Draw with Dialog Box
Lex_van_Ham
Message 1 of 19
Lex_van_Ham
I am new to scripting and I want to make a dialog box with text fields where i can insert a value and then have autocad use that value to make a drawing. I got the box to show everything I want and now I have to get it to actually do something. Can someone help me?
This is what i got so far:Layout Creator.PNG
Replies (18)
Message 2 of 19
Lex_van_Ham
31 views later and 0 replies so ill retry this question.
So what i want to happen is that the line (and other)  commands are activated using the values from the editboxes when i click OK.
How do i do that?
Message 3 of 19
Moshe-A
post the dcl file you have plus any code you already have.
moshe
Message 4 of 19
Lex_van_Ham
Thank you for the reply, here is waht i got so far:
LSP:
(defun C:LayoutCreator ()
(setq dcl_id (load_dialog "Layout Creator.dcl"))
(if (not (new_dialog "LayoutCreator" dcl_id)
);not
(exit)
);if
(setq x (dimx_tile "im")
y (dimy_tile "im"))
(start_image "im")
(fill_image 0 0 x y 5)
(end_image)
(action_tile
"cancel"
"(done_dialog) (setq userclick nil)"
);action_tile
(action_tile
"accept"
(strcat
(progn
"(done_dialog) (setq userclick T)"
(setq Po (get_tile "rb1"))
(setq La (get_tile "rb2"))
(setq B (get_tile "eb1"))
(setq L (get_tile "eb2"))
(setq H (get_tile "eb3"))
(setq K (get_tile "eb4"))
(setq OP (getpoint "\nInsertion point : "))
);progn
);strcat
);action_tile
(start_dialog)
(unload_dialog dcl_id)
(setq OP (getpoint ""))
(command "line" OP B)
(princ)
);defun C:LayoutCreator
(princ)
DCL:
LayoutCreator : dialog {
label = "Layout Creator" ;
: edit_box {
key = "eb1" ;
label = "Paneel Breedte :" ;
edit_width = 10 ;
: edit_box {
key = "eb2" ;
label = "Paneel Lengte :" ;
edit_width = 10 ;
: edit_box {
key = "eb3" ;
label = "Paneel Hoogte :" ;
edit_width = 10 ;
: edit_box {
key = "eb4" ;
label = "kolommen :" ;
edit_width = 10 ;
: edit_box {
key = "eb5" ;
label = "Rijen :" ;
edit_width = 10 ;
:boxed_radio_column {
label = "Opstelling" ;
: radio_button {
key = "rb1" ;
label = "Portret" ;
value = "1" ;
: radio_button {
key = "rb2" ;
label = "Landscape" ;
ok_cancel ;
: row {
: image {
key = "im" ;
height = 1.0 ;
width = 1.0 ;
: paragraph {
: text_part {
label = "Designed and Created";
: text_part {
label = "By Lex van Ham ";
Message 5 of 19
Moshe-A
hi,
In order to respond to any dcl tile (in this case specific to edit_box) you need to call (action_tile) functon inside a while loop scope.
where the test condition of while keeps the dialog ON untill you press the OK button or the Cancel button which by default fires a default callback function that calls (done_dialog x) with 1/0 integer value to return to (start_dialog) function.
; next is default autolisp behavior
(done_dialog 1) returns 1 (=ok)
(done_dialog 0) return  0 (=cancel)
initilazatizing tiles also must be done inside while scope
i only format the code, debuging it is on you Smiley Very Happy
cheers,
Moshe
(defun init_tiles ()
 (setq x (dimx_tile "im") y (dimy_tile "im"))
 (start_image "im")
 (end_image)
 ; do more tiles initilazation here
; callback
(defun ctrl_edit_box (value key)
 ; be aware that value is a string, use (atoi) or (atof) to convert it to integer\double numbers.
