array 1 row
array 1 row
Lex_van_Ham
array 1 row
Lex_van_Ham
I made a lisp file that creates an array with the values of R (rows) K (columns) L (Lenght) B (Width)
and when i make the array 1 row it uses the value of L where it should be B
(command "array" "_last" "" "Rectangular" R K (+ L 12)(+ B 2))
Kent1Cooper
True -- when there's only one row, the command doesn't ask for a spacing between them [it, actually].  You can take the command to the point of having gotten the number of rows and columns, and then follow up with answers to the spacings depending on whether there's more than one of either or both.  Lightly tested:
(command "array" "_last" "" "Rectangular" R K); leaves you in Array command
(if (> R 1) (command (+ L 12))); feed in row spacing only if applicable
(if (> K 1) (command (+ B 2))); likewise for column spacing
Kent Cooper, AIA
Lex_van_Ham
In my dialog box i have the option to select portret and landscape default is portret but when you click landscape it should switch the values of L and B dow do i do this?
ВeekeeCZ
Maybe just like this...
(if (> R 1) (command (+ (if (= page "Landscape") L B)
                        12)))
(if (> K 1) (command (+ (if (= page "Landscape") B L)
                        2)))
Kent1Cooper
Another way would be just what you describe.  First, do this:
(if (= page "Landscape") (setq temp L L B B temp))
then run the code in Post 2.
Kent Cooper, AIA
Lex_van_Ham
I have a new problem now...
When I enter 1 as a value for both R and  K I get:
One-element array, nothing to do.
; error: Function cancelled
Kent1Cooper
[Might it not be just as well to be notified if they're both 1, meaning there's nothing to do?]
But if there are valid circumstances that might lead to that, presumably within some longer routine, one way to handle it would be:
(if (or (> R 1) (> K 1))
  (progn ; then
  ); progn
); if
Kent Cooper, AIA
