$2/$3" . "([^\\\\])\\\\S([^;]*)[/#\\^]([^;]*);")
("$1$2" . "\\\\(\\\\S)|[\\\\](})|}")
("$1" . "[\\\\]({)|{")
(setq str (_replace (car pair) (cdr pair) str))
(if mtx
(_replace "\\\\" "\032" (_replace "\\$1$2$3" "(\\\\[ACcFfHLlOoPpQSTW])|({)|(})" str))
(_replace "\\" "\032" str)
(vlax-release-object rx)
(if (null (vl-catch-all-error-p str))
str
(vl-load-com)
(defun c:chm ( / level p0 p1)
(setvar "cmdecho" 0)
(command "._undo" "_begin")
(if (and (setq level (atof (LM:UnFormat (cdr (assoc 1 (entget (car (entsel "\nFirst level: "))))) nil)))
(setq p1 (getpoint "\nSpecify first level position: "))
(progn
(setq p0 p1)
(command "._leader" p1 "@0.65<45" "" (strcat "EL=" (rtos level 2 3)) "")
(while (setq p1 (getpoint "\nSpecify next level position: "))
(command "._leader" p1 "@0.65<45" "" (strcat "EL=" (rtos (+ level (- (cadr p1) (cadr p0))) 2 3)) "")
); progn
); if
(command "._undo" "_end")
(setvar "cmdecho" 1)
(princ)
Replies (14)
Message 2 of 15
pbejse
@chan230984 wrote:
After Command asks Next level Position, I want to select the object of the circle.
How is that different from selecting the center of the circle ?
That appears to be working fine @chan230984
Message 3 of 15
chan230984
@pbejse
I have a lot of circles
And it will make my work faster If I select all circle, just one click.
Message 4 of 15
chan230984
@pbejse  I typed it wrong
select all circle not a circle
Message 5 of 15
pbejse
@chan230984 wrote:
@pbejse
You want to select mulitple cirlces?
	 (null
	 (princ "\nSelect Circle object for Next level position: ")
	 (setq circles (setq on (ssget  '((0 . "Circle")))))
      	(repeat (setq i (sslength circles))
	  (setq p0 p1)
		(setq p1 (cdr (assoc 10 (entget (ssname circles (setq i (1- i)))))))
); if
(princ)
Message 6 of 15
chan230984
@pbejse
Hi friend, Please Edit this Lisp again Because something wrong
thank you !
Message 7 of 15
Kent1Cooper
I suspect this much:
    (setq p0 p1)
should be more like this:
    ;;;;; (setq p0 p1) ; not needed -- all in relation to 'level' value, not previous Circle
    (command "._leader" p1 "@0.65<45" "" (strcat "EL=" (rtos (+ level (- (cadr p1) level)) 2 3)) "")
Kent Cooper, AIA
Message 8 of 15
chan230984
@Kent1Cooper
Not yet
Message 9 of 15
pbejse
Is it all good now?
Message 10 of 15
chan230984
@pbejse
not
Message 11 of 15
pbejse
@chan230984 wrote:
@pbejse
not
Remind me again what the lisp code is about? can you please post the equivalent drawing sample of the imaghe you posted and show the "correct" results.
Message 12 of 15
chan230984
@pbejse
Sorry I am not good an English
Please see Picture Below
Message 13 of 15
pbejse
	 (null
	 (setq p0 p1 circles (setq on (ssget  '((0 . "Circle")))))
); if
(princ)
HTH
Message 14 of 15
chan230984
@pbejse
thanks again! you are a good man
Message 15 of 15
pbejse
@chan230984 wrote:
@pbejse
Good for you, You are welcome.
