Dwgs cleanup
09:18 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all,
A former staff had not fully finished this lisp to cleanup dwg. This is to fix textstyle (all fonts should be Arial), layers, dimension, leaders. It also merge layers and preform audit.
It seems to work only on certain drawings. At some drawing, it had error-bad argument type nil.
Please help me to fix this lisp.
IDP-2P02 Partition Plan.dwg - seems to fix the dwg.
X_STRCT1,dwg - Attributes in block is fixed. Text in block not fixed. ZONED AREA - Style: DISTSY should be 18-TEXT.
I don't seem to be able to attached more xref dwg.
Thanks in advance.
mcmk8
(defun c:cleanup (/ col count ent ent_data ent_lay ent_sty ent_ht len new_lay new_tstyle obj_lay ssetmtxt dscl ent_col txtht)
(if (setq ssetmtxt (ssget "_X" '((0 . "*TEXT"))))
(progn
(setq len (sslength ssetmtxt)
count 0
);end setq
(while (< count len)
(setq ent (ssname ssetmtxt count)
ent_data (entget ent)
ent_sty (cdr (assoc 7 ent_data))
ent_lay (cdr (assoc 8 ent_data))
ent_ht (cdr (assoc 40 ent_data))
ent_col (cdr (assoc 62 ent_data))
dscl (getvar "dimscale")
);end setq
(if (= (getvar "ctab") "Model")
(setq txtht (/ ent_ht dscl))
(setq txtht ent_ht)
);enf if
(cond
((wcmatch ent_sty "ROMANS")
(cond
((= txtht 1.3) (setq new_tstyle "13-TEXT") (setq obj_lay ent_lay) (setq col 1))
((= txtht 1.8) (setq new_tstyle "18-TEXT") (setq obj_lay ent_lay) (setq col 7))
((= txtht 2.5) (setq new_tstyle "25-TEXT") (setq obj_lay ent_lay) (setq col 7))
((= txtht 3.5) (setq new_tstyle "35-TEXT") (setq obj_lay ent_lay) (setq col 2))
((= txtht 5.0) (setq new_tstyle "5-TEXT") (setq obj_lay ent_lay) (setq col 5))
((= txtht 7.0) (setq new_tstyle "7-TEXT") (setq obj_lay ent_lay) (setq col 6))
(T (setq obj_lay ent_lay) (setq new_tstyle "18-TEXT") (setq col 7) (setq txtht ent_ht))
);end cond
);end wcmatch
((wcmatch ent_lay "TXT-#,TXT-##")
(cond
((= ent_lay "TXT-13") (setq obj_lay "TEXT-13") (setq col 1))
((= ent_lay "TXT-18") (setq obj_lay "TEXT-18") (setq col 7))
((= ent_lay "TXT-25") (setq obj_lay "TEXT-25") (setq col 7))
((= ent_lay "TXT-35") (setq obj_lay "TEXT-35") (setq col 2))
((= ent_lay "TXT-5") (setq obj_lay "TEXT-5") (setq col 5))
((= ent_lay "TXT-7") (setq obj_lay "TEXT-7") (setq col 6))
(T (setq obj_lay ent_lay) (setq txtht ent_ht) (setq col 7))
);end cond
);end wcmatch
((wcmatch ent_sty "TXT-#,TXT-##")
(setq new_tstyle (strcat (substr ent_sty 5) "-TEXT"))
(setq obj_lay (strcat "TEXT-" (substr ent_sty 5)))
(setq new_lay (cons 8 (strcat "TEXT-" (substr ent_sty 5))))
(cond
((= obj_lay "TEXT-13") (setq col 1))
((= obj_lay "TEXT-18") (setq col 7))
((= obj_lay "TEXT-25") (setq col 7))
((= obj_lay "TEXT-35") (setq col 2))
((= obj_lay "TEXT-5") (setq col 5))
((= obj_lay "TEXT-7") (setq col 6))
(T (setq obj_lay ent_lay) (setq col 7) (setq txtht ent_ht))
);end cond
);end wcmatch
);end cond
(if (not (tblsearch "Layer" obj_lay))
(command "-Layer" "make" obj_lay "Color" col "" "")
);end if
(command "-style" new_tstyle "arial" txtht "" "" "" "")
; (setq obj_layer (entmod (subst (cons 8 obj_lay) (assoc 8 ent_data) ent_data)))
; (setq obj_style (entmod (subst (cons 7 new_tstyle) (assoc 7 ent_data) ent_data)))
(setq ent_data (subst (cons 8 obj_lay) (assoc 8 ent_data) ent_data))
(setq ent_data (subst (cons 7 new_tstyle) (assoc 7 ent_data) ent_data))
(entmod ent_data)
(setq count (1+ count))
);end while
);end progn
);end if
(princ)
(setq ssetdim (ssget "_X" '((0 . "DIMENSION,LEADER")))
len (sslength ssetdim)
count 0
);setq
(setq ent (ssname ssetdim count)
ent_name (cdr (assoc 3 ent_data))
);setq
(cond
((wcmatch ent_name "DIM#")(setq new_dstyle (cons 3 (substr ent_name 1 4))))
((wcmatch ent_name "DIM##")(setq new_dstyle (cons 3 (substr ent_name 1 5))))
((wcmatch ent_name "DIM###")(setq new_dstyle (cons 3 (substr ent_name 1 6))))
((wcmatch ent_name "DIM#$#")(setq new_dstyle (cons 3 (substr ent_name 1 4))))
((wcmatch ent_name "DIM##$#")(setq new_dstyle (cons 3 (substr ent_name 1 5))))
((wcmatch ent_name "DIM###$#")(setq new_dstyle (cons 3 (substr ent_name 1 6))))
);end cond
(setq ent_data (subst new_dstyle (assoc 3 ent_data) ent_data))
(entmod ent_data)
);end while
; Returns T or nil (=fail).
