Draw largest rectangle within a limited shape
hs800150
Message 1 of 67
hs800150
Ok so this lisp might be too complicated but I would like to know if anyone knows a lisp to automate the largest rectangle within a space. I have attached a picture of what I mean. The red rectangle has to be a rectangle (90 degrees between each angle) and stay within the boundaries of the white shape. Lets say I can choose a width say 40' and the lisp automatically finds the largest length based on trial and error. Or if there is a lisp to find both the largest width and length that would work too.
Replies (66)
Message 61 of 67
marko_ribar
Hi @hs800150
I played with this topic for a while and I think I have fairly good solution... Be aware AFAIK that there can't be programmed for exact solution, so my codes are based on @CodeDing proposal... Still sometimes results aren't correct, but the code is fine and in some cases "complex closed 2d splines" it may fail (LM:Inside-p) sub particular when attempt to find parameter on curve of founded point of intersection of RAY and curve... In that case you have 2 options : either change initial inputs and cross your fingers, or convert 2d closed spline to perhaps closed 2d pline...
My routine works for any closed 2d curve type, and in addition I also mod. doaiena's posted code to account for intersections with curve, but here there is limitation that curve can be only closed lwpolyline polygon - lwpolyline must have all segments straight as with inputs doaiena's code is searching for rectangle adjacent to picked closest straight segment - can't be arced... I'll attach both my codes and mod. doiaena's into this post and now I think you have plenty things to check and material to mark this topic as solved... I haven't mod. @hak_vz codes - that I leave to him as he was the first one who seriously approached to this task... We'll see if there will be better solutions, but now areas for investigations are narrowed...
(defun c:max-inscrib-rect-rot-matrices ( / UCS2WCSMatrix WCS2UCSMatrix LM:Inside-p LWPoly Group3 groupbetweennils cur ucsf n m da k minp maxp ul ur ll lr dx dy r c p row mat matl ar pt pr prpos ptpos armat rownilpos p1 p2 p3 p4 q rec pl )
  (vl-load-com)
  ;; Doug C. Broad, Jr.
  ;; can be used with vla-transformby to
  ;; transform objects from the UCS to the WCS
  (defun UCS2WCSMatrix ()
    (vlax-tmatrix
      (append
        (mapcar
         '(lambda (vector origin)
          (append (trans vector 1 0 t) (list origin))
        (list '(1 0 0) '(0 1 0) '(0 0 1))
        (trans '(0 0 0) 0 1)
        (list '(0 0 0 1))
  ;; transform objects from the WCS to the UCS
  (defun WCS2UCSMatrix ()
    (vlax-tmatrix
      (append
        (mapcar
          (append (trans vector 0 1 t) (list origin))
        (trans '(0 0 0) 1 0)
        (list '(0 0 0 1))
  ; Lee Mac Point Inside Curve
  (defun LM:Inside-p ( pt ent / unit v^v _GroupByNum fd1 fd2 par lst nrm obj tmp )
    (vl-load-com)
    (defun unit ( v / d )
      (if (not (equal (setq d (distance '(0.0 0.0 0.0) v)) 0.0 1e-8))
        (mapcar '(lambda ( x ) (/ x d)) v)
    (defun v^v ( u v )
      (list
        (- (* (cadr u) (caddr v)) (* (caddr u) (cadr v)))
        (- (* (caddr u) (car v)) (* (car u) (caddr v)))
        (- (* (car u) (cadr v)) (* (cadr u) (car v)))
    (defun _GroupByNum ( l n / r )
      (if l
        (cons (reverse (repeat n (setq r (cons (car l) r) l (cdr l)) r)) (_GroupByNum l n))
    (if (= (type ent) 'VLA-OBJECT)
      (setq obj ent
