- Mute
- Permalink
- Report
It seems that AutoCAD dev team doesn't have a clue what software they are making and who is suppose to use. I don't need tools which consume a lot of time and it makes inaccurate and is not presentable to the client. We are not in Paper age anymore.
I am looking for a simple lisp or tool to draw polyline arc circuits with a defined angle and only two-point. Then it should work is like what. First I set angle that always will 30 (that I mean by 30. It doesn't matter if I will go up, or down, or any direction it will always will make the same angle between to point) and then I start First Point, then Next point. And when Next point. So basically you start with setting angle 30, when you chose the first point, when you chose the next point, after that always next point until you decide to change the angle.
I tried AutoCAD 2021 polylines, it draws snakes or you have always type angle and also calculate angle if you go up or down or any direction and so on.
I tried AutoCAD MEP 2021 using wire objects which are crap function. You still have to chose three points.
Can some help me in this situation as Autodesk team failed to make useful and simple tools for Electrical and Lighting design.
Many thanks,
Robertas
