Dynamic block lisp
Dynamic block lisp
Dynamic block lisp
I have applied stretch action for block VD ,I want to insert this block on duct in different size with two points one is insertion point and other stretch end pont (for chande the size of VD) How it is work by LISP
Anyone ,Can u help me
 i have attched block VD
Ajilal.Vijayan
There are some Dynamic Block functions created by Lee Mac.
http://www.lee-mac.com/dynamicblockfunctions.html
So to change the Distance1 value to 500, you can do like this
(defun c:test ()
	(setq lst '(("Distance1" . "500")))
	(setq blk (vlax-ename->vla-object (ssname (ssget) 0)))
	(LM:setdynprops blk lst)
i can't work with this programe
Ajilal.Vijayan
You have to add or appload the function also.
Full code.
(vl-load-com)
(defun c:test ()
;; Set Dynamic Block Properties  -  Lee Mac
;; Modifies values of Dynamic Block properties using a supplied association list.
;; blk - [vla] VLA Dynamic Block Reference object
;; lst - [lst] Association list of ((<Property> . <Value>) ... )
;; Returns: nil
(defun LM:setdynprops ( blk lst / itm )
    (setq lst (mapcar '(lambda ( x ) (cons (strcase (car x)) (cdr x))) lst))
    (foreach x (vlax-invoke blk 'getdynamicblockproperties)
        (if (setq itm (assoc (strcase (vla-get-propertyname x)) lst))
            (vla-put-value x (vlax-make-variant (cdr itm) (vlax-variant-type (vla-get-value x))))
nothing happen
can u give example with strech property
