DrawOrder lisp Routine
nbawden
Message 1 of 11
nbawden
I found the following lisp routine over on the AUGI forums which was created by user alanjt
(defun c:Test (/ layerList data ss)
  (foreach layer '("Water" "Gas" "Electric" "Text" "Dimensions")
    (if (and (setq data (tblsearch "LAYER" layer)) ; layer exists
             (zerop (logand 4 (cdr (assoc 70 data)))) ; layer unlocked
             (setq ss (ssget "_X" (list (cons 8 layer)))) ; layer has objects
      (command "_.draworder" ss "" "_front")
  (princ)
After looking around this lisp is almost exactly what I am after - except for one thing.
I would really like to be able to set all of the the specified layers to have their Draw Order below another specified layer.
Could any lisp gurus help out with this tweak?
Replies (10)
Message 2 of 11
ВeekeeCZ
(defun c:Test (/ data ss en sr)
  (if (and (setq en (car (entsel "\nSelect object on reference layer: ")))
           (setq sr (ssget "_X" (list (assoc 8 (entget en))))))
        (command "_.draworder" ss "" "_u" sr ""))))
  (princ)
Message 3 of 11
nbawden
Thanks - this lisp works - but out of interest how would I tweak this lisp so that the layer being set in front of the others is fixed (hard coded) and not user selected?
Message 4 of 11
ВeekeeCZ
I've simplified the code a little bit for you...
(defun c:Test (/ ss sr)
  (if (and (setq ss (ssget "_A" (list '(8 . "Water,Gas,Electric,Text,Dimensions") 	(cons 410 (getvar 'ctab)))))
           (setq sr (ssget "_A" (list '(8 . "ReferenceLayer1,ReferenceLayer2")		(cons 410 (getvar 'ctab)))))
    (command "_.draworder" ss "" "_a" sr ""))
  (princ)
_a stands for "Above", previous "_u" is for "Under"...
Message 5 of 11
nbawden
Works a treat - thanks Smiley Happy
Message 6 of 11
When I use this lisp, it asks me to select objects, ok. But then everything on the screen disappears. I don't know enough about lisp to read the routine and know what is happening. Any advice? Thanks.
Message 7 of 11
devitg
Message 8 of 11
This doesn't do anything.  Is there an update for AutoCAD Map 2019?
  (princ)
Message 9 of 11
dlanorh
  (princ)
If you don't have these layers (red items above) in your drawing it won't
I am not one of the robots you're looking for
Message 10 of 11
pat_cooper54dkt
Observer
Observer
Is there a way to incorporate using a wild card? I have multiple layers all beginning with "PHA"  and want them all sent to the back.
Message 11 of 11
devitg
@pat_cooper54dkt
Please upload the LSP you are using or want to modify , and a sample.dwg
