Autolisp documentation
Tony_Gibbs
Message 1 of 20
Tony_Gibbs
This link
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1911627
lists
Replies (19)
Message 2 of 20
wispoxy
The last time I gave someone a large and detailed description on how to download all of the pages together, a discussion admin came in and removed my post that I spent atleast 5min typing. I believe Autodesk doesn't want anyone downloading them. Takes less than 2min, but apparently it's frowned upon by Autodesk.
Message 3 of 20
rkmcswain
What? Why? That makes no sense.
@Discussion_Admin
R.K. McSwain     | CADpanacea | on twitter
Message 4 of 20
wispoxy
@rkmcswain I have no idea. Tried it twice, first time a discussion admin removed it, then I asked why, using a similar answer. Then a moderator removed my similar answer post questioning why.
Message 5 of 20
wispoxy
@rkmcswain And Autodesk really likes when you bring up the forum ranking system. Watch this post get removed.
Message 6 of 20
Tony_Gibbs
Wisp
You could always send the instructions to tunza@toltrip.com.au
Regards Delta
Message 7 of 20
Discussion_Admin
@Discussion_Admin
I Have to agree @rkmcswain.
@wispoxy Are you sure you are not confusing the subject with something else that was for subscriptions only?. That would have been edited.
As we do not delete anything but move them to a special location I made search for your "posts" and came up blank on the subject.
Can you help refresh my memory.
And on trying figuring out the ranking system well that's a no brainer right.Smiley Happy
Discussion_Admin
Message 8 of 20
Tony_Gibbs
So Discussion_Admin
Can you help with my original question about the download??
Regards Delta
Message 9 of 20
Discussion_Admin
Let me see if I can find an answer for you
Discussion_Admin
Message 10 of 20
philip.s
Hello @Tony_Gibbs,
After speaking with the ADN team I can confirm that both the AutoCAD 2015 Reference and Developers Guides are not available for download. I can confirm that the team is looking into expanding accessibility next year which obviously doesn't help now.
That being said and to help the team identify improvement opportunities for next year, was there a particular reason that you wanted to download the full docs? Possibly a navigation issue and/or inability to be online?
Message 11 of 20
Tony_Gibbs
Hi Philip
Thanks for getting back to me. the reason I want the entire documentation is because it is too slow and cumbersome for me to try to use the reference material on line, and aslo i study away from the cumputer from time to time.
Regards Tony
Message 12 of 20
Tony_Gibbs
Hi Philip
Any luck with the documentation
Tony
Message 13 of 20
kerry_w_brown
Tony,
Which version of AutoCAD do you have installed ??
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
Message 14 of 20
Tony_Gibbs
2015 & 2016
Message 15 of 20
kerry_w_brown
deltawaservices wrote:
2015 & 2016
So you already have the Help installed locally ??
You can make a shortcut on your desktop and point it to something like :
file:///C:/Program%20Files/Autodesk/AutoCAD%202016%20Help/English/Help/index.html#!/url=./files/homepage_dev.htm
Message 16 of 20
Tony_Gibbs
This appears to be all I have
Message 17 of 20
kerry_w_brown
Try
https://knowledge.autodesk.com/support/autocad/downloads/caas/downloads/content/download-install-aut...
Message 18 of 20
Tony_Gibbs
Thank you Kerry
Message 19 of 20
kerry_w_brown
You're welcome.
Hope that helped Tony
Message 20 of 20
wispoxy
@Discussion_Admin I don't know if it was a subscription, I wasn't told, maybe it was. Not too concerned right now because I can't really prove I'm not at fault. I wish there was a notice like 'not for sharing'. How do I know if a PDF guide is for subscriptions only?
If you don't just delete posts, can I just share the: .message-id
for any future problems that may arise with posts?
and if a post is completely removed, is it ok if we flush our local cache and re-cert it to obtain the .message-id (or is it considered inappropriate behaviour)? Will Autodesk be able to connect ids even if the post is completely removed?
@kerry_w_brown Well done solving the problem.
@Tony_Gibbs Glad to see your problem was resolved.