(defun TextStyleChange (obj / hgt newStl stl)
(setq hgt (vla-get-height obj))
(setq stl (strcase (vla-get-stylename obj)))
(if
(and
(setq newStl
(cond
((wcmatch stl "TXT-##,TXT-#")
(strcat (substr stl 5) "-TEXT")
((= stl "ROMANS")
(cond
((vl-position hgt '(1.3 2.6 6.5 13.0 26.0 32.5 65.0 130.0))
"13-TEXT"
((vl-position hgt '(1.8 3.6 9.0 18.0 36.0 45.0 90.0 180.0))
"18-TEXT"
((vl-position hgt '(2.5 12.5 62.5 250.0))
"25-TEXT"
((vl-position hgt '(3.5 7.0 17.5 35.0 70.0 87.5 175.0 350.0))
"35-TEXT"
((vl-position hgt '(5.0 10.0 25.0 50.0 100.0 125.0 500.0)) ; Removed: 250.0.
"5-TEXT"
(T
"7-TEXT"
(or
(tblobjname "style" newStl)
(progn
(princ (strcat "\nError: " newStl " not found "))
nil
(progn
(vla-put-stylename obj newStl)
T
(defun FontChange (obj) ; Obj=text style object.
(if (wcmatch (strcase (vla-get-name obj)) "##-TEXT,#-TEXT,DIMSTYLE")
(vla-put-fontfile obj "C:/Windows/Fonts/arial.ttf")
(command "_.-LAYER" "_A" "S" "Original" "" "" ""); add Layer State Original
;end add
; (setq ctm (getvar "tilemode"))
; (setvar "tilemode "0")
; (command "vplayer" "Freeze" "*" "all" "")
; (setvar "tilemode" ctm)
(command "-layer" "off" "*" "N" "")
(command "-layer" "on" "*" "")
(command "-layer" "Freeze" "*" "")
(command "-layer" "Thaw" "*" "")
(command "-layer" "Lock" "*" "")
(command "-layer" "Unlock" "*" "")
(if (not (tblsearch "LAYER" "DIM1,DIM2,DIM5,DIM10,DIM20,DIM50,DIM100,DIM-N"))
(command "-LAYER" "M" "DIM1" "C" "7" ""
"M" "DIM2" "C" "7" ""
"M" "DIM5" "C" "7" ""
"M" "DIM10" "C" "7" ""
"M" "DIM20" "C" "7" ""
"M" "DIM50" "C" "7" ""
"M" "DIM100" "C" "7" ""
"M" "DIM-N" "C" "7" "" ""
); end command
); end if
(command ".-laymrg" "n" "DIM1" "" "N" "DIM-N" "Y")
(command ".-laymrg" "n" "DIM2" "" "N" "DIM-N" "Y")
(command ".-laymrg" "n" "DIM5" "" "N" "DIM-N" "Y")
(command ".-laymrg" "n" "DIM10" "" "N" "DIM-N" "Y")
(command ".-laymrg" "n" "DIM20" "" "N" "DIM-N" "Y")
(command ".-laymrg" "n" "DIM50" "" "N" "DIM-N" "Y")
(command ".-laymrg" "n" "DIM100" "" "N" "DIM-N" "Y")
(command "_.-PURGE" "_La" "DIM1,DIM2,DIM5,DIM10,DIM20,DIM50,DIM100,DIM-N" "_N")
(princ)
(princ "\nLayers merged...")
