DWG to PDF
DWG to PDF
gobluejd
Message 1 of 48
DWG to PDF
gobluejd
This is what I need to do:
Replace the Qsave command with a custom command that every time I save a DWG I want it to create a PDF in the background, save it like the exportpdf command does (names it the same filename - no layout info and save over an existing file if there is one).  It will always be saved to the same directory.
Right now I can use autopublish, but it adds the name of the layout tab.  I need it to be just the acutal file name, for example - test.dwg = test.pdf.
Can anyone help me?
Replies (47)
Message 41 of 48
hmsilva
Try to copy/past the code in my previous post, in command line.
Henrique
Message 42 of 48
gobluejd
I did and all I get is this: (then I tried just (command "export") and get a response as mentioned in my last post).
Message 43 of 48
hmsilva
Was the .pdf file created?
Henrique
Message 44 of 48
gobluejd
No.
Message 45 of 48
hmsilva
Jeff,
as this is a 'mac' specific problem, try to post in AutoCAD for Mac General Discussion it will be easier to get some help on your code.
Henrique
Message 46 of 48
gobluejd
Ok thanks!
Message 47 of 48
gobluejd
@hmsilva I am trying to add this to AutoCad 2020 and do not see that it is using the same file "acaddoc.lsp" that you modified for me some years ago.  Is there a way to still implement this?  I use use lsp 100x a day and can't live with out it!!!
Message 48 of 48
gobluejd
@hmsilva ignore.  I just copied and it worked.  Sorry!
