Draw text to match a line's angle
I would like to draw "TEXT" or "MTEXT" the same angle as a line that I select.  Can anyone point me to a LISP routine that makes this easy and quick?
Brad
Kent1Cooper
I use the attached to change the Snap Angle to align with just about anything [not just Lines], then with Ortho on it's easy to establish the rotation angle for Text/Mtext/Block insertions/Rotate commands/etc.
Load it up, and type AS to simply Align the Snap angle with something, or ASB to Align the Snap angle and  set the Snap Base to a meaningful location on whatever the object is.
Kent Cooper, AIA
Kent,
My questions was moved to a different message board - just found it and your reply / .lsp file.  Getting ready to try it out.
Brad
Kent,
Thanks for your reply. I am unable to find your reply in the Forum /
unable to find the LISP routine that you mention. Is there anyway that you
can email it to me?
Brad