 ; also check here the validation and range of values
 (if (/= value "")
  (cond
   ((eq key "eb1")
    (setq B value)
   ((eq key "eb2")
    (setq L value)
   ((eq key "eb3")
    (setq B value))
   ((eq key "eb4")
    (setq K value))
  ); cond
 ); if
); ctrl_edit_box
; callback
(defun ctrl_radio_button (value key)
 (cond
  ((eq key "rb1")
   (setq Po value)
  ((eq key "rb2")
   (setq La value)
 ); cond
); ctrl_radio_button
(defun C:LayoutCreator (/ dcl_id what_next)
 (setq dcl_id (load_dialog "Layout Creator"))
 (setq what_next 2)
 (while (> what_next 1)
  (if (not (new_dialog "LayoutCreator" dcl_id "" '(-1 -1))); open dialog
   (exit)
  (init_tiles); initialize tiles
  ; define callback functions
  (action_tile "eb1" "(ctrl_edit_box $value $key)")
  (action_tile "eb2" "(ctrl_edit_box $value $key)")
  (action_tile "eb3" "(ctrl_edit_box $value $key)")
  (action_tile "eb4" "(ctrl_edit_box $value $key)")
  (action_tile "rb1" "(ctrl_radion_button $value $key)")
  (action_tile "rb2" "(ctrl_radion_button $value $key)")
  (setq what_next (start_dialog)); start dialog
  (cond
   ((= what_next 0)
     ; user cancel the dialog, do cleanup here
   ((= what_next 1)
    ; user OK the dialog, do cleanup here
    ; do your work here
    (command "line" OP pause "")
  ); cond
 ); while
 (princ)
); C:LayoutCreator
Message 6 of 19
Lex_van_Ham
one more thing tho, how do i set the Insertion point (OP) to always be 0,0,0?
Message 7 of 19
Moshe-A
(setq OP '(0.0 0.0 0.0))
Message 8 of 19
Lex_van_Ham
Now i have this and everything works except it doesnt like B as a value. when i change it to a number like 123 it works fine and creates a line 123 long starting from 0,0,0 but when i make it B and put 123 in the editbox it says: ; error: bad argument type: numberp: "123"
(cond
((= what_next 0)
((= what_next 1)
; do your work here
(setq P1 (polar OP (dtr 0) B ))
(command "pline" OP P1 )
); cond
Message 9 of 19
Moshe-A
i am sorry but you did not pay attention to what i comment in the (ctrl_edit_box) function
; callback
all values coming from dialog box are strings and must be converted to numbers if they are not need as strings.
also (dtr) is function where it's definition?
instead why not to use radians angles?
0.0           is "0.00"     degrees
(* pi 0.25) is "45.00"   degrees
(* pi 0.50) is "90.00"   degrees
(* pi 1.50) is "270.00" degrees
Moshe
Message 10 of 19
Lex_van_Ham
i added the dtr function a few minutes ago
(defun dtr (x)
(* pi (/ x 180.0))
so i can use degrees instead of radians.
Sorry im pretty new to making any type of script as i started trying to understand it last monday.
Can you explain how i convert the string to integer\double numbers?
Message 11 of 19
Lex_van_Ham
So im not sure if i used atoi the way its supposed to be used but i think it works:
(setq P1  (polar OP (dtr 0) ( atoi B)))
Message 12 of 19
Moshe-A
in autolisp documentation take a look at the follwing functions
(atoi)       ; convert a string into integer.
(atof)       ; convert a string into a real number (floating-point).
(angtos)   ; convert an angular value in radians into a string, based on angular units
(angtof)   ; convert a string into a real number, based on angular units.
(distof)     ; convert a string that represent a real (floating-point) value into a real value, based on angular units
(rtos)       ; convert a number into a string, based on linear units
Message 13 of 19
Moshe-A
(atoi B) is good (but be aware that if B is "12.98" you will end up with 12)
remenber that (polar) function expect radians angle so converting degrees angle to radians is ok but redundant
only when a function is expecting degrees angle you can use (rtd) or (angtos)
here is an example:
let's say you select some objects and want to rotate them 45 degrees about 0,0,0
(if (setq ss (ssget))
 (command "rotate" "si" ss '(0 0 0) (rtd (* pi 0.25)))  ; or (angtos (* pi 0.25) 0 4) is also good.
"si" by the way stands for "single" and it's an option of autocad select objects
it saves specifing empty double quotes ("") to respod for the end of select objects in the (command) function
 here is the same example without "single"
 (command "rotate" ss "" '(0 0 0) (rtd (* pi 0.25)))  ; or (angtos (* pi 0.25) 0 4) is also good.
Moshe
Message 14 of 19
Moshe-A
thank you very much for all the 'kudos' you sent me
does your lisp work now?