            ent (vlax-vla-object->ename ent))
      (setq obj (vlax-ename->vla-object ent))
    (if (vlax-curve-isplanar ent)
      (progn
        (setq fd1 (vlax-curve-getfirstderiv ent (setq par (vlax-curve-getstartparam ent))))
        (while (equal fd1 (setq fd2 (vlax-curve-getfirstderiv ent (setq par (+ par 0.001)))) 1e-3))
        (setq nrm (unit (v^v fd1 fd2)))
        (setq lst
          (_GroupByNum
            (vlax-invoke
              (setq tmp
                  (entmakex
                    (list
                      (cons 0 "RAY")
                      (cons 100 "AcDbEntity")
                      (cons 100 "AcDbRay")
                      (cons 10 pt)
                      (cons 11 (trans '(1. 0. 0.) nrm 0))
              'IntersectWith obj acextendnone
            ) 3
        (vla-delete tmp)
        ;; gile:
        (or ;; mod M.R. inside and on curve
          (vlax-curve-getparamatpoint ent pt) ;; mod M.R. inside and on curve
          (and
            lst
            (not (vlax-curve-getparamatpoint ent pt))
            (= 1 (rem (length (vl-remove-if (function (lambda ( p / pa p- p+ p0 )
                                                        (setq pa (vlax-curve-getparamatpoint ent p))
                                                        (and (setq p- (cond ((setq p- (vlax-curve-getPointatParam ent (- pa 1e-8)))
        (trans p- 0 nrm)
        ((trans (vlax-curve-getPointatParam ent (- (vlax-curve-getEndParam ent) 1e-8)) 0 nrm)
                                                             (setq p+ (cond ((setq p+ (vlax-curve-getPointatParam ent (+ pa 1e-8)))
        (trans p+ 0 nrm)
        ((trans (vlax-curve-getPointatParam ent (+ (vlax-curve-getStartParam ent) 1e-8)) 0 nrm)
                                                             (setq p0 (trans pt 0 nrm))
                                                             (<= 0 (* (sin (angle p0 p-)) (sin (angle p0 p+)))) ;; LM Mod
                                            ) lst
                      ) 2
      (prompt "\nReference curve isn't planar...")
  (defun LWPoly ( lst )
    (entmakex
      (append
        (list (cons 0 "LWPOLYLINE")
              (cons 100 "AcDbPolyline")
              (cons 90 (length lst))
              (cons 70 (1+ (* (getvar 'plinegen) 128)))
        (mapcar (function (lambda ( p ) (cons 10 p))) lst)
        (list (list 210 0.0 0.0 1.0))
  (defun Group3 ( l / p pl )
    (repeat (/ (length l) 3)
      (setq p (list (car l) (cadr l) (caddr l)))
      (setq l (cdddr l))
      (setq pl (cons p pl))
    (reverse pl)
  (defun groupbetweennils ( l / a g gg )
    (repeat (length l)
      (setq a (car l))
      (setq l (cdr l))
      (if (not (null a))
        (setq g (cons a g))
        (if g
          (setq g (reverse g) gg (cons g gg) g nil)
    (reverse gg)
  (while
    (or
      (not (setq cur (car (entsel "\nPick closed curve on unlocked layer that lie in WCS..."))))
      (if cur
        (or
          (not (vlax-curve-getendpoint cur))
          (= 4 (logand 4 (cdr (assoc 70 (tblsearch "LAYER" (cdr (assoc 8 (entget cur))))))))
          (not (vlax-curve-isclosed cur))
    (prompt "\nMissed, or picked wrong entity type, or picked entity on locked layer, or picked entity not closed...")
  (if (= 0 (getvar 'worlducs))
    (progn
      (vl-cmdf "_.UCS" "_W")
      (setq ucsf t)
  (initget 6)
  (setq n (getint "\nSpecify nxn matrix for calculation n= <30> : "))
  (if (null n)
    (setq n 30)
  (while (= n 1)
    (prompt "\nSpecified number must be greater than 1...")