(princ)
;end add
(if (not (tblsearch "LAYER" "TXT-12.5,TXT-13,TXT-18,TXT-25,TXT-35,TXT-5,TXT-7,TEXT-12.5,TEXT-13,TEXT-18,TEXT-25,TEXT-35,TEXT-5,TEXT-7,RESERVES,RESERVES-N,MIRROR,MIRRORS, 13-TEXT,18-TEXT,25-TEXT,35-TEXT,5-TEXT,7-TEXT,REV-CLOUD"))
(command "-LAYER" "M" "TXT-12.5" "C" "1" "TXT-12.5"
"M" "TXT-13" "C" "1" "TXT-13"
"M" "TXT-18" "C" "7" "TXT-18"
"M" "TXT-25" "C" "7" "TXT-25"
"M" "TXT-35" "C" "2" "TXT-35"
"M" "TXT-5" "C" "5" "TXT-5"
"M" "TXT-7" "C" "6" "TXT-7"
"M" "TEXT-12.5" "C" "1" "TEXT-12.5"
"M" "TEXT-13" "C" "1" "TEXT-13"
"M" "TEXT-18" "C" "7" "TEXT-18"
"M" "TEXT-25" "C" "7" "TEXT-25"
"M" "TEXT-35" "C" "2" "TEXT-35"
"M" "TEXT-5" "C" "5" "TEXT-5"
"M" "TEXT-7" "C" "6" "TEXT-7"
"M" "RESERVES" "C" "1" "RESERVES"
"M" "RESERVES-N" "C" "1" "RESERVES-N"
"M" "MIRROR" "C" "1" "MIRROR"
"M" "MIRRORS" "C" "1" "MIRRORS"
"M" "REV-CLOUD" "C" "10" ""
"S" "0" ""
);command
);if
(command "_.-LAYER" "_A" "R" "Original" "" "" "")
(command "-layer" "off" "*" "N" "on" "*" "Freeze" "*" "Thaw" "*" "Lock" "*" "Unlock" "*" "")
;end add
(command ".-laymrg" "n" "TXT-12.5" "" "N" "TEXT-13" "Y")
(command ".-laymrg" "n" "TXT-13" "" "N" "TEXT-13" "Y")
(command ".-laymrg" "n" "TXT-18" "" "N" "TEXT-18" "Y")
(command ".-laymrg" "n" "TXT-25" "" "N" "TEXT-25" "Y")
(command ".-laymrg" "n" "TXT-35" "" "N" "TEXT-35" "Y")
(command ".-laymrg" "n" "TXT-5" "" "N" "TEXT-5" "Y")
(command ".-laymrg" "n" "TXT-7" "" "N" "TEXT-7" "Y")
(command ".-laymrg" "n" "RESERVES" "" "N" "RESERVES-N" "Y")
(command ".-laymrg" "n" "MIRROR" "" "N" "MIRRORS" "Y")
(command "_.-PURGE" "_La" "TEXT-12.5,TEXT-13,TEXT-18,TEXT-25,TEXT-35,TEXT-5,TEXT-7,RESERVES-N,MIRRORS,DIM-N" "N")
(command "_.-LAYER" "_A" "R" "Original" "" "")
(if (not (tblsearch "style" "13-TEXT,18-TEXT,25-TEXT,35-TEXT,5-TEXT,7-TEXT"))
(COMMAND "-STYLE" "13-TEXT" "arial" 1.3 "" "" "" ""
"-STYLE" "25-TEXT" "arial" 2.5 "" "" "" ""
"-STYLE" "35-TEXT" "arial" 3.5 "" "" "" ""
"-STYLE" "5-TEXT" "arial" 5.0 "" "" "" ""
"-STYLE" "7-TEXT" "arial" 7.0 "" "" "" ""
"-STYLE" "18-TEXT" "arial" 1.8 "" "" "" ""
); end command
);end if
(setq doc (vla-get-activedocument (vlax-get-acad-object)))
(vlax-for obj (vla-get-textstyles doc)
(FontChange obj)
(vlax-for blk (vla-get-blocks doc)
(if (= :vlax-false (vla-get-isxref blk))
(vlax-for obj blk
(if (= (vla-get-objectname obj) "AcDbAttributeDefinition")
(TextStyleChange obj)
(if (setq ss (ssget "_X" '((0 . "INSERT") (66 . 1))))
(repeat (setq i (sslength ss))
(foreach obj (vlax-invoke (vlax-ename->vla-object (ssname ss (setq i (1- i)))) 'getattributes)
(vla-regen doc acallviewports)
(command "_audit" "Y")
(princ)