Message 15 of 19
Lex_van_Ham
Yes but i have 1 problem, it sees the R value always as 2 no matter what i type in it.
I made some changes to the code including an array and plines so here is the new one.
(start_image "im")
(end_image)
; callback
(if (/= value "")
(cond
((eq key "eb1")
(setq B (atof value)))
((eq key "eb2")
(setq L (atof value)))
((eq key "eb3")
(setq H (atof value)))
((eq key "eb4")
(setq K (atof value)))
((eq key "eb5")
(setq R (atof value)))
); cond
); if
); ctrl_edit_box
; callback
(cond
((eq key "rb1")
(setq Po value)
((eq key "rb2")
(setq La value)
); cond
;This function converts Degrees to Radians.
(defun dtr (x)
;define degrees to radians function
(* pi (/ x 180.0))
;divide the angle by 180 then
;multiply the result by the constant PI
) ;end of function
(setq what_next 2)
(exit)
(cond
((= what_next 0)
((= what_next 1)
; do your work here
(setvar 'clayer "Montagesysteem")
(setq MOP '(0.0 0.0 0.0))
(setq MP1 (polar MOP (dtr 0) (+ (* B K)(* (/ (* B K ) B ) 2 ))))
(setq MP2 (polar MP1 (dtr 90) (+ (+ (* L R) (* (/ (- (* L R) L )L ) 12)) 80)))
(setq MP3 (polar MP2 (dtr 180) (+ (* B K)(* (/ (* B K ) B ) 2 ))))
(setq MP4 (polar MP3 (dtr 270) (+ (+ (* L R) (* (/ (- (* L R) L )L ) 12)) 80)))
(command "pline" MOP MP1 MP2 MP3 MP4 "")
(setvar 'clayer "Panelen")
(setvar 'OSMODE 0)
(setq POP '( 1.0 40.0 0.0 ))
(setq PP1 (polar POP (dtr 0) B))
(setq PP2 (polar PP1 (dtr 90) L))
(setq PP3 (polar PP2 (dtr 180) B))
(setq PP4 (polar PP3 (dtr 270) L))
(command "pline" POP PP1 PP2 PP3 PP4 "")
(command "array" "_last" "" "Rectangular" R K (+ L 12)(+ B 2))
(setvar 'OSMODE 167)
); cond
); while
(princ)
); C:LayoutCreator
Message 16 of 19
Lex_van_Ham
Nevermind i found the problem.
i needed to add the line (action_tile "eb5" "(ctrl_edit_box $value $key)")
Message 17 of 19
ВeekeeCZ
(setvar 'OSMODE 0)
(command "pline" MOP MP1 MP2 MP3 MP4 "")  ; << turn the osnaps off for this command as well
(setvar 'OSMODE 0)
Also can be used "_none". Then you don't need care about changing OSMODE off and on again.
eg. (command "_.RECTANG" "_none" pop "_non" pt2)
Anyway, if you use the "PEDIT" its better to use (command "pline" POP PP1 PP2 PP3 "_close")
Message 18 of 19
Lex_van_Ham
Now i have a new problem...
I made a new subject for it here:
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/array-1-row/td-p/7803194
Message 19 of 19
scot-65
Looking at your attached image, there need not be any action_tiles to any of the
tiles except for OK and Cancel. The accept structure is in the right direction, but
the syntax is a bit off...
(action_tile
"accept"
(strcat
(progn
);progn
);strcat
);action_tile
(action_tile "accept" "(sub-function_call_here)(done_dialog 1)")
There can be nothing outside the second set of quotes inside the action_tile statement.
There can only be a total of 4 quotes inside action_tile. If more, they require escaping [\"].
You cannot use GETPOINT in this manner while inside action_tile. Take advantage of the
integer return from done_dialog to start dialog --> to enter in the "main" execution portion
of your code. Also, technically, the dialog is closed at the time you are trying to setq and
therefore the values you wish to fetch are already gone. Also, flip your "cancel" and add
a 0 to it's done_dialog.
Use the sub-function call to setq all the variables as I show, then call (done_dialog 1).
(setq sd (start_dialog))
then,
(if (and sd (= sd 1) (setq OP (getpoint "\nSpecify insert point: ")))
 (progn
 );progn
);if
load dialog
new dialog
 initialize
 set tile
 mode tile
 action tile
done dialog
start dialog
unload dialog
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