    (initget 6)
    (if (null n)
      (setq n 30)
  (initget 6)
  (setq m (getint "\nSpecify rotational 90 degree division m= <60> : "))
  (if (null m)
    (setq m 60)
  (while (= m 1)
    (initget 6)
    (if (null m)
      (setq m 60)
  (setq da (/ 90.0 m))
  (setq k -1)
  (repeat m
    (setq k (1+ k))
    (if (zerop (* k da))
      (progn
        (vla-getboundingbox (vlax-ename->vla-object cur) 'minp 'maxp)
        (mapcar 'set '(minp maxp) (mapcar 'safearray-value (list minp maxp)))
        (setq ul (list (car minp) (cadr maxp)) lr (list (car maxp) (cadr minp)))
        (setq dx (/ (distance ul maxp) n) dy (/ (distance ul minp) n))
        (setq r -1)
        (repeat (1+ n)
          (setq r (1+ r) c -1)
          (repeat (1+ n)
            (setq c (1+ c))
            (setq p (mapcar '+ ul (list (* c dx) (- (* r dy)))))
            (setq row (cons p row))
          (setq row (reverse row))
          (setq mat (cons row mat))
          (setq row nil)
        (setq mat (reverse mat))
        (setq mat (mapcar '(lambda ( r ) (mapcar '(lambda ( p ) (if (LM:inside-p p cur) p)) r)) mat))
        (setq matl (cons mat matl))
        (setq mat nil)
      (progn
        (vl-cmdf "_.UCS" "_Z" (* k da))
        (vla-transformby (vlax-ename->vla-object cur) (UCS2WCSMatrix))
        (vla-transformby (vlax-ename->vla-object cur) (WCS2UCSMatrix))
        (setq r -1)
        (repeat (1+ n)
          (repeat (1+ n)
            (setq c (1+ c))
            (setq p (trans p 1 0))
          (setq row nil)
        (setq mat nil)
        (vl-cmdf "_.UCS" "_P")
  (setq matl (reverse matl))
  (setq ar 0.0)
  (foreach mat matl
    (foreach row mat
      (if (not (vl-every 'null row))
        (foreach g (groupbetweennils row)
          (setq pr (car g))
          (setq pt (last g))
          (setq prpos (vl-position pr row))
          (setq ptpos (vl-position pt row))
          (if pr
            (progn
              (setq armat (mapcar '(lambda ( r ) (setq q -1) (vl-remove-if '(lambda ( x ) (or (< (setq q (1+ q)) prpos) (> q ptpos))) r)) mat))
              (setq rownilpos (vl-position (vl-some '(lambda ( r ) (if (vl-some '(lambda ( x ) (null x)) r) r)) (member (nth (vl-position row mat) armat) armat)) (member (nth (vl-position row mat) armat) armat)))
              (if rownilpos
                (setq q -1 armat (vl-remove-if '(lambda ( r ) (>= (setq q (1+ q)) (+ rownilpos (vl-position row mat)))) armat))
              (setq rownilpos nil)
              (setq rownilpos (vl-position (vl-some '(lambda ( r ) (if (vl-some '(lambda ( x ) (null x)) r) r)) (reverse armat)) (reverse armat)))
              (if rownilpos
                (setq q -1 armat (reverse (vl-remove-if '(lambda ( r ) (>= (setq q (1+ q)) rownilpos)) (reverse armat))))
              (setq ul (caar armat) ur (last (car armat)) ll (car (last armat)) lr (last (last armat)))
              (if (= (length ul) 2)
                (mapcar 'set '(ul ur ll lr) (list (list (car ul) (cadr ul) 0.0) (list (car ur) (cadr ur) 0.0) (list (car ll) (cadr ll) 0.0) (list (car lr) (cadr lr) 0.0)))
              (if (> (* (distance ul ll) (distance ul ur)) ar)
                (progn
                  (setq rec (LWPoly (list ll lr ur ul)))
                  (setq pl (Group3 (vlax-invoke (vlax-ename->vla-object cur) 'intersectwith (vlax-ename->vla-object rec) acextendnone)))
                  (foreach p (list ll lr ur ul)
                    (setq pl (vl-remove-if '(lambda ( x ) (equal x p 1e-6)) pl))
                  (if (null pl)
                    (setq ar (* (distance ul ll) (distance ul ur)) p1 ul p2 ur p3 ll p4 lr)
                  (entdel rec)
  (prompt "\nMaximal area : ") (princ (rtos ar 2 20))
  (setq rec (LWPoly (list p3 p4 p2 p1)))
  (entupd (cdr (assoc -1 (entmod (append (entget rec) (list '(62 . 6)))))))
  (if ucsf
  (princ)
(defun c:max-inscrib-rect-rot-matrices-each ( / UCS2WCSMatrix WCS2UCSMatrix LM:Inside-p LWPoly Group3 groupbetweennils ss el ucsf n m da k minp maxp ul ur ll lr dx dy r c p row mat matl ar pr pt prpos ptpos armat rownilpos p1 p2 p3 p4 q rec pl )
  (vl-load-com)
    (vlax-tmatrix
      (append
        (mapcar
        (list '(0 0 0 1))
    (vlax-tmatrix
      (append
        (mapcar
        (list '(0 0 0 1))
    (vl-load-com)
    (defun v^v ( u v )
      (list
      (if l
      (setq obj ent
      (progn
        (setq lst
          (_GroupByNum
            (vlax-invoke
              (setq tmp
                  (entmakex
                    (list
                      (cons 0 "RAY")
                      (cons 10 pt)
            ) 3
        (vla-delete tmp)
        ;; gile:
          (and
            lst
        (trans p- 0 nrm)
        (trans p+ 0 nrm)
                                            ) lst
                      ) 2
    (entmakex
      (append
      (setq l (cdddr l))
    (reverse pl)
    (repeat (length l)
      (setq a (car l))
      (setq l (cdr l))
      (if (not (null a))
        (setq g (cons a g))
        (if g
    (reverse gg)
  (while
    (or
      (prompt "\nSelect closed curves on unlocked layer that lie in WCS...")
      (not (setq ss (ssget "_:L" '((0 . "*POLYLINE,SPLINE,CIRCLE,ELLIPSE")))))
      (if ss
        (vl-some '(lambda ( x ) (not (vlax-curve-isclosed x))) (setq el (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))))
    (prompt "\nSome of selected curves not closed...")
  (initget 6)
  (if (null n)
    (setq n 30)
  (while (= n 1)
    (initget 6)
    (if (null n)
      (setq n 30)
  (initget 6)
  (if (null m)
    (setq m 60)
  (while (= m 1)
    (initget 6)
    (if (null m)
      (setq m 60)
    (progn
      (setq ucsf t)
  (foreach cur el
    (setq k -1)
    (repeat m
      (setq k (1+ k))
        (progn
          (setq r -1)
          (repeat (1+ n)
            (repeat (1+ n)
              (setq c (1+ c))
            (setq row nil)
          (setq mat nil)
        (progn
          (setq r -1)
          (repeat (1+ n)
            (repeat (1+ n)
              (setq c (1+ c))
            (setq row nil)
          (setq mat nil)
    (setq ar 0.0)
    (foreach mat matl
      (foreach row mat
            (setq pr (car g))
            (setq pt (last g))
            (if pr
              (progn
                (if rownilpos
                (if rownilpos
                  (progn
                    (if (null pl)
                    (entdel rec)
    (setq matl nil)
  (if ucsf
  (princ)
If you find this answer good enough, please mark it as solution...
Thanks, M.R.
Marko Ribar, d.i.a. (graduated engineer of architecture)
Message 62 of 67
marko_ribar
Still I've found some lacks in my codes... In attachment is my revision... I hope that now everything is perfect...
Regards, M.R.
Message 63 of 67
hs800150
@marko_ribar I couldn't get this code to work.
Message 64 of 67
marko_ribar
Have you downloaded attachment in last post? You have to unzip archive and there you'll find 2 LISPS... Start one and follow procedures... When asked for matrix size tap ENTER and when asked for angle division tap ENTER. Of course you firstly had to select closed curve. Also it is assumed that you operate with curves planar to WCS and that you haven't changed UCS... Then simply you have to wait and depending of your PC performances routine will finish with approximation of largest inscribed rectangle... At the end elapsed time should be printed at text screen - command prompt... If you want faster performance of routine execution when asked, you should lower both values (matrices size and angle division)... On my PC everything worked well... If that's not the case with you, post massage you get and that describes problem on your PC...
[EDIT : Sorry it was my blunder, there will be no text screen elapsed time output - only maximal area - if you started normal version - not "each"...]
Message 65 of 67
hs800150
I can't get your code to work on these. What is wrong? Thanks
Message 66 of 67
marko_ribar
The problem is that your geometry in DWG is far away from WCS origin point 0,0,0... Move temporarily geometry near 0,0,0, apply routine and when rectangle is generated return back all to previous position...
Message 67 of 67
hs800150
@marko_ribar's solution works the best but there are some minor problems with the solution. Every corner is not touching the sides of the polygon. There is a small gap in between each one.
